Question about HP LaserJet 2100 Printer
Config page in hp2100 - HP LaserJet 2100 Printer
  • 903 Answers
On the LaserJet 2100, press the Go and Stop buttons together, then let go, and the configuration page will print out. (You may have to hold them down for a couple of seconds.)
For configuration page instructions for other printers, see the How to Print Configuration Pages web site.
Posted on Jul 07, 2011
Config page on hp4345 without menu button
You would need to log into the embedded webserver to view the configuration page. From there you could screen capture it as I do not believe that the print config page was added until later models.
Oct 31, 2014 | HP LaserJet 4345mfp Printer
Tip
How to print a config page on a Ricoh printer
On Ricoh printers, the configuration page (also called the Config page) is an information page that can be printed out with detailed data about the machine's status. The Config page shows the printer's copy count, various network settings, and current firmware versions, among other things. One nice feature of the Config page (on most printer models) is that it shows how much toner is left in the cartridge or bottle, so you can find out if you'll need to order more soon.
Follow the steps below to print a Config page from a stand-alone Ricoh printer.
A. Turn the printer on and wait for it to warm up.
B. Press the Menu button.
C. Scroll through the list of submenus using the up and down arrow keys until you see List/Test Print, then hit the OK button.
D. Look for the Config Page option, and hit OK again.
The configuration page will print out, and depending on that specific printer, it might be two pages rather than one. Whether the printer is black and white or color, the configuration page will be printed in black and white. If you want to print a test page in color, scroll further down the List/Test Print menu and you should see something called the Color Demo page.
To print a Config page from a multifunction Ricoh printer (one that scans and copies as well as prints), the steps are similar, but some of the machine's buttons are different. Multifunction printers typically don't have the Menu button, so you would press User Tools instead and then go to Printer Features. From there, the process is pretty much the same as described above.
on Jun 19, 2010 | Office Equipment & Supplies
How do you get a page count from an HL 5140/
On the HL-5140, you can print out a config page which will show the page count on it by pressing down the Go button (the blue button). Hold it for a few seconds, until the config page starts to print out.
To find configuration page instructions and page count tips for other printers, copiers, and fax machines, check out How to Print Configuration Pages.
Aug 22, 2011 | Brother HL 5140 Laser Printer
I have a hayward heatpro model hp2100. the heater will run and heat the pool for a while then shuts down displaying LP on the digital screen, after a period of time it will clear the LP and have running...
LP is an error message refering to the low pressure switch. For more information about it please refer to your owner's manual here. If you decide to persue attempting to repair it yourself and need further assistance, please reply to this post with a new comment or start a new post with your specific question(s).
John
Feb 01, 2011 | Hayward Hp2100 Digital Heat Pro Heater...
Do you know how to print a config page with the ip address on a imagerunner 5570
To print a config page you go into service mode (*28*) -copier>option>p print this will print out all the configs. For just the ip address go in to the add. function >network>ip4>ip
Dec 31, 2010 | Canon imageRUNNER 5570 Copier
Xerox 3500 config page
To print a configuration page from a Xerox Phaser 3500:
- Press the Menu button
- Information will be displayed on the screen -- press OK
- Go to Info Pages, and press OK
- Go to Config Page, and press OK
To get configuration page instructions for other copiers, printers, or fax machines, go to How to Print Configuration Pages.
Nov 10, 2010 | Xerox Phaser 3500/DN Laser Printer
HOW TO GET METER READING?
Switch it on and load paper.
Press the red and green buttons together, and several pages should print out, test page, config page, and perhaps a EIO or network config page.
The second page should show the page count.
Feb 03, 2010 | HP LaserJet 2500 Printer
HP2100 aaargh!
Click on "control panel"
select "printers"
Do you see (hp2100) your printer?
If NO, it is NOT installed correctly.
If you DO see it, RIGHT click on it and select PROPERTIES
The GENERAL tab will show if it is working properly
Click on the Tab labeled DRIVER, and you will see an option to UPDATE DRIVER-click that.
Another way to view your printer is go to
CONTROL PANEL
then select SYSTEM then select HARDWARE
then select DEVICE MANAGER- (this will show everything-all your hardware and peripherals)
Look for IMAGING DEVICES and click on the "+"
Do you see your (hp2100) printer?
NO-not installed
YES-(but if there is a yellow triangle here it indicates an error)
RIGHT click on printer, select PROPERTIES
select DRIVER, click on UPDATE DRIVER.
You may need to restart.
Let me know how this works.
Hope this helps.
FYI : Xp does come with drivers, but they may be outdated, hence your problems.
Jan 14, 2010 | HP LaseJet 4350dtn Laser Printer
HP2100 laserjet won't print inserted pix in Word 2007 doc
I ended up fixing this problem myself.
I needed to set the printing resolution in the HP printing dialog box to 1200 x 1200 dpi as the HP2100 can print at this resolution.
Select: Print/Properties/Advanced/Graphics. Then set the printquality to 1200 x 1200 dpi.
Rod Salter
Dec 15, 2008 | HP LaserJet 2100 Printer
HP LaserJet 2100 Printer Logo
129 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
