Question about Roxio Easy Media Creator 10 Suite
Roxio easy creato 10.came with viao computer running windows 7.it will not detec my dvd-romm drive.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 184 Answers
Hi, I had no trouble using my Roxio 10 with windows 7 and my DVD drive. Make sure you have the latest drivers for Windows and your DVD drive. What worked with XP and Vista will not always work with Windows 7. See if your DVD drive manufacturer has an updated driver, or even try drivers from similar manufacturers. Sometime they share driver software. I hope you get it going. Thanks, Bill
Posted on Sep 08, 2010
Kim komando website
The only thing that you can try is installing it in compatibility mode.
Feb 22, 2014 | Microsoft Windows 7 Home Premium 64BIT...
Creater 7 will not record dvd or cds
If you are getting an error "No dvd/cd drive detected", you need to delete the roxio certificate.
Goto C:\program data\, find the roxio or sonic folder and delete it and restart the computer.
Regards,
Shrey
Jul 15, 2010 | Roxio Easy Media Creator 7
Keeps asking for blank dvd
check roxio configuration the check if it is using the right drive.
sometimes the burner programs try to burn discs in virtual drives.
Jun 02, 2010 | Roxio Easy Media Creator 7
DVDs I burn will not play on other players. Players reject disc
Check that the burner is finalizing the discs. This can be set in Roxio or in the optical drive properties. In Windows 7, right click on the optical drive, choose Properties, then the Recording tab. Then the Global settings lets you choose to finalize the disc on eject. Try a different brand of DVD+R and check that the other players support DVD+R discs. (I know some DVD players only support DVD-R.)
I hope this helps.
Apr 15, 2010 | Roxio Easy CD & DVD Burning
Roxio 9 compatibility with windows 7
Roxio 9, Roxio Creator 9 and Roxio Creator 10 are different animals. Roxio 9 is 3 years old +. It likely will not handle 64bit or Windows 7.
Roxio Creater 9 is not listed as compatible with Windows 7
The following are from the Roxio site:
The following products have been designed to be Window 7 compatible (as of January 2010):
  • Roxio Creator 2010
  • Roxio Creator 2010 Plus
  • Roxio Creator 2010 Special Edition
  • Roxio Creator 2010 PRO
  • Roxio Easy LP to MP3
  • Roxio Burn
  • Roxio CinePlayer BD
The following products have been UPDATED to be Windows 7 compatible (as of January 2010):
  • Roxio Easy VHS to DVD
  • Roxio MyDVD 10 Premier
  • Roxio My DVD Video Lab 10
  • Roxio RecordNow Music Lab 10 Premier
  • Roxio Easy DVD Copy 4 Premier
  • Roxio Easy CD & DVD Burning
  • Roxio BackOnTrack 3 Suite
  • Roxio CinePlayer
Apr 04, 2010 | Roxio Easy Media Creator 9 Suite (227100)...
Computer does not recognize the usb. Installed software, started to capture video, then it quit and hasn't worked since Roxio Easy VHS to DVD for Mac
I am not sure what your program has to do with your USB drive. what system are you running?. You may need to uninstall the USB port in device manager and restart your pc and let windows detect it.
Nov 03, 2009 | Roxio Easy Media Creator 7
dear custumer
the Roxio Easy that u are loading on your windows is a new version
so why it can not run on an old version on windows like yours
so try to replace your windows 2000 by the new version of it .
Oct 31, 2008 | Roxio Easy CD & DVD Burning
DVD RW - Installation Problem
Ok. What I am going to suggest may seem like a daunting task but if you are careful and do only what I suggest you should be ok. The first thing you are going to have to do is manually make a change to the Windows registry to fix the permissions. 1. Fix registry permissions a. Click on "Start" choose "Run", then type "regedit" and click "OK". b. In the Registry Editor, click on the "+" next to "HKEY_Local_Machine". c. Now click on the "+" next to "Software". d. Right-click on the key (folder) called "Roxio" and choose "Permissions". e. Make sure that "Administrators" and "System" have checkmarks for "Full Control" - "Allow". f. If you had to add those checkmarks, click on "Apply". g. Click on "Advanced". h. Put a checkmark in "Replace permission entries on all child objects with the entries shown here that apply to child objects". i. Click "OK". j. Click "OK" again. k. Now close the Registry Editor Next, you will have to uninstall the Roxio software. 1. Remove Roxio Easy Media Creator 7 a. Go to Start--->Settings--->Control Panel--->Add/Remove Programs b. Select Roxio Easy Media Creator 7 and select "Remove" c. Once the uninstall is complete, reboot the computer. 2. Reinstall Roxio Easy Media Creator 7 a. Insert the CD and install as you did before and then reboot. If you have any issues uninstalling the Roxio, go to the following link to download the Microsoft Cleanup Utility... http://support.microsoft.com/kb/290301 Run the utility after the unistallation attempt and then reboot and reinstall Roxio. Hope this helps. Good luck.
Jun 19, 2007 | LaCie 8x DVD+/-RW USB 2.0 External Dual...
Roxio Easy Media Creator 10 Suite Logo
111 people viewed this question
Top Roxio Computers & Internet Experts
Are you a Roxio Computer and Internet Expert? Answer questions, earn points and help others
