Question about Saeco Vienna De Luxe Espresso Machine
After 10 years of reliable service, I need to replace the pump of my Saeco Vienna Deluxe. After removing the top of the machine, it seems that the entire "guts" of the unit are mounted on a vertical board which slides down into the plastic exterior case. But I can't seem to find how to slide all this up out of the case. It seems to be held down by something near the grinder. Is there a hidden screw or catch?
  • 1,089 Answers
Hi
There is a screw n top by the steam valve. Then lay the machiine on its back. In the middle on the right side by the power cord there are 2 openings. Insert a flat blade screw driver into the closest one to the center and push towards the top of the machine and it will unlock the guts. Move the power cord to complete the process.
Posted on Sep 09, 2010
There are two plastics holders at the bottom.
You need to move a side ( you can use a small screwdriver)
Posted on Nov 14, 2010
Saeco Vienna Deluxe leaking problem and grinder problem
I would repair it, it sounds like the grinder needs to be adjusted (burrs may be dull), and the leak on the bottom may be coming from the small drain hole on the back of the brew chamber. If you remo;ve the chamber you will see the white water valve that the chamber connect to, if you look below the white valve the small chamber in there will be filled with water, below that there is a small discharge use a stit stick or paper clip to clear hole.
May 07, 2009 | Saeco Vienna De Luxe Espresso Machine
Stuck on ventilate
Try this, open steam wand, if it calls for ventilate pusi in steam knob, if that works then the tap rod on the steam valve needs to be replaced. To me it sounds like the machine is building up pressure and the discharge is not releasing through the water circuit.
Apr 26, 2009 | Saeco Vienna De Luxe Espresso Machine
Low water pressure
i had the same problem the brew unit was block from many shot remove the little tube on top of brew unit be carefull after removing the 2 screw there a spring under the tube and glass ball clean it good
Apr 09, 2009 | Saeco Vienna Deluxe
Saeco Vienna Deluxe not hot enough
Hi
They should have checked the temperature before shipping it out. There is a sensor on the back of the boiler that has (depending on how old the machine is) 2 orange wires. In the wire or on the wire is a resistor. You can remove the resistor and raise the temperature about 6 to 12 degrees, but I think you need a new sensor.
Jan 27, 2009 | Saeco Vienna De Luxe Espresso Machine
How do I get the steam to work?
If it will make coffee then you have a horse shoe boiler blockage or a steam valve blockage.
Try descaling first. If this does not work you will have to disassemble machine and trace the water lines back from the steam wand to the high pressure pump to detrmine where the blockage is. This can be trickey and is best left to someone with experience with this type of fix.
Contact saeco in Vancouver.
Jan 06, 2009 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna Deluxe
http://cerinicoffee.com/Saeco_User_manuals_free.asp
Apr 26, 2008 | Saeco Vienna Deluxe
Saeco Vienna Deluxe odd burning smell
gears are probably broke. Happens when to much coffee and coffee ground too fine get compacted into the brew drive unit.
Shreds the plastic gears like butter.
Machine has to be sent out for service, gear replacement is long and impossible for anyone untrained. Trained techs it takes at least an hour if not more.
Apr 21, 2008 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna De Luxe Espresso Machine Logo
238 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
