Question about Saeco Classico Espresso Machine
My machine won't do anything when it's turned on. It blows the fuse in the kitchen every time. I looked in the back and nothing appears to be grossly burnt or destroyed. Any suggestions? I'm a mess without my coffee!!!!!
    President:
  • 1,618 Answers
It is possible that the boiler over heated and blew the element, disconnect one of the legs and turn machine on, if it trips breaker, then replace element.
Posted on Sep 12, 2010
Simpson espirit 750 won't turn on
Hi, This may sound obvious, but have you checked the fuse? if the machine is completly dead this may be the problem or the ON/OFF switch is faulty. If there is life in the machine the problem could be the door switch. If the fuse has blown then there could be a fault such as heater element blown, is the most common to blow a fuse.
May 04, 2012 | Simpson Esprit 750 Top Load 7.5kg
I have a 91 olds supreme 3.1 v6 it shut off and won't start back .... It starts but won't turn over.... And when turn the key back off it's blows the dis fuse wich mean direct ignition system...
Check the coils that have been replace for bent or broken prongs that plug into the ignition control module and if nothing looks damaged then i would think the ignition control module is faulty.Replace ignition control module.
Jan 21, 2012 | 1991 Oldsmobile Cutlass Supreme
Have f11 fault tried to reset and machine starts up, turns a few times, then gives a strange noise then f11 appears and pump starts draining, had f11 few years back and was fuse but remember at this time...
sounds like you've either got a stiff motor or gunk in the drum making it difficult for the motor to turn. When the fuse blows the drum won't turn at all but as yours is trying to turn then throwing the fault up it sounds like something is causing too much resistance
Aug 26, 2011 | Dyson Flowcheck CRO1 Front Load Washer
2003 Silverado Z71. Has had nothing wrong with it. Drove it fine all day. When I parked it and turned it off I thought I hear a pop sound, sorta like when a fuse blows..now there is nothing..it's...
Something is shorted, large amp fuses do not just blow. Go under the hood to the big black box marked FUSES. You are looking for the blown main ALT or BAT fuse, but you must find out why it has blown.
Make sure nothing has shorted out your positive battery cable, accessary wire, did you add anything to the electrical system that was not fused ?
Feb 04, 2010 | 2003 Chevrolet Silverado 1500
Maytag washer blows 1.5A fuse in back of the top compartment where the dial etc is
There is a micro switch next to the fuse. It is shorted out. Replace the micro switch and solve your problem.
May 20, 2009 | Maytag SAV571EEWW Washer
No power running to SERVIS washing machine
Try disconnecting the heater element first and see what happens if still same unplug motor and try again, it is a process of elimination.
Plz rate solution.
Thanks.
Dec 14, 2008 | GE WPXH214A Front Load Washer
Need to reset model LHW0050PQ4
Try to unplug the washer for 15 minutes and then the control board should reset.
Nov 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Oven fuse blows - Nothing works
try lifting the stove top assy and checking wires under main top, leading to the elements them selves??? if tis tripping and not allowing to reset its gotta be an obvious short. isit hard wired directly to stove or into a 220 cord and plug???id look again, perhaps remove entire back panel and have someone trip on the breaker you might see where it flashes as it trips off
Apr 03, 2008 | Tappan TEF242 Electric Kitchen Range
Saeco Classico Espresso Machine Logo
119 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
