Question about Mi T M MiTM HS35060MGH HS Series 3500 PSI Hot Water Gasoline Pressure Washer U
Burner catches fire on my mi t m hot cleaner is it spraying to much diesel in to the mixing area
It's a diesel ingersoll rand air compressor did not play with the timing on it only the head gascet is replaced fuel is good but don't start
Make sure all air is bled from the system and the injector is firing a fine spray of fuel, add a tea spoon of oil to the cylinder to increase compression, a spray of diesel starting fluid sprayed into the air cleaner, housing with the filter removed may help.
Jul 09, 2015 | Ingersoll Rand Air Tools & Compressors
My 1977 1000cc sportster is back fireing when I open the throttle and it loses power.
It could be an air leak, air being drawn in somewhere under vacuum from the engine. The first thing to check is your carb connections are okay. Get a can of carb cleaner and get the bike idling/ticking over. Spray the carb cleaner around the area where the carbs are clamped to the engine. If the engine stutters or stalls it means air is being drawn into the carbs screwing up the air/fuel mix. Check the rubbers and clamps if this is the case.
Apr 20, 2015 | Motorcycles
I have a 2004 polaris sportsman 500 when it gets hot it cuts off and back fires
Does the cooling fan ever run when the engine is hot? If not, you may have a problem with the fan thermostat.
For the record, spray carburetor cleaner does no good if it's sprayed on the outside of the carburetor with the engine running. That's not what it's for.
Jul 29, 2014 | Polaris 2004 Sportsman 500 H.O
I would like a karcher instruction manual for a HDS650 pressure washer
I believe the HDS sends spark to the ignitor any time the machine is on ( hot or cold) You should hear the crackle of the ignitor in the burner area. Perhaps the ignitor rods are not properly aligned. Perhaps your ignitor coil is bad. There are several safety switches and the thermostat that would keep the burner from firing if they are bad. There is a pressure switch that turns on and off the motor for hot or cold operation. That is apparently working. I think there is a flow switch that turns off the burner. The thermostat might not be opening and closing contacts and that will keep the burner from working. I believe there is a high temperature safety switch as well.
Jul 15, 2014 | Garden
Burner stains Hot cookie sheet accidently set on
abrasive cooker cleaner. and pad. should clean it off. give it a good scrub.
Oct 27, 2013 | Kenmore Cooktops
If my engine to my accent has alot of grease oil and grime, do I need to clean it and if so how
if it works then leave alone unless its leaking bad then you want to find the leak ,for this a high pressure STEAM cleaner ,with hot water not a garden thing ,mix some diesel with washing up liquid and spray over engine ,leave a while then steam clean
Aug 27, 2010 | 2002 Hyundai Accent
My weber grill is not putting out enough heat--both burners ignite, but I can't turn them up to get a higher flame/higher temparature. The grill is about 5 years old. How can I clean the burners to get a...
follow the below procedures on how to clean the burners for your grill:
Shut off the gas. It is very important that you turn off the gas valve to your BBQ before you can begin to clean it. This is found on the hose that attaches to your propane tank, simply turn the valve all the way to the right.
Escape any remaining gas. Next turn all the burner knobs to the highest setting and allow the remaining gas, if any, to escape. Make sure you have the grill hood in the open position before doing this.
Let the Grill vent for five minute: In order to ensure that the remaining propane has ventilated properly, leave your grill open and do not begin to clean it for at least five minutes.
Brush grill bars. Using your grill cleaning brush, firmly brush the surface of the grill bars in a forwards-backwards motion with the steel from the brush sweeping across the surface. Once you have brushed the surface flip each grill bar over and brush the other side.
Saturate with grill cleaner spray and repeat. Using your grill cleaner spray thoroughly saturate the surface of the grill bars and brush both sides. Set the grill bars aside after you finish so you can access the interior of the BBQ to clean it.
Remove burner plates and clean. All gas grills have metal plates which cover and protect the flame pilots during cooking. These will typically become covered with ash, and burnt grease and sauce over time. Simply remove them from the grill and brush them down. After you have brushed them once, saturate them with the cleaner spray and brush them down again. Set the plates aside so you can finish cleaning the rest of your grill.
Clean interior of grill. The plates will only catch so much, still sauce and grease will fall to the bottom of the grill and turn to ash. Using your grill brush, jar all of this ash free. Douse it in cleaner spray so it condenses and scoop it up with the paper towels.
Clean grease catch. Many newer gas grills will come with a grease catching plate. You can usually access these through the rear of the BBQ. They generally have a small metal handle and will easily slide out. Remove this grease catch, and brush and clean it thoroughly.
Clean exterior of grill. Using your grill cleaner spray, saturate the exterior of the grill and wipe it down with the paper towels. Repeat this process until the exterior is entirely clean.
Reassemble the grill. Now you can put all the pieces back together in your grill and turn the gas valve on again.
I hope the above helps to solve your problem.
Good luck.
Aug 18, 2010 | Weber Grilling
I have spart, but won't turn over
so if its firing with starting fluid but not gas then your gas is not getting thru at the right rate. if you are in the USA get some Berrymans carb cleaner spray and a can of fuel additive. remove air cleaner and spray a ton or cleaner in. leave it soaking over night. try starting. add some of the mix in additive in the gas, if it will start run it till hot then let stand overnight. next day hopfully will be fine
Apr 03, 2009 | 2000 Harley Davidson XL 1200 S Sportster...
We have a Landa with a diesel burner. The problem
There is a screen in the tip of the spray nozzle for the diesel. Remove the tip and clean the screen. Your getting a explosion because diesel is pooling in the coils and igniting when conditions are right (air/fuel mixture). There is also a screen in the diesel pump. Remove the pump and clean it also. When you split the pump the screen sits between the two halves. Hope this will help.
Mar 31, 2009 | Garden
Oven Burner
try this,when you see the ignitor glow use a match and try to light the burner itself BE CAREFUL!! if the burner lights the problem is its clogged or low gas pressure.remove the burner and use brake cleaner to clean the burner AND pilot.if your using propane youll have to do this occasionally.let me know.
Jan 04, 2008 | Ovens
Mi T M MiTM HS35060MGH HS Series 3500 PSI Hot Water Gasoline Pressure Washer U Logo
35 people viewed this question
Top Mi T M Garden Experts
JOHN LAPIER
Are you a Mi T M Garden Expert? Answer questions, earn points and help others
