Error in c:\windows\system32\spool\drivers\w32x86\3\lxcitime.dll missing entry:rundllentry
  • 83 Answers
It is related to a Lexmark Printer. Try reinstalling the driver for the printer and see if it works.
Hope this helps!
Posted on Sep 08, 2010
Error in C:\WINDOWS\System32\spool\DRIVER\w32x86\3\LXCItime.dll Missing entry:RunDLLEntry
Looks like you will need to re-install the driver for your printer model. Good luck.
Oct 26, 2013 | Dell Photo 964 All-In-One InkJet Printer
What does this message on my pc mean?Error in c: windows \ system32 \ spool\ drivers \ w32x86\3\dlcd time. Dll missing entry: run dll entry
Time.dll was probably installed along with some software that came with the HP printer.
As time.dll is shared with other applications HP may have removed it during the uninstalling process and either some oter application is looking for it or a command to open it has been left behind.
As you say the Dell printer is working well so have alook in your StartUp folder (Documents and Settings/User/Start Menu/Programs?StartUp) and delete any reference to that file of HP Printer.
Also look under StartUp by Clicking Start > Run and typing msconfig and uncheck andy reference to HP or the file.
If it turns out another pallication needs the file then reinstall that application.
Jan 29, 2012 | Dell Computers & Internet
RunDLLEntry@16
LXCGtime.dll is a module installed with the spooling drivers for Lexmark printers. This is required for your printer to work properly and should not be disabled. You may need to re-install the Lexmark printer driver hope this helps
Mar 25, 2010 | HP Pavilion dv6000z Notebook
Errors
solution 1>
CAUSE:
Certain HP services (and associated DLL files) were somehow partially/improperly installed. (Possibly, from a previous failed install?)
The Windows services (files) were:
Pml Driver HPZ12 (C:\Windows\System32\HPZipm12.dll)
Net Driver HPZ12 (C:\Windows\System32\HPZinw12.dll)
The existence of these 2 files in the System32 directory was causing this error in my situation. Somehow, the installation script was not identifying that these files were already installed (or improperly installed) and failing to properly set them to be installed again.
SOLUTION:
Steps:
1) Check to make sure that the 2 Windows services above are not running (or not installed).
2) Rename/delete the 2 associated service DLL files (this will only be possible once the services are stopped)
3) Run the installation again.
solution 2>
complete uninstall printer software from computer.
run uninstall L1 L2 L3 L4(if not an hp computer).
run same uninstall l1l2l3l4 from 7z..folder or hp folder from temp if availalbe.
then clean from add remove programs/program and features.
then clean from cleanup utility all hp pritner related entries.
then clean temp folder. clean recycle bin.
delete c:\program files\hp and hewlett packard folders (if not an hp computer). on hp computer delete digital imaging bin folders.
delete following folders from following locations-
C:\windows\System32\Spool\Printers and deleted entries inside it
C:\windows\System32\Spool\drivers\w32x86\*.* deleted entries inside it
C:\windows\twain_32.
cleanup from regsitry--
plz make back up for registry first.
>> hklm/system/current control set/control/print/environment/windowsNT(x86/64)/drivers + processors delete all pritner entries from there.
>> hklm/system/current control set/enum/usb/vid_000,vid_003 delete.
>> hklm/system/current control set/enum/usbprint delete pritner entries.
>> hklm/system/current control set/control/print/monitors/hp standard tcp/ip ports/ports.
>> hklm/system/current control set/control/print/monitors/standard tcp/ip ports/ports.
>> delete same ports from printers and faxes/pritners pritner properties ports
>> hklm/system/current control set/control/print/monitors/hpz..
>> hklm/system/current control set/control/print/providers/lan man settings.
>> hklm/SYSTEM/CURRENTCONTROLSET/CONTROL/PRINt/PRINTERS
>> hkey_Current_User\Software\Hewlett-Packard
>> hKey_Local_Machine\Software\Hewlett-Packard
>> HKEY_USERS\.DEFAULT\Software\Hewlett-Packard
>> hkey_current_user\software\hewlett packard delete if not hp computer.
>> hkey_curent_configuration/system/current control set/control/print/pritners.
then go to msconfig
make it selective startup disable all microsoft services except hp services. hide all microsoft services. disable all startup tab apply restart.
after restart install cue version 12 officejet pro 8500 or 6500.
then run msiexec.exe /unregister then msiexec.exe /regserver cmd commands.
then install software from downloaded version of original pritner install only basic drivers first and imaging devices only and use solution center 12. cue 12.
issue resolved.
Nov 02, 2009 | Computers & Internet
J6480 fatal error 2753 MSI.dot4wrp during full driver install. I tried uninstalling al related hp drivers, all the HP advice. Disabled firewall, services etc. Do you have a solution that works?
you can try with installing the windows installer 4.5 and then try.. otherwise reinstalling windows might work because the error you are getting is related to installer.. and its a service of windows itself which is responsible for all the software installation..
Oct 29, 2009 | HP DeskJet 648c InkJet Printer
Error Code: 2753 " Fatal Error or error MSI.dot4msi"
CAUSE:
SOLUTION:
Steps:
solution 2>
then go to msconfig
issue resolved.
Jun 19, 2009 | HP LaserJet 3055 All-In-One Printer
Install missing dll file
Dear
If u have missing .dll file (download from web)
copy .dll file to c:\windows\system32
go to run and type (if ur dll file is abc.dll)
regsvr32 abc.dll
and press enter n ok
Oct 19, 2008 | Computers & Internet
When ever I reboot,turn on or bring my pc out of hibernation I get the below error message from my printer:
Uninstall the printer driver...and reinstall it...else the you have to reinstall the OS
PLEASE don't forget to RATE ME (FIXYA) for my help..........
Aug 14, 2008 | Lexmark X2470 All-In-One InkJet Printer
Computers & Internet Logo
728 people viewed this question
David Payne
David Payne
