Question about LG L1930B 19" LCD Monitor
I have a L1930b with a bad panel. I have a panel that will fit this monitor but it is an LM190E03-B4, which takes 5V input, whereas the original panel takes 12V input. The power inverter is a Lien Chang AI-0066.PCB Rev:H. Can someone tell me how to modify this inverter to output 5V so I can use this panel?
  • 11,361 Answers
You can use the 5vdc from the monitor power supply
Service manual: http://elektrotanya.com/?q=showresult&megnev=lg&megnev2=L1930B%20&kategoria=&kat2=all
I look at the diagram page 31, pin 1~3 is the VCC for the panel with notes for 12/5vdc, it can be connected to the 12 or 5vdc, so it must have a jumper on the board somewhere that will let you choose 12 or 5vdc for the panel, the main thing is that the rest of the panel pins match the original panel, please verify that first.
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Sep 09, 2010
My L1930B display darkens right after switching it on. The image of the computer appears only for a millisec. If I keep trying switching on and off, it begins working, but usually it doesn't. What could be...
If not a bad kettle lead or loose connection at the monitor it could be:
Failing inverter, also maybe powerboard capacitors leaking or not holding charge. flicking the power switch will cause it to fail more quickly, repair or replacement I'm afraid
Jan 10, 2011 | LG L1930B 19" LCD Monitor
My driver cd has been damaged where can i find replacement drivers
here.. click this file to start downloading this file
LG L1930B 19" LCD Monitor Driver
Save the file, unzip and install.
Much appreciated if you rate this help..thanks..
May 25, 2010 | LG L1930B 19" LCD Monitor
My monitor power on then cut off what can i do
I had the same problem with the exact same model of Gateway 19" LCD. Likely this is the same issue you're experiencing, and I hope you're able enough with a multi-meter and soldering iron to fix this issue, or willing enough to tear this thing down to its components and at least try to fix it.... otherwise you have a fancy dead-weight object on your hands/desk.
In my case, the 5V power was fried so I actually inserted a 5V 2A power supply inside the monitor housing and soldered the +5V and GND leads to the marked connector pins that connect the power board(larger) to the vga signal board(much smaller). I stripped the guts from the 5V power supply so it would fit easier, and then stole power from the 120v monitor input and directly wired that to the wires that were hooked to the 120v power supply prongs(after removing those prongs as well). The monitor looks and functions as if it were brand new, there's nothing extra hanging out and no bulges anywhere. It works excellent.
Aside from my more-so hackful approach, here's some links and quotes, from other sites, from people who know what components to replace on the power board and still achieve a well-working end result.
From: http://www.topix.com/forum/tech/TNTK13PFRQURRRJJC/p4
Sure-power wrote:
I repair the Gateway FPD1960, FPD1975W and FPD2185W monitors. You can contact me at sure-power@nc.rr.com if interested. If you can remove the power/inverter board it will save $$ on shipping costs. I have sucessfully repaired hundreds of these monitors. From: http://gatewaymonitors.blogspot.com/2007/09/gateway-monitor-recall.html
Russ said... Thank you Michael & Germel & everyone else for your help. I replaced the 5 470microfarad and 4 220microfarad caps on the FPD1960 and it works again. If your in the Metro Detroit area I can perform this repair for $60 onsite.
(insertabovename)@gmail.com
June 19, 2008 10:57 AM icon_delete13.gif b16-rounded.gif Russ said... russix
at
G Mail
Dot
Com
Feb 22, 2010 | Gateway FPD1960 19" Flat Panel LCD Monitor
LG Flatron L1930B lcd monitor - 3 vert. stripes, center one dead
sounds like the pixel controllers have gone bad or one or more of the color (RGB, RED, GREEN, BLUE) controllers have gone out. this is quite common in lcd monitors/tvs and is usually caused by pressure on the edges of the screen (you grabbed it too tightly when moving the monitor) or just faulty controllers. they are expected to eventually go bad, ask LG for yourself, they will tell you the same thing. If you just bought it, that can be considered a mfr defect that they will replace, IF IT IS IN WARRANTY!!!!! Unfort. there is no fix due to seal that placed on the actual lcd panel inside the plastic casing. Youd spend more money trying to find the part and install it than just buying a new monitor. hate to say it but im an avid gamer and have gone through about 4 lcd monitors in tha past 3 years due to everyday use
Sep 18, 2009 | LG L1930B 19" LCD Monitor
No DVi input, then computer goes to sleep
Hi publicworker,
I had a similar problem whereas my monitor went to sleep mode after a few minutes. I'm running an HP LP 2065 in dual mode with another HP flat screen. However, I did resolve the issue after resetting the output settings.
How to do that:
  • right mouse click on the desktop
  • select graphic options
  • output to
  • extended desktop
Maybe some changings/modification will help you too.
Stefan
Jan 31, 2009 | HP 2025 20.1" Flat Panel LCD Monitor
Please
Hola.., parece su panel están defectuosos... reparado le costará lotes de $$$... Simplemente comprar uno nuevo... salvado el headached y $$$... Tienen un buen día!
Oct 07, 2008 | LG L1930B 19" LCD Monitor
LG L1930B 19" LCD Monitor Problem... HELP
When an LCD Monitor starts to respond like this it is due to one of three reasons a power supply is not generating enough power to properly power the LCD or the LCD's backlight is beginning to burnout, and last the inverter is bad. These things all can be replaced, but it is not worth the cost! Easier and cheaper to buy a new one!
Nov 25, 2007 | LG L1930B 19" LCD Monitor
Monitor suddenly goes black
Is this monitor and LCD flat Panel? If so this is due to a bad power supply, an inverter board going bad or LCD backlight bulb blown. When the backlight goes bad it gets just enough power to start up, but when it is on for a long period of time it goes black because the bulb is not stable enough to hold the charge because it is going bad. These bulbs can be changed, but they also can be costly!
Nov 17, 2007 | LG L1930B 19" LCD Monitor
LG L1930B 19" LCD Monitor Logo
961 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
