Question about Sharp AL-1642CS Copier
Vertical lines on copied page - Sharp AL-1642CS Copier
  • 61 Answers
Run a copy on the glass if there are no lines then something is on the scan glass of the document feeder. Use some window cleaner and scrub the document feeder glass and test. Sometimes white out or ink will stick to the glass and the scanner reads the dot as a line.
Posted on Sep 10, 2010
Testimonial: "Thank you, there was something on the glass. Got it cleaned off and is copying fine now."
How do I fix this
Vertical Bands, Lines, or Streaks in Copies, Faxes, or Scans
support.hp.com/us-en/document/c02881567
Figure : Sample output with vertical colored bands or lines ... Remove any paper from the automatic document feeder (ADF) tray. ... To protect the scanner, do not spray the glass cleaner directly on the glass. .... determine if your printer is still under warranty, and then Contact HP Support to schedule a repair or replacement.
How to get rid of lines on a copied page - YouTube
? 2:10
https://www.youtube.com/watch?v=xTJpCg5sHl0
Feb 17, 2010 - Uploaded by Wayne Springer
When you make copies on your copy machine, does it ever leave a black vertical line ... QLS ' How to Eliminate Vertical Linesfrom Scans, Copies & Faxes ... Part 2- Fix or repair color laser printer with fading, light print, or lines ...
Dec 29, 2015 | Office Equipment & Supplies
Copier is not connected to PC. Stand alone. Vertical line on copy
To determine if the line is caused by the cartridge, try printing a test page. Not sure of your model, but there should be a menu setting to print a configuration page. If that configuration page prints out clean, then there is likely debris in the scanning area of the document feeder. You should be able to locate the debris by lining up the vertical line with your feeder. If you could reply back with the model of your Canon device, we can help you a bit more. Alternatively, you should be able to pull the cleaning instructions from the manual for your copier.
Dec 27, 2015 | Canon Office Equipment & Supplies
Savin 9935DPE is printing one thick vertical balck line down the copy or print pages. About 2 of every 3 pages printed. What's wrong?
are you printing from Doc feeder or glas?? if from feeder then try to make a copy from the glass, does it still do it? yes problem is with drum.
No? problem is with the small scanning glass to the left, look carefully see if any spots or lines on the 1inch glas --- clean it
Sep 05, 2012 | Savin 9945dpe 9935dpe 2035dpe 2045dpe...
Vertical lines in copies and scanning
You need to clean small exposure glass located on the left of the main exposure glass.If this doesn't help,it can be a dust under the glass or on the mirrors that causing lines.
Oct 06, 2009 | Brother MFC 6490CW InkJet Printer
Full page vertical line appears on copy fed pages.
Open up the document feeder. You will probably find wite-out on the scanner glass.
Dec 12, 2008 | HP Officejet 5510 All-In-One Thermal...
Vertical lines (no printing) on copy
Make sure you have visited the HP web site for the OfficeJet 7310 (it's not the 10xi model, is it?)
Check out the page on troubleshooting copying problems.
See if your vertical lines issue is addressed on this page.
Nov 08, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Vertical line on page
i have the same problem although its a horizontal line
Jun 19, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Vertical lines on multiple page copying
Did you check to see if the lines are before or after the fixing unit? Stop a copy before it gets to the fixing unit. If there is no lines in the same spot, then the problem is in the fixing unit, if not check the and clean the optics and dust proof glass. Good Luck...
Apr 16, 2008 | Sharp AL-1642CS Copier
Print Problem - vertical lines
If the problem only occurs when using the document feeder, the problem is not usually caused by the drum. When using the document feeder, try to notice where the scanner (the light assembly under your scan glass)stops just before the paper is being fed. Some multifunction machines have a small piece of glass that is separate from the large scan glass and the scanner assembly stays parked underneith it as the original is being fed over it. Most likely there is something on the glass where the scanner parks as originals are being fed thru the feeder. When putting your original on the large scan glass to copy, the mark on the glass will only show as a spot, but will show as a vertical line thru the whole copy when using the feeder.
Feb 23, 2007 | Brother MFC-7820N Laser Printer
164 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
