Question about KitchenAid 24 in. KUDP02FR Built-in Dishwasher
The bottom water jet (four pronged turning thing) came off, and I am unable to screw it back on
  • KitchenAid Master
  • 43,501 Answers
Unfortunately those pieces break and need to be replaced...
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Sep 08, 2010
How do you adjust idle speed 1991 johnson 100 hp
not important, what's important is that they are absolutely clean, including the four brass high speed jets located in the bottom center portion of the carburetor.
That model engine's carburetors has fixed jets, BUT if the slow speed jets are adjustable, earlier model carburetors have been installed. If so...................
The four adjustable needle valves control the flow of fuel in relation to the set air flow, adjusted as follows (if needed).
(Dual Carb V/4 With 4 (2 each carb) Slow Speed Adjustable N/Valves)
(J. Reeves)
The adjustment procedure of the carburetor slow speed needle valves follows. NOTE... if the needle valves turn too freely, replace the nylon bearing retainer (the nylon item at the front of the carb that the needle valve goes through first) with the newer type RED retainer #315232. If your engine has that weird linkage that connects all four of those needle valves, the newer RED retainers will enable you to discard that linkage. The RED retainers make it impossible for the needle valves to vibrate out of adjustment.
(Carburetor Adjustment - 2 Slow Speed Adjustable Needle Valves, each carburetor)
Initial setting is: All (4) Slow speed valves = seat gently, then open 1-1/2 turns.
Facing the carburetors, start with the top left needle valve, then the top right valve, then the bottom let valve, then the bottom right valve. It may be necessary to redo these steps to get the adjustments ideally set
Start engine and set the rpms to where it just stays running. In segments of 1/8 turns, start to turn the S/S needle valve in. Wait a few seconds for the engine to respond. As you turn the valve in, the rpms will increase. Lower the rpms again to where the engine will just stay running.
Eventually you'll hit the point where the engine wants to die out or it will spit back (sounds like a mild backfire). At that point, back out the valve 1/4 turn. Within that 1/4 turn, you'll find the smoothest slow speed setting.
Do not attempt to gradually adjust all four of the valves at the same time. Do one at a time until you hit the above response (die out or spit back), then go on to the next valve.
When you have finished the above adjustment, you will have no reason to move them again unless the carburetor fouls/gums up from sitting, in which case you would be required to remove, clean, and rebuild the carburetor anyway.
Jun 28, 2017 | Cars & Trucks
My Gibson dryer has a three prong plug on it.I
The National Electrical Code began requiring 4-prong receptacles for 220-volt residential circuits in 2000, but it doesn't prohibit you from using your older dryer with a 3-prong cord. Instead, it allows you to change the cord so that the dryer can be plugged into a modern receptacle, and the procedure isn't very complicated. Four-prong dryer cords, or pigtails, are available at hardware and electrical supply stores, and usually cost less than $20. To make the switch, you'll need a green ground screw to attach to the dryer body so the machine can be grounded by the ground wire.
1 Unplug the dryer and move it to an accessible spot. Unscrew the plate on the back that covers the electrical terminal with a screwdriver. You'll find the cover on the back of the dryer near the bottom of the machine at the point where the cord exits.
2 Loosen the three terminal screws holding the cord. Before you remove them and take off the cord, note the colors of the screws and the wires attached to them. The screws holding the black and red wires are brass and the one holding the white wire is silver.
3 Remove the ground strap from the silver terminal. It may be a small metal plate or a length of wire connecting the terminal to the body of the dryer. You may be able to pull it out with pliers, or you may have to loosen a screw to remove it. Its function was to ground the dryer, and that function will now be served by the ground wire on the new pigtail.
4 Insert the brass terminal screws into the ring lugs attached to the red and black wires on a replacement pigtail and the silver screw into the ring lug on the white wire. Drive the screws into the same slots from which you removed them and tighten them securely with a screwdriver.
5 Drill a 1/4-inch hole in the body of the dryer within reach of the fourth wire in the pigtail, which is green. Insert a green ground screw through the ring lug on the end of that wire, drive the screw into the hole and tighten it securely.
6 Feed the cord through the notch on the terminal cover plate and screw the cover plate to the back of the dryer.
Things You Will Need
  • Screwdriver
  • Pliers
  • Drill
  • 1/4-inch drill bit
  • Ground screw
  • 4-prong pigtail
Tip
  • There usually isn't room behind the cover plate to install the ground screw. If not, it's acceptable to attach the screw to the back of the dryer outside the plate.
  • Check the grounding with a multimeter before you plug in the dryer. Set the meter to ohms, touch one lead to the dryer body and touch the other lead to the ground prong on the plug. The meter should show less than 10 ohms of resistance.
References
Sep 12, 2014 | Dryers
I have a Gibson dryer..It has a three prong plug
  • Screwdriver
  • Pliers
  • Drill
  • Ground screw
  • 4-prong pigtail
Tip
How to adjut the carb
This is tricky because it's one of those hands on things to show & hear. Most homeowners get this wrong and either the saw runs to rich or too lean(real danger). On the high speed jet, you turn it IN until the saw seems to scream uncontrollably(just for a few secs!) and then back the screw out until it starts to 'four stoke'....which means its cutting out slightly. On the low speed jet, you adjust right at the point where blipping the throttle trigger gives you fastest response. But if turning IN the low speed jet is raising your idle significantly, then you've gone too far.
If you've got the high speed jet set correctly, it will four stoke until you bury the bar and then smooth out perfectly under load.
Jun 18, 2013 | Poulan 16in. 35 Cc Chainsaw 952802144
I am changing out the wiring from a 3 wire to a four wire. The terminal block has (top to bottom) black, whiteandblue wires. The new 4 prong wiring has a white black green and red wire... what goes where...
The black,red & blue wires are your hot (120 volt) wires. Two of them get conn. to the two brass colored screws. The white is the neutral wire which conn. to the siver screw. The green wire is the ground wire conn. to the green screw which is the grounding screw.
Oct 06, 2009 | Dryers
8n ford runs smooth but lacks power and rpms
2 things it can be main jet dirty or float level low,pull your main jet out and clean with carb cleaner screw it back i untill it bottoms out back out 1 turn and 1/2
Aug 05, 2009 | Ford Garden
How to remove idle jet? I need to check the size of my idle jet and if necessary change it as bike stalls when rolling on throttle from idle, adjusted idle speed and idle mix but stalling and carb spit...
The idle jet is located in the bottom of the car. it's the recessed one in the bottom of the body. Remove your air cleaner assembly. remove the four screws. Be careful because it will be full of gas. ( well vented area.) You'll have one jet sticking out. That's your main. right next to it is a recessed jet . That is your idle. you'll have to use a small flathead screw driver to get it out. Make sure you have god pressure on the jet to break it loose. The jet itself is brass, and you don't want to mess it up. You should probably have a 45 jet with your combo. if you've been messing with the mixture screw it should be set around 1 & 1/2 turns out from lightly seated.
Jun 26, 2009 | 2006 Harley Davidson XL 1200 C Sportster...
Main menu / positioning /
Sounds like a button is sticking. Does it seem too sensitive? It should give a little resistance when pressed and have about 0.1" of travel. Try gently prying outward on the offending button with a pin or needle. If you're comfortable taking the monitor apart, do so and check the alignment of the menu buttons.
Oct 03, 2007 | Dell E151FP 15" Flat Panel LCD Monitor
My phone displays 'unable to charge' or no battery icon?
I plugged my phone up and all of a sudden got the message "Unable to charge" on it. I changed chargers (i had an extra one), i changed batteries (i had an extra one), and i swapped every combination imaginable.
My solution....
My Razr's plug has an opening to plug the phone that resembles a person's navel, and it got dirt and dust bunnies in it while it was in and out of my pockets. I was able to take an old tooth brush (or your new one if your really desperate), and got a can of office duster that you use to clean keyboards. Turn the can of office duster upside down for a second while you are spraying it and liquid will come out as you are spraying the connector. Immediately after that, use your toothbrush to work it inside the dirty connector to free it from anything that will keep it from making good contact. Then, hold the can of office duster upright and it will only spray air... and blow the connector free of anything that you loosened with the brush. Repeat this process if after all this it still doesn't work... because you have a REALLY REALLY dirty connector if it doesn't work after the first try.
Dec 28, 2006 | Motorola Mobility RAZR V3
KitchenAid 24 in. KUDP02FR Built-in Dishwasher Logo
59 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
