Question about AcerPower FV PC Desktop
What battery code do I need for my Acer Power FV Desktop PC to run the time and date clock?
  • Acer Master
  • 11,800 Answers
CR2032 - it's a 3 volt cell battery.
Posted on Sep 08, 2010
Testimonial: "Thanks for your help. I wanted to be sure what cell battery to ask for before visiting my local store. Thanks again."
    Scholar:
  • 100 Answers
Detailed instructions for use are in the User's Guide.
http://click here
hope it helps you..
Support acer,com
you can use ultimate boot disk which you can burn yourself
Mar 11, 2012 | Acer Power FV PC Desktop
Cpu fan running high speed for acer power fv 519 1gb ram, vista operating system,
i have acer power fv desktop win 7 1gb ram ,CPU fan running high speed
Jan 22, 2012 | AcerPower FV PC Desktop
Will not power up
You may need to replace the CMOS battery in your desktop but first:-
  • Check the power connections.
  • Disconnect power to the desktop.
  • Remove and re-fix the hard disk.
  • Remove the CMOS battery and connect power without it.
  • Now power it up.
  • Your desktop may run without the CMOS battery,[untill you replace] but you will be forced to re-set the date and time everytime you start it.
Hope this helps.Thanks!
Please rate this free answer.
Oct 18, 2011 | Acer Aspire™ T180 PC Desktop
I can't get acerpower fv sound driver from its cd after i format the desktop why?
It all depends on which type of CD you are using to get the drivers from. The Acer FV recovery discs, are meant to run recovery only and not store any user accessible files. However, I can recall that one of these CD's is a CD with the name "Acer Power FV Resource CD" which should actually contain the driver for the sound.
Please use following link to download the sound driver: Acer Power FV Sound Driver direct download
At this stage I will assume your OS to be Windows XP SP3, your Audio driver will be Realtec High Definition Audio.
If you have used a Windows XP CD to format the desktop as you've said, you need other drivers as well not just sound. Let me know if you need more drivers and I will find the links for you.
May 20, 2010 | AcerPower FV PC Desktop
I lose my clock and date settings whenever i switch off my Acerpower desktop pc
I think you need to change your cmos battery. The instructions recommend an anti static wrist strap, It is the correct way but i have changed without but that was my choice.a very common battery is A coin-cell battery (CR2032)
To replace the CMOS battery, follow these steps:
Electrostatic discharge (ESD) can damage components. Perform the procedures described here only at an ESD workstation using an antistatic wrist strap and a conductive foam pad. If such a station is not available, you can provide some ESD protection by wearing an antistatic wrist strap and attaching it to a metal part of the computer chassis.
Turn off all peripheral devices connected to the computer. Disconnect the computer's power cord from the ac power source (wall outlet or power adapter).
Remove the computer cover.
Locate the battery on the board.
With a medium flat-bladed screwdriver, gently pry the battery free from its connector. Note the orientation of the "+" and "-" on the battery.
Install the new battery in the connector, orienting the "+" and "-" correctly.
Replace the computer cover.
hope this helps please rate :)
Feb 05, 2010 | AcerPower FV PC Desktop
My Acer extensa4420-5963 has been acting funky for the last three/four days. Started out my date and time went haywire. Clock kept losing time as soon as laptop was turned off and reverted to battery. Then...
First of all the RTC (real time clock, BIOS/CMOS) battery has run out. This means the computer cannot keep the date and time when its turned off and disconnected from the mains. You will need to take the laptop to a reputable PC repair store and have them fit you a new CMOS battery.
As for the power on problem, this well could relate to the CMOS battery being drained but also could be a number of different reasons why it won't power on properly.
In my experience laptops that have problems powering on is either to do with the DC adapter on the laptop that has a dry solder point or the power board is failing.
Either way i would take the computer to be looked at.
Regards.
Jan 25, 2010 | Acer Computers & Internet
I turned off the power on my Acer Power 1000 desktop and now it won't turn back on. This has happened before but after leaving it overnight I could turn it back on. It's been 3 days now and I still can't...
You might want to run setup and see if that is way off. If so, replace the nickel cell battery on the motherboard. That saves the setup information, date and time etc. That goes, you never know. They only cost about $4
Nov 02, 2009 | Acer Power 1000 PC Desktop
I have a e system desktop the clock keeps running late
Computers have an internal battery on the motherboard that helpd the board retain certain data when the computer is off. If the battery is low or dead it will cause this problem. The easiest way to replace the battery is to open the side of the computer when it is off and remove the battery from the battery holder on the motherboard. The battery looks just like a watch battery. Replace it with the same kind of battery (available at most drug stores) once you have replaced it turn on your computer and reset your clock.
Dec 29, 2008 | E-Machines eMachines Desktop PC
AcerPower FV PC Desktop Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
