Question about Stairmaster 4600PT Stepper
Both pedals slip? - Stairmaster 4600PT Stepper
  • Stairmaster Master
  • 914 Answers
When both pedals slip at the same time, it is more likely to be the alternator brushes than it is to be the hub assembly. Check this link for a brush replacement video. I am also attaching a troubleshooting video for no resistance on a 4600PT.
Stairmaster Alternator Brush Replacement Video
Posted on May 21, 2014
Stairmaster 4000pt pedal slips
Why does one pedal drop on my Stairmaster Stepper but the other pedal operates correctly? Stairmaster Steppers, How to Troubleshoot when one Pedal Drops (Loses Resistance) while the Other Pedal Operates Correctly
  • If one pedal drops while the other operates correctly on your Stairmaster stepper, this problem commonly occurs when the drive sprocket on one side or the other becomes defective
  • Usually, when one drive sprocket fails, the other isn't too far behind
  • The best approach to resolve this problem is to install a new hub assembly
Why does one Pedal Drop on my Stairmaster Stepper
Jul 07, 2012 | Stairmaster 4600PT Stepper
Clutch pedal on ford fusion 3 goes down pin or something comes out
My clutch pedal kept slipping off the rod. I attached a washer with screw tightner to the rod. The pedal nows stays put and does not slip off
Jun 24, 2012 | 2004 Ford Fusion
My brake pedal is slipping i have to pull the pedal up to turn off the rear lights
On your brake pedal under the dash, you will see a white unit with a plunger, the plunger touching the brake pedal. The tend to start slipping in the bracket after a while. Try pulling it out and squeezing the bracket a little then reinstall it. If that doesn't work, you will have to replace it.
Jul 26, 2011 | 1988 Chrysler LeBaron
I have a stairmaster 4400cl and the right hand pedal intermittently slips and drops to the floor. it only does this a few times every 5 minutes or so. when i put weight back on the left pedal and start...
Oct 17, 2010 | Stairmaster 4400CL Stepper
Slipping gears
Your chain and drivetrain is probably worn out.
Read this...
http://www.sheldonbrown.com/chains.html
May 03, 2010 | Cycling
Stairmaster pedal slip
Sound s like it maybe the hub assembly they have a one-way bearing in them and that could be cause the problem go to
http://www.gympart.com/ or call them 1-800-496-7278 they will have the parts for your
Jan 09, 2010 | Stairmaster 4600 Cl Cordless Freeclimber
2002 Kia Sportage Car spongy clutch pedal Answer The clutch pedal is very spongy, and sometime has not pressure on the pedal at all when the vehicle... (More) The clutch pedal is very spongy, and sometime...
The spoongy feeling is a defective clutch slave cylinder. Generally a cluthc will not slip because of a pressure issue with hydaulics.
If the clutch is slipping with your foot off the pedal it defineately is time for a clutch job... Best bet is to get it inspected to be sure.
Jan 04, 2010 | 2002 Kia Sportage
Stairmaster 4600pt pedal falls without warning
i have the stairmaster 4000pt which was bought new in 2003. in 2007, i started experiencing the same problem, the right pedal would sometime slip and fall to the floor. i called the local fitness store and they came and replaced the hub assembly and that resolved the problem until now. The left pedal is now slipping.
Apr 14, 2009 | Stairmaster 4600PT Stepper
Clutch slipping
A clutch is usually adjusted from underneath the car if it's a mechanical clutch.
Your comment that there is very little play at the top indicates an improperly adjusted clutch. You should have about 1/2 - 3/4 inch of play before feeling the clutch in the pedal.
Jan 24, 2009 | 2003 Nissan 350Z
Stairmaster 4600PT Stepper Logo
118 people viewed this question
Top Stairmaster Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
Matt Olenzek
Matt Olenzek
zr800o1le
zr800o1le
Level 1 Expert
Are you a Stairmaster Exercise and Fitnes Expert? Answer questions, earn points and help others
