Question about Konica Minolta bizhub C250 All-In-One Laser Printer
Konica minolta bizhub c353 replaced fusion unit, and still have the error code, it will not reset
  • pettry Sep 08, 2010
    We did that and it still has the same code, tried several times.
    Sorry that is the code, it's been giving that, we changed the part and did the reset, but it will not reset..:(
  • 1,110 Answers
You did not mention the specific code. But if it is a fuser warm up failure code such as C3421 or similar you must use the proper reset procedure for the code.
Here is the procedure. If it does not work for you then reply with the code/indication you have and I will address it.
1. Turn OFF the main power switch.
2. Turn main power switch on WHILE pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
Posted on Sep 08, 2010
  • 5 more comments
  • Edwin Martens
    Edwin Martens Sep 08, 2010
    I don't see where you have listed any code? Unless you are referring to the one I wrote. So what specific code or message is displayed that you are trying to reset?
    code c3421, but we replaced the part and tried to reset.
  • Edwin Martens
    Then the reset I posted is the reset procedure. If it will not work then there are 2 possibilities. 1 is you are not doing it correctly or 2 the fuser you installed is bad.
    Are you very sure you got to the "trouble reset" box on the screen, touched that box then got the OK indication on the screen? If so did you then turn off the MAIN power switch for at least 10 seconds then power back on? The MAIN power switch is NOT the one on the operation panel, that is the stand by power switch.
    Let's check these issues and see where we get.
  • pettry Sep 16, 2010
    tech came out and said unit was bad no power to unit, we ordered new one, and it is the doing the same thing.
  • Edwin Martens
    Edwin Martens Sep 16, 2010
    Apparently the tech was wrong or you got a bad unit. The reset procedure should be working. I take it that the code does go away initially and you get the initial copier warm up screen but then the code comes back? If so then the tech needs to come back and determine what the real issue is.
    Good Luck
  • amy r Oct 21, 2011
    Will doing this delete the contact emails on the actual printer?
  • Edwin Martens
    Edwin Martens Oct 26, 2011
    Amy,
    Performing this reset will not effect any emails, fax or scanning information you have stored. It simply clears the fuser error condition.
My konica minolta c353 the screen is not displaying
See if you can get a new control panel.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jan 26, 2016 | Konica Minolta Konica Bizhub C353 Drum...
Error C2557 Konica Minolta bizhub c353
Replace the black image unit or take unit out and shake the the unit to spead the developer along the entire length of the image unit. also ensure properly seated.
Jun 17, 2014 | Konica Minolta bizhub C250 All-In-One...
After replaced transfer belt unit its error 2152
Open close front door. to reset. Ensure belt was install properly the code is for that device also check the transfer roller sponge one. ensure shipping parts remove before installation.
Jan 31, 2014 | Konica Minolta Konica Bizhub C353 Drum...
I just replaced new transfer belt assymbly then error 2152 appeared
Sir, Open close front door. to reset. Ensure belt was install properly the code is for that device also check the transfer roller sponge one. ensure shipping parts remove before installation.
KONICA MINOLTA C353 ERROR CODE C-5102
hi tracey, 5102 is a main motor failure, it is possible for there to be paper jammed tight in the fuser unit, if not this will pretty much be guaranteed to be the main motor
Nov 11, 2013 | Konica Minolta Bizhub C353 Copier
I have a trouble code C-3727 showing on my photocopier konica minolta bizhub C353. What does that mean?
C-0F36 on the bizhub C350 means the machine has registered a really low toner density in the Black
Imaging Unit. I'd take the unit out, give it a shake and pop it back in. Also worth checking you have some Black Toner in it.Or in case You Still Having Konica Printer Problem Then Follow Us For On: Konica Printer Support
Oct 06, 2013 | Konica Minolta Konica Bizhub C353 Drum...
"konica minolta bizhub c353 error code c-4154"
"konica minolta bizhub c353 error code c-4154" help
change the chip and the imaging unit and still the same
what else I can do ??
help me please?
Thank you ...
Mar 09, 2013 | Konica Minolta Office Equipment & Supplies
How to clear error code c 3421 on konica bizhub c353
While holding down the utility/counter button and turning on the machine go to screen that say trouble reset press it says OK that power off and turn on again if comes back need a fusing unit.
Mar 13, 2012 | Konica Minolta Konica Bizhub C353 Drum...
I have problerm with konica minolta c353 .. the error code c4554 showing on display. i cant printing....
this is an easy fix, have you had your fuser replaced recently?? if so then it needs reseated or just do a trouble reset. ask me if you need help with that
Dec 19, 2010 | Konica Minolta Konica Bizhub C353 Drum...
Konica Minolta C353 has a C4551 error, how do I fix it?
try replacing the imaging unit with a new one not a reset imaging unit
Mar 10, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
492 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
