Question about Roper REX4634KQ Electric Dryer
Everythings been checked.... there's power and heat, but it won't tumble....
  • Roper Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley.
If you have to check/replace/repair your drum motor or belt and if you have a front loading machine:
Note: This method works for most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch or other electrical connections.
Remove the lint filter and the screws that hold the filter housing.
Then remove the top of the dryer.
Note: Some of the tops tilt backwards and do not have to be removed completly.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
Please rate me
Posted on Sep 09, 2010
Hotpoint Dryer model DLL2650BFLWH won't blow heat
So your not getting any heat. There could be a number of different problems. I believe this is a gas dryer. You would need to remove the drum and check the ignitor. This is a little complicated and I would recommend a technician since this is a gas drier.
Oct 27, 2012 | Hotpoint Dryers
Lhe5700wo won't heat after power outage
the heating element may have burnt out , you can purchase on for around $25 dollars , also check thermostats, I usually find where the heating element has burned into, then spice it back together with a stainless steel electrical **** connector , check with ohm meter . heating element runs in a metal box shaped container and looks like a spring coiling through ceramic insulators .
Mar 13, 2012 | Dryers
The heat is working but it won't tumble
tilt it back and see if the belt broke. do you hear the motor runnung?
Dec 31, 2011 | Dryers
My LG tumble dryer does not heat up, the motor runs and everything tumbles inside but it does not heat up. what could be the cause of this?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101\]]\]\
Aug 16, 2011 | Dryers
Dryer tumbles but won't heat up
heatman101
Aug 09, 2011 | Estate Dryers
My gas dryer won't tumble or heat
sounds like a few things are wrong/ needs checked, will not tumble is usually the belt, no heat is usually a thermal fuse if the pilot light is lit. Here is a website that will assist you Tim:
http://www.applianceaid.com/gas_dryer.html#noheat
May 15, 2011 | Kenmore Dryers
I checked everything now i am down to the timer will this cause the dryer not ti heat?
If your dryer doesn't heat, check these:
Power from the house
Heating element
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Aug 05, 2009 | Kenmore 63942 Dryer
Dryer not heating...everything seems OK
Y'ou are zeroing in on your problem. Read the info below and hopefully you will have your answer:
Heating element
Thermal fuse
Wiring
May 29, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
There is no heat
Disconnect power and access your dryer fuses. Check and test your fuses for "continuity". Most likely, a white thermal fuse. Can possibly be your ignitor or heat element as well. Is your dryer gas or electric?
Jan 27, 2009 | Hoover Dryers
No heat to tumble dryer
Check the thermal disc with an OHM meter. One will be next to the heat element (high limit) and another on the air exhaust area which is the low limit.
Dec 16, 2008 | Dryers
Roper REX4634KQ Electric Dryer Logo
32 people viewed this question
Top Roper Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Roper Dryer Expert? Answer questions, earn points and help others
