Question about LG 42LC2D 42 in. LCD HDTV
Hi Guys, I am working on an LG LCD tv mod # 37LB4D TV turns on, backlight lcd lights up,however there is no picture. Even menu list doesnot display. Any Solutions? thanks.
  • jiro Sep 08, 2010
    Hi Rylee,
    I have opened up back of this tv. I think the backlight boards are working fine since I can see the backlights lighting up as I turn the tv on , and turn off when the tv is off.
    Any other suggestions?
  • jiro Sep 11, 2010
    Thanks Rylee, I hope i can find the board easily.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Hope you already know that this cannot be corrected through the MENU options. To resolve this issue you'll have to open the back of the unit and check the inverter board which is the power supply source for the backlights. The issue can be a bad inverter board and/or the inverter board is not getting 20vdc from the power supply maybe due to the connector that has gone bad/loose.All this is only recommended to be done by someone who has electrical expertise and knows about the internal circuitry of the unit. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 08, 2010
  • Rylee Smith
    Rylee Smith Sep 09, 2010
    Check the T-con board
  • LG Master
  • 5,138 Answers
Ck power supply board for Bad Capacitors they will be vented,swollen or puffed up on Top 2200uf 10v 3300uf 10v 1000uf 16v
Posted on Sep 09, 2010
  • mannypacute Oct 15, 2010
    PRESS THE T.V AND SMASH IT WITH THE HAMMER!
    3x AND IF IT DOESN'T WORK..
    UNPLUG THE T.V AND PICK IT UP AND THROW IT OUTSIDE THE WINDOW!!
    AFTER THAT PICK IT UP AND PLUG IT..
    POST THE RESULT AND TAKE A VIDEO!
    IT REALLY WORKS!! :D
Samsung monitor 2232bw plus backlight fade in black backgrounds scenes
Most common failures in these LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply C242 470uF 10V, C241 & C242 1000uF 16V, C261 & C319 680uF 35V failed as indicated in the attached picture, replace them at once.
If the power supply board is working then it is back light problem, first do a flash light test. If you can see the image in the flash light test, follow the steps how to test back light voltages: https://how-to-repair.org/repair/lg-tv-repair-manual-pdf/lg-led-tv-no-backlights-32ln5300-32ln5310-32ln5700-voltage-test-troub/2pyuXwNkBMA.html and follow the steps how to repair back light LEDs: https://www.youtube.com/watch?v=_poWTEihIJU Fix Led Backlights for TV or Monitor Lg Led Tv No Backlights 32ln5300 32ln5310 32ln5700 Voltage Test Troub Lg... Fix Led Backlights for TV or Monitor
samsung-2033sw-2233sw-ip-43135a-bn4400124s-power-board-dfydxumns33ohqc3bsmt22yf-3-0.jpg
Nov 07, 2013 | Samsung SyncMaster 2233BW 22" LCD Monitor
No picture
Sounds like you have a backlight problem. To verify this, turn on the set, dim the lights in the room, and shine a bright flashlight on the screen. If you see a faint picture you have a backlight fault. It could be as simple as a bad capacitor in the power supply, or a faulty inverter board, or in rare cases a bad backlamp.
May 04, 2013 | LG 32LD350 32 in. LCD TV
LG LCD 37" GREEN STANDBY/POWER LIGHT FLASHES GREEN NINE TIMES
http://www.tvrepairkits.com/?gclid=CP-_rIXGgbICFUXHtAodv3QAUA Take a look Kolbrun
Aug 24, 2012 | LG Televison & Video
Hi I just bought a LG M2362D tv monitor and somehow the backlight level (feels like the backlight) will change to very dark automatically every 5 or 10 minutes then back on bright again in 1 minute does...
The tv have a long board that called the tv LCD inverter board,this tv LCD inverter board only job are to control and help the all the amount of the tv LCD screen panel backlight brightness for the tv LCD screen panel for light.This long LCD inverter is the causes and the problems.New tv exchange it for another one,not so new take ur tv warrenty repair qickly the tv long LCD inverter board it is the causes an the problems must have to be change.
Sep 13, 2011 | LG M2362D 23 in. LCD TV
PICTURE GOES OFF AFTER A FEW SECONDS. SOUND OF TV
have youtryehave you tried going to menu options and turning off the power save you might try changing the scart cable any interferance will cause the tv to turn of. my little boy often knocks the scart lead on my set an the tv turns itself off when he does this ,. hope this helps good luck
Dec 11, 2010 | LG 42LG30 42 in. LCD HDTV
My LG HD tv screen suddenly went green. sound is
I disagree with info provided, if screen of your LG lcd tv becomes green that means inverter board is working and lcd tv does not have convergence ICs.
Please unplug tv from ac wall socket for minute to get it reset, replug back in and turn it On and check its picture.
If still showing green screen then change input source with remote, if tv shows same green screen on all inputs that means its either lcd panel problem or digital signal processor got bad loacted on main board. Local tv repairman is needed to confirm and fix it.
Thanks.
Jul 21, 2010 | LG 42LC2D 42 in. LCD HDTV
My new LG LCD won't turn on
Take ur waurenty repair the tv is faulty.The LCD inverter board is shorted.Need it replaced,not lighting ur LCD backlight screen to get the picture.
May 01, 2010 | LG 47SL80 LCD TV
I have sound and backlight, but no display.
the t-con board need replacement( it is found on the top middle section of the lcd panel)
Apr 27, 2009 | ViewSonic N2635w 26 in. LCD Television
MY LG LCD TV PICTURE DIED
Hi...there,
Wow! You guys...must had watching a really....HOt sizzling movie to make it overheating. Hehehe...
Your inverter are fried, need to replaced a new one. If you still under warranties asked LG to send you a replacement. Have a nice weekend!
Oct 04, 2008 | LG Flatron L1710S 17" LCD Monitor
LG 42LC2D 42 in. LCD HDTV Logo
470 people viewed this question
Computer Repairing
Computer Repairing
