Question about KitchenAid Refrigerators
It appears I need a new seal on my KitchenAid Refrigertor freezer Model # KBRA20ERBL01. How or where do I get one?
  • KitchenAid Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Sep 11, 2010
Kfcs22evms ice under freezer door and water leaks out onto floor
Check for a clogged drain line at he bottom rear.
Oct 30, 2017 | Refrigerators
The freezer door jamb on Kitchenaid side by side model KSRF26DSA1Y0 is cracked and the freezer door is covered in frost and ice and not sealing. What is best way to fix?
If the casing is cracked its best to seal the crack with clear 100% silicone. You can get it at any hardware store. Fill the crack and then put clear tape over it so it does not stick to your door. You can also just lay a clear plastic bag across it and shut the door let it set for 8 hrs. good luck
Aug 12, 2010 | KitchenAid Refrigerators
On the KitchenAid Model KSSC42QTS, the small door on the ice-maker dispensor that seals off the freezer is loose. It does not appear to be broken, but is loose in the compartment. Does the dispenser need...
do not reattach the old door but replace the door with a new seal . some of these units had poor door closure when new . the new door is better . and you will have dissamble unit to install door .
Aug 11, 2010 | KitchenAid Model: KSSC42QTS
I have a Kitchen Aid Md# KBLA20ERSS The
Lack of airflow up to the refrigerator. could be a defrost problem, a fan motor not running, a damper staying closed, a food obstruction, or something else altogether.
May 09, 2010 | KitchenAid (KBLA22ER) Bottom Freezer...
Can't find the model number - our fridge is old; about 20 yrs. Freezer door won't seal so cold air leaks, ice forms, water drips at the door handle. My husband tried beefing up the magnets, but that...
model on that vintage very well might be behind the bottom lover vents. remove vent screws and kick plate vent. look for a piece of paper in a taped on envelope. also sometimes on a sticker on the back of the unit.
hope this helps you.
Jan 24, 2018 | KitchenAid KTRS19KKSS Top Freezer...
Refrigertor run alot
check to see if you have frost build up on rear wall of freezer section. you could possibly be low on freon
Jun 21, 2009 | Kenmore Refrigerators
Fridge freezer double door top fridge bottom freezer
Things to check
Check freezer...
for Frost build up and if Fan is blowing,
Check condenser...
To make sure clean, and the fan is blowing by compressor & IF it is running
Check Recirclating Vents in refrigerator... to make sure theres no blockage,
CONTROLS ...should be in the middle setting,
YOU CAN TRY turning FREEZER CONTROL
To A WARMER FREEZER SETTING
Allowing.. MORE AIR.. to refrigertor side
Oct 24, 2007 | KitchenAid Superba KSCS23IN Side by Side...
Fridge does not get cold
If your getting frost build up in the freezer..u said u tried defrosting... is frost building up it freezer?
IF so you have a defrost problem...bad  heaters, defrost themostat or defrost timmer, if ya need more help post more info
Things to check
Check freezer...
Check condenser...
Oct 23, 2007 | KitchenAid Superba KSCS23IN Side by Side...
Refrigerators Logo
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
