Question about Craftsman 2500 PSI Briggs Stratton Powered Pressure Washer
Hi, I have a problem starting my Craftsman 2450 PSI Pressure Washer, Model 580.752310, could you help? I've changed the spark plug.
  • 420 Answers
SOURCE: Craftsman Pressure Washer 2.3 GPM 2550PSi
if there is a fuel filter running completely out of fuel sometimes allows all of the bad stuff in the fuel tank to plug the fuel filter (if it has one). press the primer bulb until you can hear fuel, then it should start.
Posted on Jun 02, 2010
Jmonica1
SOURCE: New 75219 Power Washer is missing owners manual.
Any luck finding someone to give you a copy of the manual for this model? I bought one on clearance and it doesn't have the manual and I'm scared to even start it up without reading the manual as I don't want to mess anything up upon first start. If I ever do find one, I will post a copy of it for you. Good Luck! Thanks
Jim
Posted on Jun 10, 2010
  • 36 Answers
SOURCE: started by Craftsman 2700 PSI
The first thing I would check would be the oil level, to make sure you didn't put in too much oil. If the oil level is correct, it could be a stuck piston ring, letting oil blow by the piston, and out the exhaust. If this is the case, you are going to have to tear down the engine.
Hope this helps!
Posted on May 09, 2011
woobie dog
  • 1273 Answers
SOURCE: Water flows thru the pressure washer pump and out
Let the water run for a longer time. "Walk" the hoses, from the faucet to the pump and then to the nozzle, holding the hoses up to displace any trapped air in the lines through the pump and out the nozzle. What it sounds like is that air is reaching the pump. When it does, it cavitates, and no water can be pumped. Tighten all of your hose fittings securely. Try holding the trigger down while starting the washer. It may be easier with another person helping.
Best regards, --W/D--
Posted on Jul 08, 2011
Spark plug gap for craftsman pressure washer 2700 psi
The spark plug gap should be .028" or .7mm
Hope this helps.
Brad
Jul 30, 2014 | Garden
Engine lockup
Sounds like the intake or exhaust valve is not opening.
Jun 08, 2013 | Craftsman 2700 PSI Briggs Stratton...
I've got this white powder stuff in my fuel filter
its from using old fuel only use fresh gas 30days or newer
Aug 03, 2012 | Craftsman 2700 PSI,2.3 GPM Briggs &...
My 13.0 honda gx390 motor has no spark and will not start
try disconnecting the black wire which runs across under the fuel tank you should have spark.
Nov 15, 2011 | Simpson Taskmaster Industrial Gas Powered...
I bought a new craftsman pressure washer 2700psi. Put oil and gas in it. Cranked on the first try. It worked for about 15 minutes and then cut off. Now the pull start is very hard to pull and will not...
Hello
Take out the spark plug and try pulling,if it is still hard then then there is a problem with the pull start mechanism.
Check the plug for oil fouling or fresh oil.If there is excessive oil you may have bad rings.
If in doubt, craftsman will honor the 1 year warranty no questions asked,for a new unit.
Jun 25, 2011 | Craftsman 2700 Max Psi Pressure Washer 23...
Troy bilt pressure washer will not build or reach high pressure
check the non-return valves in the pump block. if these are damaged or dirty you pressure will be greatly reduced. they are located behind the 3 lage brass hexagonal caps.
I hope this helps
Sep 04, 2009 | Karcher 2500 PSI Pressure Washer
How much oil in pump...Craftsman 2200 PSI pressure washer
Hello:
Best to use NON DETERGENT 10W30. Be sure you fill the reservoir only 1/3 to less than 1/2 full.
Aug 25, 2009 | Briggs & Stratton Garden
I have a craftsman 4.5hp quantum xte pressure washer 1800psi/4.5hp/2.0gpm mod 580.761800. I have to start the washer before I turn the water on and just today started with if I let go of the trigger on the...
the pressure relief valve(bypass) is most likely stuck or clogged. take the relief valve off and check for broken or jammed parts..there should be a bypass hose that goes around the pressure valve
Jun 16, 2009 | Briggs & Stratton Garden
Craftsman 2500 PSI Briggs  Stratton Powered Pressure Washer Logo
231 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
