Question about HP Officejet Pro 8500 Wireless All-In-One InkJet Printer
Officejet Pro 8500.. had a paperjam, cleared it but now everytime I scan or copy through the feeder I get a vertical line through every copy. this doesn't happen when I print or when I scan or copy on the glass just when i use the feeder. I have cleaned everything and it's not dirty, unless I'm missing something.
  • gulfcoasthat
    gulfcoasthat Sep 19, 2012
    Fixed my problem. Thanks!
    Sniper:
  • 56 Answers
Clean it again but the glass at the very left. Not the big one, the narrow one and use windex
Posted on Sep 08, 2010
Vertical lines when copying from feeder or glass - does not happen when printing from computer or scanning documents.
Inspect the glass below the feeder for ink or ink correction liquid remnants from previous scanned documents. Clean them out.
Oct 08, 2014 | HP OfficeJet Pro K8600 Printer
Vertical black line on scans or copies;
Hello James,
Please click Vertical Bands Lines or Streaks in Copies Faxes or Scans to access the troubleshooting steps that should resolve the issue.
Mar 03, 2014 | HP Officejet Pro L7680 All-In-One Printer
There is a vertical line down the middle of copies that are made through the automatic feeder. How do I fix?
Open adf unit, spray little quantity if ISO alcohol clean with smooth cloth especially small glass. ensure that when you are using ADF avoid wet whitener/glues on paper.
Sep 08, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
Failure of alignment of printheads on setup of HP 8500A
when feeder is used for scan, fax or copy, a black vertical line appears on the left side of page
Jan 11, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
I have a vertical line going through every copy when I copy or scan?
The glass may need cleaning. Clean the glass with a soft damp cloth. Make sure to also clean the strip of glass on the left side.
Sep 03, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
HP OFFICEJET PRO 8500. BLACK LINE WHEN SCANNING FROM FEEDER, AND COPYING FROM FEEDER, BUT NOT FROM THE GLASS. fROM INSPECTION, ITS A METAL WIRE THAT IS HOLDING A FEW CORDS INSIDE THATS CAUSING IT
This may be dot of dirt on the class that looks like a horizontal line when the feeder moves, to solve it, try this link from hp site: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01619149&cc=us&lc=en&dlc=en&product=3752459 it its something within the glass which you can not clean, contact the hp's repair or replacement options if it is still in warranty.
Aug 25, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
HP Officejet Pro 8500 - issue scan & copy
while the printer is on take a damp cloth and wipe the scanner glass and then open the automatic document feeder and clean the scanner glass there and then remove the cartridges and close down the printer now just pull out the power cable from the back of the product and if possible and the walljack wait for 30 secs and replug the printer first to the walljack and then to the printer,now try to scan....(if your printer is wireless then after the above you will have to run the wireless setup wizard again).if that doesn't work,try the same above but just before plugging the printer cable press and hold the power button,if that doesn't work do the same holding the #3 buttons,if this doesn't work then do the same holding down the #6 buttons,if even this doesn't work then call in to hp at 1800-474-6836 and get a replacement
Oct 03, 2009 | HP Officejet Pro 8500 Wireless All-In-One...
Thick line when goes throught auto feeder
The automatic feeder passes the page over the scanner, the scanner does move, so even a small mark (often find it is correction fluid) will effect the whole page, check the glass on the left side of the scanner for any sort of mark
Sep 08, 2009 | HP Officejet Pro 8500 Wireless All-In-One...
HP OfficeJet J5780 Vertical Black Line Prints when copying or scaning only. Cleaned rollers and changed black ink cartrigde. Still problem.
Have you tried cleaning the document feeders Scan Glass? (small glass under doc feeder ~ 1" by 9") Most times there is dirt spot on this glass, causing a shadow on scans and copies.
Try copying from the large glass by lifting doc feeder / platen cover and manually placing original. If no line copying or scanning manually from large glass, then small scan glass is deffenitely the culprit. Hope this helps.
Sep 07, 2009 | HP Officejet 5780 Printer
HP Officejet Pro 8500 Wireless  All-In-One InkJet Printer Logo
368 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
