Re whirlpool awm328 user manual. which is hot feed - left or right
I want to replace a current dual outlet with a combo switch outlet where the switch controls the outlet.
Based on what you said, your hot wire feeds the top left and the neutral connects to the bottom left. The two brass on the right should be connected to each other with a brass tab. If you look at it, you should be able to see it.
This is the way it works: hot feeds top left, when switch is turned on, hot goes through to the top right which also feeds bottom right. Now the outlet is powered.
If you are not sure, use a multi meter set on continuity and check from the top left to the bottom left while turning on the switch. Good luck!
Jan 28, 2017 | Electrical Supplies
Janome 3050 feed dogs wont come back up
Dropping the Feed Dog
The feed dog can be lowered with the drop-feed lever for sewing on buttons etc.
  • Shift the drop-feed lever to the right to lower the feed dog.
  • Shift the lever to the left to raise the feed dog, it will return to the up position when the machine is started.
NOTE:The feed dog should be in the up position for regular sewing. Turn the handwheel toward you to check if the feed dog comes up after setting the lever in the up position
JANOME DC 3050 User Manual Page 9
May 24, 2015 | Janome Sewing Machines
Where do I lower the feed dogs on the Viking Iris machine so I can machine quilt?
Check the user manual, page 15. You can view, download, or print the manual from the viking website -
http://www.manuals.husqvarnaviking.com
There is a dial on the bottom of the free arm in the middle. The dial should be turned to left to drop feed dogs and to right to raise feed dogs.
Jul 11, 2014 | Husqvarna Sewing Machines
Where to put washing detergent in Whirlpool AWM8121?
Simply place detergent into wash ball and place inside drum on top of clothes,,,,fabric softener goes in smallest compartment in tray
Jun 20, 2013 | Whirlpool Washing Machines
I have a leviton combination (2) switch... I want each switch to (naturally) operate (2) different lights - all (white) 4 neutrals are combo in a wire nut and feed is going to the right side top brass...
Don't break away the tab.
It sounds like you have Hot wire connected to wrong side of device.
Electricians don't guess, they test.
Separate wires. Turn power ON.
Test each wire to bare ground.
Tester lights up on Hot wire.
Hot connects to brass screw(s). This will feed power into each switch.
Wires going to Load (lights) connect to each silver screw.
Feb 19, 2011 | Leviton 002-1754-W Dual Rocker Switches
Hi the water goes from hot to cold and then hot again. The controls don't seem to correlate with what it dies. I am in a rented flat and have never used a shower like this before. No manual available.
sounds to me like the hot and cold water connections are connected on the wrong sides(hot should be left cold right) you should speak to the landlord
Dec 09, 2010 | Home
Have to replace the warmer switch on my bunn model b10-b
Looking at the back of the switch:
If you have an original style switch:
Black (hot) wire on left terminal
White wire on right terminal
3rd wire (color varies) middle terminal.
If you have a new style switch:
White wire on LOWER right terminal
3rd wire (color varies) UPPER right terminal.
See attached photo
Mar 02, 2010 | Retail Supplies
User manual whirlpoolfridge freezer 20rid3 sf i have lost user manual
Call Whirlpool. The number should be on model tag inside freshfood. Either upper right or upper left.
Sep 08, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Quilting on Janome MC 4000
I have a MC4000 and a manual. To raise or drop the feed dog, remove the accessory box and feel at the back of the free arm there is a lever that will slide left or right to raise or lower the feed dog. I am not a quilter, but the manual says to use foot A (zigzag foot) and accessory L (quilter) which appears to be a guide. Cheers, Deb, Townsville, Australia
Aug 16, 2008 | Janome Memory Craft 4000 Sewing Machine
Washing Machines Logo
180 people viewed this question
Top Washing Machines Experts
