An open ended U-tube with a uniform cross section equal to 1 cm2 and height 100 cm on both sides is mounted on a stand in the lab. The tube is filled with mercury to a height of 50 cm on both sides when the barometric pressure in the lab is 750 Torr. The left side of the tube is then sealed and the right side is connected to a vacuum pump and evacuated to a pressure of essentially zero Torr. (a) What distance in cm does the mercury level fall from its original position on the left side of the tube? Hint: Set up and solve a quadratic equation. (b) What is the final pressure in Torr of the air trapped in the left side of the tube?
PartsCenter
  • 125 Answers
SOURCE: Kohler bathtub spa does not work at all
If the air tube is still connected to the air button on the side of the tub and you are pushing it with no results then either the motor is no good, the air button is no good or the air switch in the box is no good.
process of elimination, start with the pump. take the switch off the motor or out of the box and make sure you can get the motor to come on. If the motor comes on then move to the air switch and hook it back up and see if you can blow into the air switch with a new air button or a straw and see if the switch will activate the pump. if it does then you most likely have a bad air button ($12). If you cannot get it to activate the pump then the air switch is bad ($21).
Posted on Feb 24, 2009
  • 219 Answers
SOURCE: need to level my kenmore 25 cu side by side-don't have a manual
take of your front kickplate you see the leveling screws on either side
Posted on Mar 19, 2009
SOURCE: My Ti-89 won't factor a quadratic equation with imaginary roots.
(a-b)3
Posted on Apr 04, 2009
SOURCE: rear air suspension is not at level left is higher than the right
I have the exact same problem but my Left side is "Lower" than the right side.... Go Figure, Let's switch Solenoid's... Lol. I haven't seen a fix for this yet... there is 1 ride height sensor bolted to the rear but it's for both sides. the following site seems to be recommended by most Expo owners on all of the ford forums.. Check them out.
http://www.suncoreindustries.com/english-ford-expedition-97-02-air-suspension.html
Posted on Aug 01, 2009
nonontech
  • 4737 Answers
SOURCE: 2x2-3x+5=0 solving the quadratic equation
Here you are :
2X2-3x+5=0 => 4-3x+5=0; (2X2=4) => -3x+9=0; (4+5=9) => 9 = 3x; (-3x moved to the right-hand side and it became 3x) => 9/3=x; (3 moved to the right hand side, so it becomes 1/3, i.e 1/3X9= 9/3) i.e. x=9/3 => x=3
Hence x equals to 3.
You can add or remove the explanation/description, I simply add them to make you understand.
If you need help, let me know.
Good luck.
Thanks for using FixYa.
Posted on Oct 08, 2010
Can you help me i need a pump that will produce 1 GPM thru 250' x 1/2" tubing @ 10psi
You can convert pipe size to gallons per minute of flow by calculating the cross-sectional area of the pipe and making some reasonable assumptions about pipe volume and the rate of flow. Pipe sizing is measured by the internal diameter of the pipe, not the overall outside diameter. Once determined, the overall volume can be calculated. Pipe flow is described in gallons per minute. Shorter lengths of pipe will have a greater flow than a longer length of the same diameter. This is caused by internal resistance of the pipe itself. By the same reasoning a larger diameter pipe will have a greater flow or GPM than a smaller pipe at the same pressure or flow rate. Pressure is described as pounds per square inch. The square-inch measurement is determined by the area of the pipe. The pounds are the amount of force that is placed on the liquid to push it through the enclosed space.With that background, you can estimate the flow based on the pipe size.
Find the cross-section area of the pipe. Area is equal to pi times the radius squared or a = 3.14 x r2. A two-inch diameter pipe would have a cross-section area of 3.14 x 12 or 3.14 square inches.
Understand that water has a certain pressure associated with the height of that water. One pound of water pressure, or 1 PSI, is equal to 2.31 feet of elevation in height. In other words, a 1-inch column or pipe of water that is 2.31 feet high will have a pressure of 1 PSI. The overall height -- not volume -- of the pipe corresponds to the pressure. A 6-inch diameter pipe that is 2.31 feet high will only have 1 PSI.
Find the volume of the 2-inch diameter pipe in Step 1 that has a length of 10 feet. Ten feet is equal to 120 inches. Multiply 3.14 square inches, the cross sectional area, times the length. The volume of the pipe is equal to 376.8 cubic inches of volume.
Convert cubic inches into cubic feet. One cubic foot equals 1,728 cubic inches. Divide 376.8 cubic inches by 1,728 cubic inches per cubic foot and the answer is .218 cubic feet. This means that the 2-inch diameter pipe that is 10 feet long has an internal volume of .218 cubic feet.
Calculate the amount of water that can be contained in the section of pipe at any given time. One cubic foot of water is equal to 7.48 gallons. Multiply 7.48 gallons by .218 cubic feet and the amount of water in the pipe is equal to 1.63 gallons.
Find the GPM if the flow of water is one foot per second. Multiply the one-foot per second flow by 60 seconds per minute and the flow is now 60 feet per minute. In other words the water will flow through the 10-foot pipe six full volumes for every minute. Since the piping contains 1.63 gallons per 10 feet of pipe, multiply 1.63 by six and the final GPM is equal to 9.78 GPM of water flow from the 2-inch diameter pipe.
Jan 19, 2018 | Plumbing
Find the perimeter of a square whose area is 1225 cm2
I could just give you the answer of 140 cm
but I think you need to know how I got this answer
A square is an object that has equal sides
area is calculated by length multiplied by width
so 1225 cm^2 area by using the square root of 1225 cm^2 gives you 35 cm
so each side is 35 cm and there are 4 sides so 35 cm +35 cm + 35 cm + 35 cm = 140 cm
If you are doing homework always show how you got the answer because in an exam having the working out shown can sometimes result in getting some marks even if you slipped up slightly and got the wrong answer.
Nov 05, 2017 | The Computers & Internet
I'm removing this Whirlpool oven and want to replace it with a KitchenAid Model KEBS109BSS. Will the new KitchenAid fit in the existing cutout?
Just fill in the old opening on the top with styling to meet the height needed. If the new one is narrower in width add equally to both side styles, if its wider trim equal amounts off both sides.
Nov 05, 2015 | Whirlpool Ovens
How many inches equals 24mm length ?
An inch is defined as 2.54cm.
10mm = 1cm
24mm = 2.4 cm
Setting these up in a ratio we have:
1 inch x inches
2.54 cm 2.4 cm
cross-multiplying we get:
2.4 = 2.54x
Dividing both side by 2.54:
2.4
---- = x
2.54
x = 0.94488188976377952755905511811024...
Good luck.
Paul
Mar 09, 2015 | Office Equipment & Supplies
Convert cm2 to m2
There are 100 cm in one m, so there are 10000 square cm in one square m.
May 01, 2014 | Office Equipment & Supplies
Solid mensuration problem solving
First a square has equal sides, it means s= square root of 225 = 15.
Height of the base is equal to 15. Volume of the prism = Base area x Height = 225(15) = 3375 cu. cm x 1 liter / 1000 cu. cm = 3.375 liters
Ans = 3.375 liters
May 11, 2013 | Cars & Trucks
How would you represent the area of the base of the box?
The total surface area is made up of three pairs of sides for a total of six sides.
We must find Areahw, which is the area of the side that is h by w.
Areahw = (h)(w)
We must find Areahl, which is the area of the side that is h by l.
Areahl = (h)(l)
We must find Areawl, which is the area of the side that is w by l.
Areawl = (w)(l)
Each of the above areas are present on two sides of the box. So, the total surface area is sum of twice each of these areas, that is:
Total Surface Area = 2(Areahw) + 2(Areahl) + 2(Areawl)
Example:
Let h = 3 cm, w = 5 cm, l = 8 cm
Areahw = (h)(w) = (3 cm)(5 cm) = 15 cm2
Areahl = (h)(l) = (3 cm)(8 cm) = 24 cm2
Areawl = (w)(l) = (5 cm)(8 cm) = 40 cm2
Total Surface Area = 2(15 cm2) + 2(24 cm2) + 2(40 cm2)
Total Surface Area = 30 cm2 + 48 cm2 + 80 cm2
Total Surface Area = 158 cm2
Aug 04, 2011 | Computers & Internet
1.the ratio of the corresponding sides of two similar traingle is 3:2 what is the ratio of there height 2.the ratio of the corresponding sides of two similar traingle is 5:9 what is the ratio of...
1. the ratio of there height is 3:2
2. the ratio of areas of the triangle is: 125:6561
3. the perimeter of smaller parallelogram is: 40 cm2
4. THe real length of the object is 7 cm
Jan 21, 2011 | Dell Computers & Internet
How to fix fill water shooting up and over when flushing?
I don't exactly know what you mean so i will cover all the basics. The fill valve sends fills water in 2 locations. 1) the fill valve fills at the low end (from the bottom to the top) of the tank. This is the flush water level. It needs to be stopped by a float switch before the water overflows into the over flow tube.
2) the fill valve fills water via a small tube at the top of it which this tube NEEDS to be pointed into the overflow tube with a high arch. THIS water is filling your toilet bowl section to proper flushing height. If your water in your bowl does not reach proper height and someone removes this tube to aim it into the tank where the other water is stored, THEN you may have the problems you described and you will need to do several flushes to remove waste.
SO to reiterate 1) make sure your float cuts off and stops the filling cycle before the water flows into the over flow tube. This is done from 1 or 2 adjustment screws. and 2) make sure the small black tube is aimed down into the over flow tube with a good arch. The arch prevents back siphon.
Mar 19, 2010 | VitrA Aria Toilet with Elongated Bowl/...
Please help how many centimeters are in 3 meters? 3.5 meters?
100 centimiter is equal to 1 meter 3meters = 300 centimiters, 3.5 meters = 350 centimiters
Oct 08, 2009 | The Learning Company Achieve! Math &...
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
