Question about Fisher and Paykel GWL11 Top Load Washer
Fault 49 - Fisher and Paykel GWL11 Top Load Washer
  • 4 Answers
Replace cold valve...
Posted on Oct 04, 2010
Fault 49 pops up on the screen
If your washer is a Fisher Paykel Top-Load Washer Error Codes = 49 I found this online by typing "Washing Machine Fault 49" into a google search engine...
Error Fault Condition - Water Inlet Valve Fault.
Repair or Check - Unplug the washer from power. Reconnect any non secure wires on the water inlet valve. Replace the wire harness if it is found to be damaged. If the wiring is okay then measure the resistance of the water inlet valves using an ohm meter. If the resistance of each water inlet valve solenoid is not 60 to 62 ohms then replace the complete water inlet valve assembly.
Parts for Replacement - Water Inlet Valve Assembly or Wire Harness.
Mar 09, 2016 | Washing Machines
What is the fault when the air bag dash light flashes code 49
It's a common fault on many Fords, usually due to a poor connection in the YELLOW PLASTIC CONNECTOR underneath the passenger seat. Just push it together properly and it should clear the fault. If not, go under the drivers seat and secure all the wires and clips there as well.
Aug 21, 2014 | 2006 Ford Territory 4.0
Fault 49
The main board is displaying the wrong error
for the problem your machine has.
Fault 49 is water valves error.
The most common problem with AquaSmart is pump faulty
and damaged your motor control board,
Pump and motor control board need replacing.
Jul 31, 2014 | Fisher and Paykel Washing Machines
Fault code 49
Fault code 49 is a valve fault, but I have found it to often be the motor controller board at fault.
Oct 19, 2013 | Fisher and Paykel Washing Machines
Fisher paykel aquasmart fault 49
Fault code 49 is water valves, But the Aqua-Smart board is outputting the wrong code here, The Smart pump has blown the water valves fuse, A common thing in Aqua-Smart Machines.
The Smart pump has jammed with lint and caused over current to the board and taken out parts on the board that drive the pump.
Best to get a new/recondition board for your machine.
Apr 20, 2013 | Fisher and Paykel Aquasmart wl80t65c
Fisher paykel aqua smart fault 49
Hi my washing machine saying fault 49 on it model WL80T65C
prob the capacitor faulty on motor , or start up windings on motor burnt out ,
Mar 22, 2012 | Washing Machines
What is fault code 49
Fault code 49 is cold inlet valve
May 22, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fault 49 smartdrive
My paperwork says fault #49 is hot and/or cold water valve faulty. Check that the valve harnesses are connected connected correctly or check that the valve is not an open circuit.
May 23, 2009 | Fisher and Paykel GWL11 Top Load Washer
Code 49 and Manual Book
Fault 49 usually points to the cold inlet valve. I have come across many with this fault that the valve tests ok and it needs the motor controller replaced.
Jan 06, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher and Paykel GWL11 Top Load Washer Logo
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
