Question about Kenmore 60172 Electric Commercial Dryer
Hello- I have a Kenmore dryer #60952990 and the dryer turns but there is not heat. By reserarching other comments, I am assuming it is the heating element. So to be knowledgeable when the repairman comes tomorrow, what do these parts cost? How much time will it take to assess this problem and put in new parts? What other questions should I ask?
  • Kenmore Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Sep 10, 2010
Dryer works but timer doesn't move. I just replaced it and still having the same problem.
Kenmore 400 6942 Dryer Heat timer - Questions - Fixya
www.fixya.com > Forum > Dryers > Kenmore > Kenmore 400 6942 Dryer
Kenmore 400 6942 Dryer, heat timer related issues. ... The timer doesn't work. ... the heat turns back on the timer stops,heat shuts off the timer will move again,if the ... not heating/timer knob not turning . the dryer works but is not heating and i ...
kenmore 400 doesn't heat, and timer doesn't move, but dryer ...
www.shopyourway.com > Manage My Life > Questions
I understand your Kenmore 400 Dryer doesn't heat up or the timer doesn't move, butit tumbles sometimes. I found the manual for your Kenmore Dryer in ...
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ....and now the dryer won't heat and the timer doesn't advance, butthe motor still runs? .... Diagose a Whirlpool or Kenmore Dryerthat Keeps Running, Wont Shut ...
Dec 21, 2015 | Kenmore 400 6942 Dryer
My Kenmore elite electric dryer will not heat. I
Hi
Thanks for using FixYa. No Heat issue in an electric dryer is usually caused due to three things mainly: Thermal Fuse, Wiring Harness and/or Heating Element. Start with checking the Thermal Fuse which is mounted inside the back cover panel to the exhaust duct and is mounted in white plastic housing. If that’s fine then the Heating Element should be checked. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 03, 2010 | Kenmore Elite HE4 Electric Dryer
Dryer has no heat
Hi assuming that this is a gas dryer. you most likely have a bad ignitor. If this is and electric heat dryer you may have a bad heating element.
I hope this helps if you need further assistance please let me know.
Apr 13, 2010 | Kenmore 74652 Gas Dryer
Hello
You are sure the element heats up? Belt around drum tight? Drive motor getting power from relay
Mar 09, 2010 | Kenmore 63942 Dryer
Hello,my kenmore dryer wont heat. i am not sure where the fuess are? thank you mike
There are no fuses internal to the dryer, except for a thermal fuse located with the strip heating element.
Let's start with the basics, does the motor turn the drum but the unit just does not heat?
Is this a gas or electric dryer?
Please provide Make and Model number of the dryer.
Dec 18, 2009 | Kenmore Washing Machines
GAS DRYER WONT STAY HOT
Hello, This problem is going to be your safety valve coils...basically they get old and over time of heating then cooling develop a short when they heat up...It may appear the gas lights to start but then goes out until the safety valve coils cool back down. Here is a picture of the coils 57d5263.jpgThis The coils are mounted to the gas safety valve, This should solve your problem. Hope this helps, Please feel free to comment again if you have any further questions or concerns. Good Luck! Mike
Sep 18, 2009 | Kenmore 63942 Dryer
Dryer heats for 5 minutes then only blows cool air.
Hello, reading between the lines I'm going to assume you have a gas dryer. This problem is going to be your safety valve coils...basically they get old and over time of heating then cooling develop a short when they heat up...It may appear the gas lights to start but then goes out until the safety valve coils cool back down. Here is a picture of the coils 57d5263.jpgThis should solve your problem. Hope this helps, Please feel free to comment again if you have any further questions or concerns. Good Luck! Mike
Aug 17, 2009 | Kenmore 800 7982 Dryer
Dryer heats and works properly at first then won't keep a high enough heat to get the clothes dry in less than two hours.
Aug 14, 2009 | Kenmore Dryers
Dryer heat shuts off
Jul 24, 2009 | Whirlpool Dryers
Kenmore gas/electric dryer
theordis:
When you say electrical power is working Ok ,I would assume you are saying this because the dryer is tumbling.
Which could mean you are only getting 120 volts to the unit but it will not heat with out 240 volts.
If you are getting 240 volts.
You could have an open thermostat, an open heating element. A bad timer contact or a open switch on the motor.
All these can be tested with a Volt-Ohm meter.
((((The Electrical supply must be turned off and at least one wire dissonnected from the component being tested.
woodychoppers
Aug 13, 2008 | Kenmore 75944 Gas Dryer
Kenmore 60172 Electric Commercial Dryer Logo
61 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
