Question about ViewSonic Computers & Internet
Hi I own a VG2230VM mod VS11422 that went blank (black screen) all of the sudden, PC is OK tested on two different monitors, on the viewsonic, at POST a faint flash can be detected, that all, what's wrong with a otherwise fine product? advise
  • 11,361 Answers
Look for bad caps as shown in the pictures, they (as marked by red color by me) should be replaced in a set since bad caps can look normal without bulging tops.
http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VG2230WM/
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Posted on Sep 09, 2010
I have a gateway FPD2485W tft lcd monitor and i start my monitor and after it shows gateway it then goes black. How can this be fixed
bonannorl, Maybe it can be fixed. You did not give any history of unit. Only "now" stuff. Is unit covered by Gateway warranty? How old is unit? Date of manufacture? Did unit work fine connected to your pc and this black or black n blank screen thing suddenly happen? Is screen also BLANK? Have you swapped-in old monitor to prove PC is OK? Your CCFL back-lit lcd monitor no different than any other brand in it's basic design and operation. Get into my fixya profile and read some of my testimonials and solutions to black or black n blank screen problems to help in your decision to DIY fix or contract out needed repair work. Most likely 2485w has problem with it's internal "switch-mode-power-supply"/"ccfl inverter supply"!! Let me know more info about unit.
12fixlouie on fixya.
Mar 09, 2010 | Gateway Computers & Internet
Viewsonic monitor -- VX2235wm LCD
avintagedish, Possible problem w/unit power supply. Go trade it in on new a new wide screen so the electronics technician in the repair area of the store can (with a little luck) put less than $10 in parts into your unit and maybe have a nice VX2235WM to give to his 10 year old kid to play games on. I sure hope you have a valid warranty!! You should verify that VX2235WM does same at KNOWN GOOD pc!!! Swap-in a KNOWN GOOD monitor to prove pc is OK!!! Read my FIXYA profile and learn "flashlight test" for "rude an crude" test of "switch-mode-power-supply" status. Follow the links you find there to other web sites for more info. Check to see if ViewSonic has a cash+old swapout for factory refurbished unit for premature failed units! I'm lmistyrel over on aim. and 12fixlouie on FIXYA good luck in your quest to fix unit. It can be fixed. Just do your research FIRST! So you don't get ROOKED if you contract out the work. Read, read, and read some more!! Visit YOUTUBE for video clips of LCD monitor repair and disassembly. FYI.
Bye for now.
Feb 05, 2010 | ViewSonic VX2235WM Monitor
Abrupt loss of signal to monitor.
May be your Video card. Try a different monitor to see if it is working. If not you may need a new video card.
Nov 15, 2009 | E-Machines eMachines Desktop PC
Blank (dark) notebook screen after hooking up digital ext monitor
I notice a difference in the setup of the two monitors, have you installed the correct driver for the new screen?
Try F8 on startup to get into safe mode, this should allow you to use the default VGA screen, and to reset the correct monitor drivers.
Dec 08, 2008 | Sony VAIO VGN-A790 Notebook
About a problem in my viewsonic monitor
Hi
Actually the common problem of viewsonic LCD monitor is bad electrolytic capacitor at primary, secondary & inverter area, if your lcd using power adaptor test the voltage out, use analog or digital tester range 50v dc, if the voltage out is accurate dont be sure to your adaptor working good, open it and find bad electrolytic capacitor inside. That is common problem of viewsonic LCD monitor could cause of display flashing then back to black after few seconds. Suspect inverter area lastly mainboard.
Gud Luck!
Oct 06, 2008 | ViewSonic VE710s  (Black, Metallic...
Monitor blank
try to start your pc in safemode with vga mode with thjis faulty monitor
hope you know how to do it
start pc (powerr on)
then continuously press F8 key then it will show you boot menu
select safemode with command prompt
then if it show desktop on screen this means your monitor is having problem with resolution try to downgrade your monitor's resolution
rightclik on desktopgo to properties
select settings
here you can find screen resolution make it to 800X 600 just for one time
then restart your pc it will auto select proper screen resolution
Mar 29, 2008 | Dell E173FP (Black) (Dark Gray) 17" LCD...
No Display.
the problem is seem to be in your moniter vedio driver ic which is present inside the moniter it is programmable ic, it may get heated or corrupted so pls check your moniter
the service manuals are available at eservice.com
Mar 18, 2008 | ViewSonic VA2012WB Monitor
Vx900 viewsonic monitor problem . Blank screen except for power off/on
no, Viewsonic has the part for sale 42.99 - free shipping. Easy to replace
May 25, 2007 | ViewSonic VX900 19" Flat Panel LCD Monitor
Computers & Internet Logo
275 people viewed this question
Top ViewSonic Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
