Question about SanDisk Audio Players & Recorders
Answer to question from k_akima: No, factory reset doesn't work. I had tried that earlier (it's always worked before if I had problems) but it doesn't help. Thanks.
  • kakima Sep 08, 2010
    Okay. The menu button is supposed to get you out of FM mode, but apparently doesn't. Are you saying the reset puts you back into FM mode? Do you have a microSD card installed? If so, what happens after you remove it and reset the Sansa? What happens when you connect the Sansa to a computer?
  • ginny_crowle Sep 08, 2010
    No microSD card installed. Reset didn't work, but when I plugged the Sansa into the computer it reset. Thanks for your help.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • SanDisk Master
  • 102,366 Answers
Glad to have been of service :-)
Posted on Sep 09, 2010
Testimonial: "Responded quickly and had the solution. Thanks a lot."
There is three days that I try to open high five casino, it logo for high five casino comes on, but it always goes back to icons.
Try first to clear the cache, delete the data and force close the app then start the app. If it doesn't work uninstall the app and then reinstall it from Google play. And if this doesn't work try to find a earlier version of the app and try with it but first do the first 3 steps in my first suggestion. My last suggestion is to do a factory reset and reinstall the app
Feb 15, 2015 | Apple Ipad I-pad
Daytek TV reset code
If nothing else works, connect your TV to a receiver ir an XBOX One or even a ROKU 3 device. Each of these will power on your tv set automatically when you power on the device.
Mar 24, 2014 | Televison & Video
How do i unlock my pattern lock on my galaxy s2
1. try entering null as password.2. try entering your username without @gmail.com3. Combine 1 and 24. Call yourself from another phone, answer, without hanging up press the home button, then menu button, settings, try to disable pattern-lock5. Call yourself from another phone, answer, hang-up, directly after hanging up start pressing your buttons like a madman for <30-60 seconds ending with your home button (might take a while to get the timing right). Go into settings and disable pattern-lock.6. Try the normal recover password routine from GMail.com
7. Perform a factory reset. YOU WILL LOOSE all not-synced DATA (SD card will be left untouched).
1-6 are possible workarounds, these doesn't work for everyone but can be worth a try to avoid factory reset. 6. is what should work but hardly never does. 7 - The factory reset always work
Added reference with some additional info, how to factory reset can be found there.Good luck!
Oct 14, 2011 | Samsung Galaxy S GTI9000 Smartphone
How do i return my acer aspire 5630 to factory settings
Method of Restoring yourPC to factory reset: Try tapping the F10 key every couple of seconds during a boot. Most OEMmachines have a recovery partition on the hard drive. Don't worry about the partition, it's probably hidden and it doesn't concernyou. In that partition there is an image of your system that was made justbefore it left the factory. Just follow the directions to recovery your system and you should be fine.You 'might' have an option to do a 'non-destructive' or a 'destructive'recovery. If you choose the 'non-destructive' it will 'try' to repair yoursystem and save all your files. If you choose the 'destructive', it willrestore your system to the way it came from the factory. I suggest trying the 'non-destructive' first. You can always try the'destructive' if it doesn't work.
Sep 15, 2011 | Computers & Internet
I have a linksys router and i have tried to access the configuration menu. I have tried the common 192.168.1.1 with no sucess. i have even looked at my details for the ip and it is 192.168.24.1. That does...
Resetting by pressing the button for a total of sixty seconds usually works! While holding the button you can also power cycle the router once or twice. That should put the router back to default settings. Its frustrating sometimes but usually works by prolonged resetting and power cycle. Good luck!
Sep 06, 2011 | Computers & Internet
Im Using LGKm555e the problem is my camera was not working .. Its capture fail always everytime i try to use it help plzz,
Try to check your phone memory if there's still available memory and sufficiency to save a photo. delete some unused data or file to save space and to be able to operate any other phone features. also check the memory card if still have a space to save data.
If the above method doesn't work,try to reset your phone by going to setting and choose reset factory settings,and if ask for a code,the default code will be 0000.
hope this method will works.thank you for visiting fixya.
Jun 16, 2011 | LG Dare VX9700 Cell Phone
Memory full, the problem is that there is always a MSG on the screen that the phone memory is full, i was trying to format the device but it doesn't work, i removed everything from the device and...
have you try reset by this way *#7370# or by 3 button tricks : turn off your phone, press 3 * answer key and power at the same time?? if you have and still have a same problem, maybe you need to flash your os by going to nokia care center..
May 12, 2011 | Nokia N79 Cellular Phone
My phone got locked after attempting to unlock it twenty times. it went to a gmail account and i dont have a gmail.
Must be an android phone. In which case it makes you set-up a gmail before being able to download apps from the Android Market. Anyway yes now you must start over. This time write down the gmail account.
I’m happy to assist further over the phone at https://www.6ya.com/expert/steven_958e67a4edcc47d5
May 02, 2011 | Cell Phones
Error 678
What version of ActiveSync do you have on your computer?
I assume that you have had this device for a while and are not new to it. I am currently using version 4.2 of ActiveSync, which you can download from Microsoft, and rarely have any problems with it.
I would try doing a soft-reset on this machine, restarting your desktop computer. I would recommend uninstalling ActiveSync if you have an older version and installing 4.2, or even 4.5, they both seem to work well for me, and I rarely have problems. If this doesn't work, you can always do a hard reset on your 900, which is removing both batteries, waiting no less than 15 minutes with both batteries off, and then re-inserting the batteries and starting over. (Do this only if you have nothing you would regret losing, or if you have backed-up your data.)
I mentioned the hard-reset because it can often save you a lot of hassle of looking all over for the answer and then finding out that the answer you got gets you nowhere.
If you are able to, I would do a hard reset plus uninstall older version of ActiveSync and install either version 4.2 or 4.5 on your Windows XP or earlier machine, and then see if that works.
If that does not work, go to http://www.hpcfactor.com/forum, go to the section for Handheld PC's, and make a post with your problem and someone will answer. They are really good with these machines and can usually point you in the right direction.
Hope this helps
Regards,
elMono28
Aug 26, 2008 | NEC MobilePro 900 Handheld
43 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
