Question about Video Game Consoles & Games
Wont work when you power x box up.red light pops up and keeps flashing .i have a x box 360.pass word e68
  • 4,102 Answers
Hi you have got the dreaded red ring of death, this is very common with all xboxes and their are people out their that will fix them for you for a fee.
their is nothing you can do yourself to solve this problem as its a case of taking the xbox apart and removing the heat sinks and the x clamps and fitting new parts and new heat sink paste, this is a big job and requires special tools. so its not for the novice to do.
i do the repairs to these on a regular basis and 8 out of 10 i fix work again but others tend to be to far gone.
any way the reason you are getting this warning light is due to it over heating, check the date on the sticker on the back of the xbox as it is covered by warranty for 3 years for this exact fault so if its less than 3 years old go to the xbox website and get them to replace it for you, if its outside this time then you have 2 options you could either repair it or sell it.
you can buy repair kits and get the instructions off the net but without having done it before it can by really hard to do and you could do more harm than good.
when they built these they used cheap parts and cheap heat sink paste now over time this causes it to over heat and then you get the dreaded red ring of death and this shows you the either the gpu or cpu chip has over heated.
now the repair involves taking the xbox apart which is not easy but can be done you need to then remove the x clamps and then remove both heat sinks. once their removed you need to clean them up and remove all the old heat sink paste and use new paste, you also need to get xbox rrod repair kit as you wont be using the cheap x clamp bits anymore these will go in the bin as this is what caused the problem in the first place.
let me know what you would like to do or if you need further assistance ok
i also be damaged xbox's but im based in UK
plz rate this solution as i have a whole page of unrated posts, thanks
Posted on Sep 10, 2010
When I turned on my system, it had system error contact xbox customer support. There is a red light flashing on the bottom right, around the power button. I don't know what to do. Please help.
Some of us suddenly when we turn on our Xbox 360 console one day we got one red light flashes on the ROL (Ring of Light) around the Xbox 360 power button, and we got an Error message appearing on the TV screen "System error" also might occur with any error code like E66, E67, E68, E71, E74 or E77, all the same.
When you get any of these messages appearing on your screen with one red light flashing on the ROL of your Xbox 360 console that's an indicator of a hardware problem with the console connection to one of the parts connected to it as the hard drive or cables.
So, first disconnect all power and AV cables from the back of your Xbox 360 console and also unplug the power cord from the wall socket, wait for a minute then reconnect them all back and try to turn on your Xbox 360 console once more.
If that doesn't work, it seems then to be a fault with your Xbox 360 hard drive so turn off the console again and remove the hard drive then turn on your Xbox 360 console without the hard drive, supposed then to work fine, it might be an intermittent issue and when you reconnect the hard drive your Xbox 360 will work fine all after, or it will just work fine without the hard drive so it will be then definitely a fault with your Xbox 360 hard drive so call Xbox 360 customer support to exchange the hard drive for you.
The Xbox 360 console might even keep giving you the same error code even after you remove the hard drive so it will then appear to be a fault with your Xbox 360 console not the hard drive & also in a case like this we need to contact Xbox 360 customer support to exchange the console.
Read more: http://xbox360help.blogspot.com/2007/03/one-red-flashing-light-xbox.html#ixzz14pQlSds6
Nov 09, 2010 | Microsoft Xbox 360 Console
One red ring, erra 68.
What you need to do is try using the console without the hard drive or with a different hard drive, one red ring means a hardware failure, and the error code e68 is in relation to the hard drive. If using the console with a different hard drive, or none at all doesnt work, ensure that the fans are working as they often also cause the e68 error and a single flashing red light.
I hope this helps. Good luck.
Sep 03, 2010 | Microsoft Xbox 360 Console
The light on the box that the electricity passes through is red, and I don't know why. What does it mean? This happened about 5 minutes ago, and I received the E68 error 2 days ago, but I dusted off the...
Xbox 360 red lights or Xbox 360 red ring of death error is very infamous among all Xbox gamers. About 33% of all console owners experienced this error. So if you are now seeing three flashing red light near the power button of your console, congratulations, you "improved" the statistics.
At a first glance the problem might have seemed very frustrating but this is not really so. There are two possible solutions to this problem. The first one is to send your console to the Certified Microsoft Service Center and if your warranty is OK you will receive your console back in 2 months. Yes, it's not a joke, the repair process will take two months. Alternatively, you can repair it yourself. To do it you will need to get Xbox 360 Red Lights Repair Guide. This guide illustrates how to fix red lights problem at home within 1 hour.
Don't be afraid, the guide won't require any technicak knowledge or skills from you. Just follow the steps and get your console repaired.
Jun 29, 2010 | Microsoft Xbox 360 Console
The xbox360elite the red light flashes and e68 comes up on the screen with different language on the tv screen is also showing.
E68 means that you have a bad hard drive. Take out your hard drive and turn the unit on to confirm. Once this is done just buy a new hard drive and your good to go! Or now Microsoft just released where you can use a Flash drive :]
Apr 05, 2010 | Microsoft Xbox 360 Elite Console
Got system error E68-and a red light-this has happened after using a hard drive to save my game data-now can't find any data-would appreciate assistance!!!
I've got a permanent fix for Error E68 to help you out, But first ill tell you my XBox was dropped so it might have just worked for mine, i will be posting a vid on youtube by Nov. 5 2009 look for imthatstupidkid fix X Box Error E68 walkthrough
Oct 20, 2009 | Microsoft Xbox 360 Console
X Box 360
It might be Red ring of Death problem, You can either send your Xbox toMicrosoft and wait for 2-3 weeks till you get back your Xbox or you canfix the problem yourself with the help of a DIY fix guide.
Check out the post discussing about RROD problem here: http://www.fix-xbox360.info/2008/08/23/xbox-360-red-light-fix/
Hope it helps...
Jan 05, 2009 | Microsoft Xbox 360 Console
Red light flashing on the bottom right of power button. error is E68
Hi burnzcity,
It seems you have an issue with a Xbox 360. So, according to Microsoft, one red light flashing means you have a system error and suggest you contact Xbox Customer Support. Here is a link that should provide you some assistance.
Sincerely,
Agent Xiong
May 09, 2008 | Video Game Consoles & Games
Xboxe 360 console arcade
you got the red lights of doom #1 suggestion make sure your harddrive is plugged in all the way #2 make sure all cables are pluuged in if thats not it go onto the web fin da video of how to get three red light instead of one nd send it into microsoft becuase your warranty cover three lights not 1 or 2
Jan 02, 2008 | Microsoft Xbox 360 Console
Video Game Consoles & Games Logo
18 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
