Question about Tippmann 98 Custom Act Paintball Gun
Co2 leaks from Tippmann 98 custom barrel all of the time.
    Novelist:
    Scholar:
  • 111 Answers
If you **** it you may find that that stops. Or **** it and then screw in your tank. Make sure you have plenty of air in the tank too, low pressure can sometimes not engage the valve enough to close.
My first suggestion is to pull out the internals and clean/lube them with a good oil made for paintball.
It's possible it could be an o-ring, but I'd try the above first. If it's been a while since you've had any o-rings replaced it might be a good time for a tuneup. Get a kit and change 'em all and you know everything is good to go rather than waiting for something to fail.. and if one fails it's probably only a matter of time before another one gives.
Play hard, play safe, play with honor!
8^)
Posted on Jan 04, 2011
Hi I recently purchased a used tippmann 98 custom paintball gun and I connected a co2 tank and it started leaking and it came out of the barrel and froze it! I do not know why is wrong or if it is missing...
sounds to me like you have seals gone inside your marker,, take it apart make sure all seals are in good condition and the marker is well lubed
Dec 05, 2012 | Rock & Ice Climbing
Just bought a tippmann 98 act took it home went to test and it still broke like everyother ball. Is it the balls or possibily to much veloicity? does it make a difference co2 or compressed air?
The velocity adjustment is probably way too high.
This causes too much propellant to enter the firing chamber.
There should be an Allen screw on the side of the gun where
you can adjust the velocity. Try backing the screw out a turn and see what happens.
Here is your owners manual to help you.
http://www.paintballadvisor.com/manuals/Tippmann%2098c%20manual.pdf
CO2 is very hard on O-rings so if you can use air you are better off.
I use an A-5, Autocockers, Smart Parts Ions and more.
Mar 06, 2011 | Tippmann 98 Custom Act Paintball Gun
I was playing today and my 98 custom just started leaking CO2 from all the cracks it froze up and ice started coming out of the barrel. what happened and how can i fix it??
your tank loosened up, the co2 freezes the rubber seals they will have to be replaced, you can order a repair kit from the website, change out all the rubber seals on the gun and your co2 tank
Feb 17, 2011 | Tippmann 98 Custom Act Paintball Gun
When i screw my tank on the CO2 goes right through the gun and out the barrel
**** it and that should stop.
If that persists make sure you have cleaned the marker and used a good paintball oil to lubricate the internals.
At the next level you could have a o-ring that's old, brittle, broken and now is leaking by. Your local airsmith should be able to provide the necessary part(s) or fix it in short order for you.
8^)
Nov 07, 2010 | Tippmann 98 Custom Act Paintball Gun
Paintballs will fall out of the barrel of my tippmann 98 custom, randomly when the gun is not being fired. I am not sure how to fix this, or if it can be fixed. Mechanically the gun fires and aims great....
Get another ball detente from ebay, this one is the cheapest one I could find.
http://cgi.ebay.com/NEW-TIPPMANN-C-98-BALL-DETENT-A5-BALL-DETENT-/370469346400?pt=LH_DefaultDomain_0&hash=item5641b19c60
Jun 26, 2010 | Tippmann 98 Custom Act Paintball Gun
98 Custom Act Paintball Gun: i have just brought a 98 tippmann custom and it ha...
Basically speaking, air is air. Now it's the pressure that's the concern. co2 bottles use a regular valve that has a pin in it and opens to allow the gas through. High Pressure Air - HPA is the same concept but since the pressure with co2 is built up by expanding gas, HPA has to do it with pressure only. So the tank is pressurized a LOT higher than co2, but there's a regulator on the tank valve to bring the working pressure into the marker to the proper level.
So yes, you can use "air", but you need to make sure it has the right output for your marker. (i.e. not a low pressure HPA valve.).
You'll have the same problem though, getting someone to fill the bottle. Check with your local airsmith and paintball fields and stores. If they have co2 they would have HPA, but some do only deal with HPA since it's "easier" in some cases.
You may have to check around. Sometimes hardware stores have a small section in back, or you can check with the paintball places around to see if anyone in your area is equipped. Some teams have their own tanks, especially if there's not a place to get fills locally.
There's also online communities like Brigade and various paintball sites where you can check around for other players. Someone may have a co2 fill tank, a scuba tank for HPA, or a group that gets tanks together to make a run and get them filled somewhere.
8^)
May 18, 2010 | Tippmann 98 Custom Act Paintball Gun
As soon as I screw on the CO2 supply cylinder, I hear air leaking internally. The last time I used it, it worked perfectly. Any ideas?
O-ring. If it is leaking near the tank, it is the o-ring on the tank. Otherwise, it could be one of many o-rings inside the marker. I would take it to a gunsmith and get all the o-rings swapped out.
Mar 01, 2010 | Tippmann 98 Custom Act Paintball Gun
Tippmann Custom 98 simply NOT WORKING
  1. Home page | Special Ops Paintball SPECIAL OPS - A-5-A2 COMMANDO EZ-KIT. Regular Price: $ 79.95 ... Special OpsPaintball is a proud sponsor of the Living Legends scenario paintball game. ...
    shop.specialopspaintball.com/ - Cached - Similar
    Forum Brigade Tippmann A-5 Upgrades Gear Vests Articles Sick Deal Tippmann X7 Upgrades Markers More results from specialopspaintball.com »
    YOU NEED TO BUY A RE-BUILD KIT ITS CHEAP HERE.
Oct 04, 2009 | Tippmann 98 Custom Marker
Co2 leak
Did you check the O-rings?
Jul 07, 2009 | Tippmann 98 Custom Marker
Tippmann 98 Custom Act Paintball Gun Logo
509 people viewed this question
Top Tippmann Sport & Outdoor - Others Experts
spank61
Vickie Miller
Vickie Miller
Level 1 Expert
Are you a Tippmann Sport and Outdoor - Other Expert? Answer questions, earn points and help others
