Question about Roper RAX4232KQ Top Load Washer
The wahing machine makes a noise at the spin cycle and does not drain. I haven't taken it apart yet but I think the belt is broken. It wahes just fine.
  • Roper Master
  • 8,220 Answers
That must be the lid switch. The wahing machine makes a noise at the spin cycle - 6dbd353.jpg422ad8a.jpgTo fix this puppy you flip up the controls and pop the case off. Here are some vids:
More here.
Posted on Sep 08, 2010
Beko WM6355W wahing machine makes a clicking noise when the drum turns, the noise gets louder and a smell of burning rubber comes when it spins
sounds like your drive belt is damaged, it may have a small section stripping of the belt and hitting something in the machine as it turns.
take off the back and check the condition and replace as needed.
Aug 29, 2014 | Beko Washing Machines
My wahing machine won't spin
There are probably 12 things that would make it not spin...check
the belt. Is it loose or broken?
Regards,
Dennis
Aug 17, 2014 | Whirlpool Washing Machines
Water does not drain automatically wahes and spin
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Mar 04, 2011 | Washing Machines
Wahing machine does not spin
the coupler is bad, this unit does no have a belt. has a motor coupling installed.
i have seen video's on youtube about how to do this in the past, its not hard
part number 285753A buy it here http://lartoday.com/order_parts.htm
lebarchrigen appliance repair
www.lartoday.com
Dec 10, 2009 | Whirlpool GST9679P Top Load Washer
My wahing machine makes the noise that it normally makes when it's in spin mode, but the tub isn't moving.
The belt probably broke.  The belt is on the bottom of the machine and if fairly easy to replace.  If it is not the belt it could also be the brake, but if this was the case you would probably be smelling burning rubber during the spin cycle.  The brake is just above the belt pulley.
Oct 25, 2009 | Maytag Performa PAV3200
Wahing machine will not wash
the entire agitator is not moving during the wash??? or just the top section that looks like a big plastic corkscrew???
or is the unit actually just filling with water, making the motor running noises and going thru the motions of running a cycle yet not actually moving anything within the unit, then draining out as normal??
if just the top section of the agitator is free spinning instead of ratcheting as normal you'll need to replace the agitator dogs if present.
if however the units just filling and draining of water with no inner movement then more likely the drive coupling is bad and needs replacement..
hope this helps,
best of luck,
ttfn
Oct 25, 2009 | Whirlpool Washing Machines
Code f-21. Wahing machine keeps on showing code F-21 after I put it on rins/drain cycle, and 2nd spin. What should I do now?
What you should do is get a flashlight, remove the hose from the pump and look into the suction port on the pump. Check the blades on the pump impeller. Make sure that no blades are broken or missing and that the impeller rotates freely. If any blades are missing or broken or if you cannot get the impeller to turn freely, then the pump will need to be replaced. Hope this helped and best wishes.
Aug 15, 2009 | Washing Machines
Spining makes noise and machine vibrates a lot
its a simple solution just remove the brown colour clamp at the bottom of the machine with a screw driver
Jun 03, 2009 | Whirlpool Washing Machines
Roper RAX4232KQ Top Load Washer Logo
134 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
