No schematics for a fraser johnston furnace. model# 80CD36BNL series# NAHOE serial# 138703901300
3 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: I need the wiring schematic
Rich tips for hvac knowledge seekers
Whats going on with the unit. Can't nobody find schematics online for HVAC.
Posted on Mar 28, 2011
  • 119 Answers
SOURCE: need the manual or schematics
Try this one.
Posted on Jun 24, 2011
I have a Fraser Johnston furnace model #PCUHALD12N060C That acts like the flame indicator is faulty. It will ignite and 5-20 seconds later it shuts the gas off. I have replaced the indicator. Any sug?
Thomas, the 'flame indicator' to which you refer is a portion of the safety circuit called the 'flame rectification' circuit. Typically, the flame rod or possibly the igniter itself complets the ground circuit in the circuit board as flame is established. This is a very low amperage, as low as 4 MICRO-amps and can only be read with a Micro-ammeter. Many times, if the problem persists after the flame rod has been replaced, it is slight corrosion on one or more of the spade clip connections on the ground wire at the pilot assembly or at the circuit board itself. It takes verrrrry little corrosion to interupt that verrrrrry tiny signal and a shining up of the connections many times rectifies the problem.
The fact that the gas ignites and stays on for near 20 seconds indicates there IS a signal getting back to the board, but its borderline in its ability to being strong enough to 'prove' the flame.
Nov 21, 2015 | Heating & Cooling
Fraser Johnston Furnace - Not heating
Check the furnace filter to make sure its not dirty . Dity airvfilters can cause the furnace to overheat and shut off on a high temperature limit switch when the switchs cools down it resets but the furnace has to be shut off to reset the control board. Hope this helps.
Jan 23, 2014 | Heating & Cooling
Replace johnston fraser thermocouple
Shut off gas to Furnace, then loosen the conection going into the gas valve, then remove from pilot aseembly and replace.
Dec 21, 2012 | Heating & Cooling
I'm interested in buying this furnace from someone. it is new and wrapped in plastic so i took a picture and thought i could find out about it model #tg9s100 c16 mp 11 95% what year is it and how can...
the company that makes this unit (Fraser Johnston) has the ISO 2001 logo on their
website. The compliance date for ISO is between 2008 and November 2010 so
I would venture a solid guess that the 9 in the first 3 digits is the manufacturing year
Mar 02, 2011 | Heating & Cooling
I need a part number for a pressure switch for an Amana Furnace GUCA070BX40
Check this out. You ave to apply negative pressure to make the reed switch click, that means you have to apply suction to the switch to check it. most of these switchs ain't the problem. Blocked tubing yes bad switch naw.
May 20, 2010 | Heating & Cooling
What is the model number for the Draft Inducer Motor Goodman GNP075-2REVB Furnace
I think you must mean GMP075-2rev8 check this link for parts listing:
http://site.famousparts.com/goodman/PDF/RP-169C.pdf
Johnstone supply which has many locations in many cities sells Goodman and stocks parts, and available mailorder http://www.johnstonesupply.com/corp/Default.aspx
Feb 18, 2010 | Goodman Furnace Draft Inducer Blower ...
Carrier 58 Series Furnace Blower Motor Won't Shut Off
Yes. If the high limit is tripped, the furnace will bring on the fan continuously until the limit resets. Often, they will not reset if tripped repeatedly. If the furnace is too large for your application, you probably are not able to move enough air to keep the heat exchanger cool enough.
Oct 03, 2009 | Heating & Cooling
Need a schematic diagram on a trane furnace model blu080k0942b0
Have you checked on the inside of both front panels?
Mar 05, 2009 | Heating & Cooling
Heating & Cooling Logo
118 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
