Question about Toshiba 65H82 65" Rear Projection Television
I have a toshiba 65H82 tv i need to move to my new house. can i lay it down or does it have to be upright?
    President:
  • Toshiba Master
  • 1,779 Answers
It's always best to transport upright. They are not shipped at anytime from the factory laying down.
Posted on Sep 08, 2010
  • Toshiba Master
  • 8,457 Answers
Move it upright best for the tv.These tvs have chemicals in it three CRT tubes colors guns.
Toshiba 65h82 has sound but no picture, what are likely causes?
Most likely you have a high voltage failure. This TV has 3 CRTs that are driven by high voltage. If one tube fails it shuts them all down. If the HV circuit has failed it may be time for a new TV
Feb 17, 2015 | Toshiba Televison & Video
I have a Sony Wega KP-FX432M91 Prjection TV. I am moving house and I want to know if I can lay the TV flat on it's back to move as it's too tall to stand upright in our vehicle
Please do not lay tv on its back because of its internal design, things are mounted inside vertically and screws are holding them in place. Laying tv on back will put force on screws that might came off or get loose and you will end up with a distorted picture on tv screen.
Move tv in stand upright position, it is safe.
Hope this will help.
Thanks.
Mar 25, 2011 | Sony KP-FX532M91 TV
Refrigerator was unplugged for a week. We moved it from one house to another and plugged it in and it's not turning on. The light is on but motor isn't starting. Any Ideas?
ck power at new house ( the plug ) do the lights come on in frig ? if so look for wires under frig that may have been puled off during move .. this should not be a tuff one . / the frig should not been damaged by beeing off . did you lay it down dueing the move ( it chould have been kept upright .. as laying down causes the oil to ru up in the cold coil .) hope this hepls mm
Oct 24, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I just set up my Frigidaire upright Freezer, only
Rule of thumb, if you lay a frig/freezer on side let sit upright at new location for 24 hours before plugging it in.
Mar 07, 2010 | Freezers
Moved fridg to new house pluged it in dosen,t get coled at all!!!
If you had to lay the fridge down to move it? Then you have to let it stand upright for at least 24 hours before you can plug it in and use it or it won't cool, as oil will get into the coolant lines and foul the works.
If you didn't have to lay it down, then check for a switch and or harness under the front grill that may have got bumped out of adjustment of knocked the plug off.
I hope this helps you, and good luck.
Sep 16, 2009 | Maytag MBB2256GES Bottom Freezer...
Moving a Kenmore upright freezer
there would be a problem if you lay it down. it should be moved up right or max 45 degrees tilt only. oil in the compressor could go to the evaporator and clog it.
front handles could be remove only from the inside. you have to remove the plastic rack of the door and remove the insulation in order to see the bolt holding the handle.
tnx 4 using fixya,
drcool
Oct 08, 2008 | Kenmore Freezers
TOSHIBA 65H82
you need to replace your 2-convergence ic's #STK392-110 you need to replace both ,,they are attached to 2 big heat sinks and identified as q-751 & q-752 you can get the ic's you need plus free tec support and installation instructions including pictures at the link I gave you.
http://servicemanuals.vstore.ca/
Apr 12, 2008 | Toshiba 65H82 65" Rear Projection...
Toshiba 65H82 65" Rear Projection Television Logo
231 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
