Question about Compaq Computers & Internet
Hard drive help with on how can I install a hard drive to my pc without a disk to install it.
    Genius:
  • 2,785 Answers
Connect the new hard drvive as slave and old one as master(by jumper settings) then boot the pc, after that your can format the new hard drive
Posted on May 14, 2008
Have dell latitude d630 laptop had widows vista won't re boot says no internal drive no boot able devices help me hard re boot system Without disk
your hard drive gone. you will need to get another hard drive, install it and place your old hard drive in an external holder and see if you are able to still access it.
Jul 28, 2014 | Computers & Internet
Erased hard drive, how can install os without the disk?
You would require an installation media to re-install OS, So you can't do it without CD or USB thumb drive with installation file.You can call dell @ 8006249896 and ask them for OS disk, If you wouldn't have received with the computer, they will be sending it to you free of cost and it will only take 2 to 3 business days for you to receive those than you can re-install OS.
Dec 28, 2012 | Dell Inspiron 1525 Notebook
How can I install my hard drive without the cd?
HI jamarrfinney
If you only want to install on your hard drive as backup, cd is not needed. just set the hard disk jumper to slave for IDE hard disk. If you are using SATA hard disk, no need to set jumpers, just insert the cable and then set the bios setup hard disk as a second hard drive (if necessary)
regards
Jan 11, 2011 | Computers & Internet
It is not formatting., please help me
hi
follow these instructions
Instructions Things You'll Need:
  • Windows installation media (and product key)
  • Manufacturer software
  1. Ensure that the hard disk is installed properly in the laptop. The drive cannot be formatted before it is installed, or if it's not installed correctly.
  2. Gather the required software. The type of media will depend on the hardware in your laptop. Older computers without a CD-ROM drive, will require the use of the operating system floppy disks. Laptops that can run Windows XP require the installation CD and product key. Older versions of Windows also have disk-formatting capability in the installation process, and the installation media is either a CD or floppy disk.
  3. Place the installation disk or manufacturer software in the drive and then boot the computer. Early in the installation process, the Windows installer has a step that will detect any installed hard disks and allow for them to be formatted. The software from the disk manufacturer will also detect the hard disk and give you the option to format the drive.
  4. Determine which file system is to be used. Windows XP will either work on a NTFS file system or an older VFAT file system. Choose the desired file system when prompted.
  5. Decide whether the whole disk should be formatted or if the disk will be partitioned and each partition to be formatted separately. The Windows installer includes a menu-driven utility that will create hard disk partitions before formatting. If the hard disk is being formatted to replace an existing Windows installation, delete the existing partitions and re-create them.
  6. Format the hard disk with the Windows installer when prompted. The Windows installer will let you know when it is time to format the disk and ask for confirmation.
this should help you.
Nov 28, 2010 | Computers & Internet
I want to replace HDD on my HP ProBook 4510sand I don't know how help somone.
Hard Disk Drive removal
  1. Review the safety considerations before performing the steps listed below by clicking on the following link: CAUTION: Failure to comply with the precautions could result in damage to your product or loss of data. CAUTION: Observe all precautions when removing and replacing components.
  2. Remove the battery, switch cover, keyboard, and palm rest.
  3. Remove the two silver 3mm P000 Phillips-head screws from the left side of the hard disk drive bracket.
  4. Loosen the captive P1 Phillips-head screw on the right side of the hard disk drive bracket.
  5. Use the black Mylar tab located on the hard disk drive enclosure to slide the hard disk drive away from the hard disk drive connector on the system board.
  6. Remove the hard disk drive from the hard disk drive bay.
  7. Place the hard disk drive in an electrostatic dissipating bag.
Hard Disk Drive replacement
  1. 1. Remove the hard disk drive from the electrostatic dissipating bag.
  2. Place the hard disk drive into the hard disk drive bay and align it with the hard disk drive connector on the system board.
  3. Use the black Mylar tab located on the hard disk drive enclosure to slide the hard disk drive securely onto the system board connector.
  4. Tighten the captive P1 Phillips-head screw on the right side of the hard disk drive bracket.
  5. Replace the two silver 3mm P000 Phillips-head screws on the left side of the hard disk drive bracket.
Sep 19, 2010 | HP ProBook 4510s FM849UT Notebook
Recently i ordered a dell studio 14 laptop. they did not send me any copy or disc of the OS installed in it, i.e., Windows 7 Home Premium. however the entire 500 GB of hard disk space has been only in the...
Hello Sir,
You can create a Partition in your hard drive without affecting your OS. Just follow the process I've sent.
1.) Go to Start Menu and Type in search area Create and Format Hard Disk Partition.
2.)Open the Create and Format Hard Disk Partition.
3.)Now you can Select the C: and can Partition it with another new drive.
Thank You
Aug 09, 2010 | Dell Computers & Internet
Not recognizing hard disc drive for windows xp reinstall .
You aren't using the correct install disk . The generic XP install disk can't recognize a SATA disk.You will have to load the appropriate driver during install. Here it is ftp://ftp.hp.com/pub/softpaq/sp32001-32500/sp32492.exe
Or you could create a custom install disk  as explained here
http://news.softpedia.com/news/Install-Windows-XP-On-SATA-Without-a-Floppy-F6-47807.shtml
May 13, 2010 | HP Compaq Presario C304NR Notebook
Blue light is flashing but the computer is not recognizing the drive. The drive is colde
try installing the drive on a friends pc to see if it is the drive or your pc
simple things first...
if you do a test on a friends pc take a couple of cdrs/dvdrs so you can burn the files you can't live without...
good luck
rate if helpful
Oct 25, 2009 | LaCie Big Disk External USB 2.0 1TB Hard...
Installing windows on acer notebook help
you cannot usually switch installed operating systems from computer to computer like that and still expect windows to boot, but with windows 98 it *might* work.
to install windows 98 on the usb drive, insert and boot from the windows 98 disk like you were to install it on that computer , and then, it should, before it formats any drives, give you a choice of what drive to format.
Oct 09, 2009 | Acer TravelMate 340T Notebook
Pc problems
Why do you want to format your hard disk for? Do you wish to install a new operating system on your PC, or do you want to format a second hard disk.
If you want to install a new operating system, then you will need to install a CD drive or an external CD drive and then you can format your drive and install a new operating system.
Use a floppy disk, This must be a boot disk with operating system files. Suggest you use Windows ME.
Apr 18, 2008 | IBM ThinkPad T23 Notebook
Computers & Internet Logo
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
