No matter how many times i try to get towel to spin it will not spin out!!!
  • Washing Mach... Master
  • 43,501 Answers
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Sep 08, 2010
Washing machine won't go to spin cycle if there are towels in it
Washing machines have trouble if they are overloaded and the load gets out of balance. This occurs most often with towels. Open the machine and lift the towels out and put them back in evenly to get the load to finish. You will see how heavy they are when full of water. In future, try running with a few less towels and see if it works ok. You have found the other 'fix' by draining and running spin only which probably resettles the load.
May 11, 2017 | Washing Machines
My Maytag Centennial top load washer start to refill at the end of the spin cycle....help!
This is an issue with the timer starting the cycle over again and it will need to be replaced. Here is the part to order. To replace the timer remove the back of the console to access the timer.
Nov 23, 2012 | Washing Machines
WHIRPOOL washer model LSR8010PQ0, WHEN LOADED WIT...
If large items in the machine create an imbalanced load the machine is designed to switch off...Towels are notorious for doing this because they hold so much water. Jeans don't soak up much water. Wash towels with towels alone and the problem should be reduced....Good luck....Nomess
May 16, 2010 | Washing Machines
Clothes, especialy towels smell moldy no matter
Same problem here, heavy lime in the water, we had to change to Purex powder with Renezit. Problem is gone!
Jan 29, 2010 | Samsung Washing Machines
GE Front load washer spinning too slow????
A couple of things come to mind,if the micro-processor senses the load is out of balance enough, it will control the RPMs(reveloutions per minute) or slow it down in order to avoid damage to the suspension system, so readjusting the spin speed manuallly probably would help. Although that machine should be able to handle 9 large towels easily! Next thing, have you cleaned out the trap inside the lower access panel, if it is restricted you will have draining problems. Good luck !
Jan 07, 2010 | Kenmore 22422 Top Load Washer
Beach towels sopping wet after machine done spinning
The washer will not proceed into high speed spin with just two large beach towels in the basket. The washer is detecting a out of balance condition, and remains in low speed spin. Solution? Try adding more items into the basket. With only two towels, there is not enough mass to balance the washer. With more clothing or towels, there is more items for the machine to balance, and reach full speed spin.
The only other thing that could cause this, would be if the water in the tub is not completely draining in the time allowed. This washe does not have a cleanout, and checking for an obtruction in the pump is difficult. I would go with the more clothes first, then see.
Sep 25, 2008 | GE WSXH208A Front Load Washer
Hard towels
If you are drying your towels outside they will always be hard no matter what you try........ Drying them in the dryer is the only solution to that problem........ I have tried everything else and the dryer is the only thing that works..... Hope this helps
Oct 19, 2007 | Electrolux EW1000i Front Load Washer
Washing Machines Logo
52 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
