Question about NEC LCD1712 17" Flat Panel LCD Monitor
I use two monitors and the NEC is beginning to flicker a little and when I just got back on the computer it wouldn't come out of sleep mode until I turned it on and off.
  • jcallaway14 Sep 08, 2010
    Actually instead of going to sleep it goes to standby after 4 hours. The power setting is set to never turn off. This fllickering has just started after a couple of years.
  • jcallaway14 Sep 15, 2010
    The monitor now will stay on for about a minute and then goes to black. I can turn the power off and back on and it will repeat the process each time. Stay on for about a minute or two, ,then go to black. HELP!!!
    I switched the monitor plugs on the computer and it does the same thing no matter which monitor plug I put it in.
  • 11,896 Answers
Yes sleep mode and hibernation are not good programs to use on a computer. They cause many problems. I would recommend going to control panel, display settings, then screen save, then power options. Now just change when the monitor turns off and when and if you want your hard disks to turn off. You would be ok with just having to monitor turn off.
Posted on Sep 08, 2010
  • Nate Stansfield
    Nate Stansfield Sep 08, 2010
    Does it flicker when using either screen? If that is the case, check the card make sure it is in tight and no loose solder joints or connections. Updating the drivers wouldn't be bad idea either.
  • Nate Stansfield
    Nate Stansfield Sep 15, 2010
    Make sure the monitor cord is plugged in tight to the computer and that no pins are bent. Check that the monitor is on the 110 voltage setting (not all monitors have this switch)
    Check the contrast and brightness adjustment. If the monitor to computer cable detaches from the monitor, exhange it for a cable that is good. or check the cable for continuity.
    Confirm that the proper system configuration has been set up. Some older motherboards have a jumper or DIP switch you can use to select the monitor type.
    Test a monitor you know is good on the computer you suspect to be bad. If you thinkj the monitor is bad, make sure that it also fails to work on a good computer.
    Check the CMOS settings or software configuration on the computer. When using windows, bott into safe mode.
    Try reseating the video card. For a PCI card, move the card to a different expansion slot. Clean the card's edge connectors, using a rubbing alcohol and a cotton swab.
    If there are socketed chips on the video card, remove the card from the expansion slot and then use a screwdriver to press down firmly on each corner of each socketd chip on the card. Chips sometimes loosen because of thermal changes.
    You can also trade a good video card for the video card you suspect may be bad.
    Another thing you can do is go into CMOS setup and disable the shadowing of video ROM.
    You can also test the ram on the motehrboard with diagnostic software.
    For a motherboard that is usingan AGP or a PCI Express video card, try using a PCI video card in a PCI slot.
    If you have a different monitor to try and use, then you can check or change the video driver configuration.
Monitor with lines and flickering but monitor is fine
It might have been caused by an outdated video card driver. To check that, go to safe mode and observe if you experience the same issue.
To go to safe mode, do the following:
Restart your computer and tap F8 until you see safe mode. Use the arrow keys to highlight safe mode and press enter. Once you're in, observe if you experience the same problem. If you still have the problem, then it's the connection between the monitor and the motherboard which causing the problem. You need to reset the connection or get it checked by a technician.
If there are no problems inside safe mode, then update the video card driver. You can also automate the updating mechanism of your computer's drivers to make sure that you won't be getting any problem in the future. You can use RadarSync to automate the updates.
I hope this helps!
David
Feb 24, 2013 | Acer Computers & Internet
Viewsonic vx2235vm does not turn on
This really sounds like you have a power supply board that is having problems with the filter capacitors which are causing it to not start up correctly. Here is a like to a repair guide including video instructions showing how to open and repair the monitor.
http://www.ccl-la.com/blog/index.php/repairing-the-viewsonic-vx2235wm-lcm-monitor/
Part one of the video guide:
Feb 07, 2013 | ViewSonic VX2235wm LCD Monitor
My screen symtoms are a little different on my L1975NW.
I am guessing the LED power indicator blinks green then becomes steady when the screen "turns on" (shows video). The problem is most likely a failing backlight power supply. That's why there is a 30 minute delay. Try to disable sleep mode and see whether that helps.
Aug 30, 2012 | Westinghouse L1975NW Monitor
My monitor goes to sleep and doesn't come back on.
For that when you power up the computer press F8 key then enter in enable vga mode .
Then go to display property and set screen resolution to 1024*768 then apply and ok.
if still not work then try safe mode then uninstall graphic driver and reinstall.
When you power up the computer press F8 key untill you see windows logo.
Let me know if you need further assistance.
Thanks for using Fixya.
Feb 07, 2010 | HP w1907 LCD Monitor
Compaq Presario stuck in sleep mode
Connect the monitor to some other computer, e.g., a notebook, and see if it does the same thing. If it does, then the monitor is the problem.
If it does not, then your computer is not putting-out any "video" signal, and so the monitor goes to "sleep".
If you have MORE than one VGA-output port on your computer, connect your monitor to the "other" VGA port.
Or, press-and-hold the ON/OFF button on your computer, to force it to completely shutdown.
Jan 13, 2010 | HP Pavilion a1710n (RK573AA#ABA) PC...
Dim monitar with flickering screen
The problem can be caused by 1 of 2 things either your power supply is going out or the backlight bulbs are going out. The most likely cause is the power supply. If you are willing to do a little soldering you should be able to do the repair. If you go to our web site at: www.ccl-la.com/badcaps.htm We have a section on monitor repair. Look under the Samsung 930B it is the same as your monitor.
If you don't want to do it yourself we do offer a repair service, email me if you are in need of that.
I hope this helps.
Buddy
Aug 05, 2009 | Computers & Internet
My monitor goes to sleep after a certain time when I'm in BIOS?
you can only control the pwoer function to your pc or monitor to adjust when the screen to go to sleep mode or even shut off throw control panel power options
Jul 19, 2009 | NEC LCD1735NXM Monitor
How do you put a monitor into power save?
Depending on your operating system go to Control Panel of Windows and find the Power Options section.
There should be a setting there to change how long to waite before the monitor sleeps.
Jul 16, 2009 | NEC MultiSync FE700 17" CRT Monitor
Hmm... is still not working
Start your computer and tap the F8 key as soon as the computer begins to power-up. Keep tapping until you come to the Safe Mode screen. When the screen alerts you to the fact that you have chosen Safe Mode, click OK.
When you get to the desktop go to the control panel and launch System Properties. Go to Hardware and Device manager. Click the arrow next to the Display Adapter. Point at the adapter, right click and chooser Properties. Click the Driver Tab. Roll back the video driver to previous driver.
If indeed you have installed a new driver that is not compatible with your video card, then rolling it back to the original may very well take care of this problem.
Aug 14, 2008 | HP Pavilion a800n (PP163AA) PC Desktop
NEC LCD1712 17" Flat Panel LCD Monitor Logo
Top NEC Computers & Internet Experts
Steven Wander
Steven Wander
Martin Murray
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
