Question about Panasonic VIERA TX-37LZD800 37 in. HD-Ready LCD TV
Volume control does not work the first minute or so when turned on. Only works if you are a few feet away and point remote directly at the receiver at bottom of screen.
    President:
  • Panasonic Master
  • 1,779 Answers
I would take your hand remote to a retailer that sells Panasonic and try it on one of their sets to eliminate the remote. If thats ok, then the problem is with the IR receiver in the set.
Posted on Sep 08, 2010
Remote control won't work 10 feet away but if two feet away it works. What gives?
the remote uses light to send a signal to the tv. make sure there isn't anything interfering with the light signal. it could be dirty or the receiver could have dirt obstructing the light.
Mar 20, 2013 | Panasonic TC L42E50 - 42" VIERA E50 Series...
Volume control on reciver isn't working. Only using remote control for volume works. So I must need a volume control for the receiver. Is this an easy fix or not worth the time to fix
Hello
You haven't specified if all the other functions are working with the remote control or not. If no functions are working with remote control, either there is no infrared emission from your remote control handset. Check it with the help of a cellphone with camera option. Cellphone digital camera can detect the infrared rays comes out of the remote control. Just put the cellphone to camera mode, and place the remote control just about 1 feet away from its camera lens and push each button on the remote control and see whether there is any image of infrared rays indicates at your cellphone camera screen. If not, be sure that the remote control is not working, and should be replaced or repaired. Replace the cells first, and check. If this does not helps you and still the remote control is not working, replace it.
If the remote control works, and the all the other functions of your device can be set with it, the motor of the volume control or it control circuitary has damaged. To check this, you must have through knoledge in electronics and is a time taking service work. OK.
Apr 24, 2011 | Sherwood RD-6500 Receiver
Dish remote won,t work if Visio E550Vl is in operation.
Hey there! Becki Barned with Dish Network here! The problem that you are having is interference with your tv. You can try to move your receiver away from your tv a little, just a few feet, so that the LCD tv is not affecting the signal from the remote.
Dec 23, 2010 | DISH Network IR Remote Control
Remote control rmt b101a stopped working, changed batteries, same thing; did reset by pressing power, TV i/o and vol- simultaneously, still not working. Help!
Make sure that the Remote is operating in a range of 3 to 10 feet away from the unit.
Point the Remote directly towards the Remote Sensor of the Device.
Remove any obstacles that may be in the path of Remote and the Sensor.
Make sure that no interference is blocking the Remote to operate normally. Do not expose directly to Sunlight, bright florescent lights etc.
Try resetting the Remote by removing the batteries from the Remote control, press every button twice, and then re-install the batteries after 1 minute.
Make sure that none of the buttons on the Remote control is jammed.
Install fresh alkaline batteries in the Remote, do not use rechargeable batteries.
Make sure that the batteries are inserted by matching the polarity (+ & -).
Try resetting the Blu-ray Disc Player with which you're using the Remote.
If the issue persists, after all the possible troubleshooting steps, service may be required.
Thanks for using FixYa
Dec 03, 2010 | Sony RMT-B101A Remote Control
Remote want work on tv
Make sure that you're using the supplied Remote (RMY-906) to control the TV. If so, perform the steps given below to resolve the issue.
  • Make sure that you're using batteries which are having enough charge. Try using fresh alkaline batteries.
  • Do not use rechargeable batteries in the Remote.
  • Ensure that the batteries are inserted correctly with the correct terminals by checking the + and - symbol in the battery compartment.
  • Make sure that the Remote is set to operate with the correct functions. On the remote control, press the TV FUNCTION button to re-check this.
  • Press the POWER button and other buttons to test the operation.
  • Make sure that none of the buttons are jammed in the remote control.
  • Ensure that the remote control is being used no closer than 3 feet and no further than 10 feet away from the unit. Try using the remote control at varying distances from the TV.
  • When using the remote control, be sure to point it directly at the remote sensor on the device.
  • Remove any obstacles that may be in the path between the remote control and the device.
  • Ensure the remote sensor of the device is not exposed to direct sunlight or bright florescent lights, as this can interfere with the sensors ability to receive signals from the remote control.
  • Try resetting the Remote. To reset the Remote. remove the batteries from the remote control, press every button twice, and then reinstall the batteries.
  • Try resetting the TV also to check the operation. To reset the TV, disconnect the power cord for a short period of time (approximately 1 minute), then reconnect the power cord and power on the television.
If the remote control is able to operate other devices (such as cable box, DVD Player or satellite receiver), then the issue may be with the IR sensor on the TV. If this is the case then the TV that will require service. Otherwise, the remote control may need replaced.
Good Luck!
KenSolutions
Nov 23, 2010 | Sony KP-61S75 TV
Remote control stopped working.
Hi forlillis,
1. Make sure there are fresh batteries in the remote, and they are installed correctly.
2. Make sure the area between the remote control and receiver is not blocked by some object,
and the distance is no more than 15 feet at an angle no greater than 30 degrees from the
front of the receiver.
3. Make sure strong lighting is not directed towards the IR sensor of the receiver.
4. Press each button on the remote and verify proper operation.
If these steps are taken and remote control still does not function properly
5. This step discharges the capacitor and resets the remote control. (You do not need to point
the remote control at the receiver or even have the receiver turned on.)
A: AVR35  Press the TV and the M4 buttons at the same time and hold for 12 seconds.
To Test: Make sure your AVR35 is ON, press each button on the remote and verify
proper operation of your receiver.
Let me know how it went.
lykohavi
Aug 05, 2010 | Harman Kardon AVR 35 Receiver
My HK 1005 incresases volume to max by itself
I had the same problem; got rid of it by changing the baateries of ma remote control.
Jun 27, 2010 | Harman Kardon DPR 1005 Receiver
Direct TV remote quits working - conflict with Samsung LCD?
Turned power saving feature on the TV to low and moved the receiver about four feet away from the TV and the remotes work fine now.
Sep 03, 2009 | Samsung TV Remote Control
Kenwood VR-6070: Broken volume knob; will IR sensor still work?
Looks like you have several faults?
First try to fix the remote:
http://www.instructables.com/id/Repair-your-remote-controls/
May 28, 2009 | Kenwood VR-6070 Receiver
Panasonic VIERA TX-37LZD800 37 in. HD-Ready LCD TV Logo
125 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
