Question about Kenmore Irons
I have a Kenmore iron that I bought several years ago and have never been happy with the amount of steam that I get when ironing. The model number is 81667, and it was bought at Sears in Halifax, Nova Scotia, Canada. Can you help me?
satscoop
  • 59 Answers
SOURCE: Brown spots coming from steam iron
you can mix 50% water with 50% vinager let it set in the iron overnight then turn it on and let the steam run out.What happens is the inside of the iron where the water is had corroded or rusted or has lime deposits.the vinager will break this loose overnight.also after you let the iron steam out all the mixture,flush the iron 4 to 5 times and start using fresh water from a store bought gallon.your tap water is probably full of iron.
Posted on Nov 15, 2007
SOURCE: Breville steam glide 2200w iron
Hello, dont know if you still have no instruction book for this iron, i have the same iron and found the instruction booklet on there website. go to breville website, and irons and download.
Posted on Jan 16, 2008
SOURCE: No steam
It appears that your rocker switch is broken, I am attempting to find a source for the switch and the screw driver that removes the screws holding the unit together
Posted on Feb 25, 2008
SOURCE: Hinari steam vapor iron Model HIN001
More complete answer...
If you are having steam problems then the cartridge needs changing.
I phoned them (0161 652 1211) and they do sell the cartridge for £5.99 including delivery but are out of stock for a couple of weeks. You have to send them a cheque or postal orders. Good luck.
Send Cheque for £5.99 for each cartridge with note of model etc.
Pulse Home Products Ltd.
Middleton Road
Royton
Oldham
OL2 5LN
Posted on Oct 07, 2008
  • 104 Answers
SOURCE: How do I register a Shark Steam Iron on line
Follow the link to register you Shark Steam Iron
https://secure.prodregister.com/euro-pro/hhappliance/yqd_1.shtml
Posted on Jun 06, 2010
ROWENTA PROFESSIONAL
Try to check the wire connecting to the switch from the steam unit,.,,
Jun 07, 2008 | Rowenta Professional DX8900 Iron
My iron is leaking water. Can it be repaired? I picked it up off the ironing board today and it was sitting in a puddle of water. It continued to pour out the bottom. Is this fixable?
I have had several do this after many many years of use. I did not find a fix but ended up buying a new model. If you do not need to use the steam function, you can still use it. Might want to use a spray bottle with water to add the steam the old fashion way.
Jan 27, 2014 | Irons
The water that is spitting out when I press the steam button is clear and boiling hot. A LOT of water comes out.
Check to see the amount of water the iron requires. If too much is added it will spit water out can also come out of where the water goes in plus the holes the steam should come out. In order for the iron to steam the water must boil inside the iron. Check the instructions and see how mmuch the manufacturer suggests. You may have to fill it several times while doing the ironing. If there is no instruction try consulting the manufacturers web site for information on your make and model of iron. They should have instruction manuals available for download. If that is not the problem it could be cracked on the inside. Give the water adjustment a try first though a lot cheaper in the long run.
Aug 06, 2012 | Irons
Sunbeam steam iron model #GCSBRS-1 does not give steam. 11/2yr old
I have had the same issue with both of these irons. I bought them both thinking they would be a "better" iron with more steam and have not been happy within the first year of owning them. Thanks for the tips.
Mar 22, 2012 | Sunbeam Irons
We have a Rowenta Model DW 8080 steam iron. Even when the steaming feature is turned off, there is a water leak in the gap between the bottom plate and the upper part of the iron.
I too have this problem. Ihave bought so my of these irons. I wish so meone else could make something that could put the steam out that this do, that would last for more than a year!!!
Nov 18, 2010 | Rowenta Irons
What happens if I use CLR in my steam iron? I have an expensive European style iron which is no longer producing steam. I have bought an iron descaler/cleaner and have repeated its use. I tried the...
The steam tank may not be heating because of mineral deposits in the tank. But also do this check first. Open up the tank reservoir cold, and drain all water out, (is it clean inside there when you shine flashlight in there? Rinse with clear filtered water only (low minerals).
Do not use CLR or anything agressive in there. You should have the main unit in full steam mode and the iron control also in full steam mode. Leave one tablespoon of water in the tank, put back together and let the pressure build. Put a clean towel on your ironing board and when iron is at full pressure and heat, hit the burst of steam and look at what comes out of the sole plate. If you see lots of white deposits look at the sole plate and see if the white chunks are coming out steam holes.
When using iron, run it till steam/water tanks are dry, the burst of steam is used in this case to clean the iron of all standing water. Pull the reservoir and allow to cool...once tank is cool drain it as well. Doing this several times should help purge unit of the heavy mineral deposits.
If you need parts, here is the Rowenta repair facility....
California Electric Service in Concord CA (it is the only Rowenta repair station in California) go to either of the following addresses:
their website is: http://www.californiaelectricservice.com/
or tech service: service@californiaelectricservice.com
Mar 12, 2010 | Rowenta DG-980 Iron
Bought iron model no 14722 less than a year ago cannot find reciept for argos how do i get new iron or repaired
You could try the store but I don't think you will have any luck. I buy most of my electrical items from one local store, so if I have lost a rec eipt they can look it up on their system. I recommend a Phillips Steam Iron GC 4430 Don't buy an iron from a supermarket.
Sep 10, 2009 | Irons
Mold
First with the iron cold fill the reservoir with white vinegar.  I would let this sit for a few hours and then pour the vinegar out of the iron. I would do this a couple of times until you see the mold is removed from reservoir. Next fill again with vinegar and run the iron on the steam setting, steaming a clean rag or towel until all of the vinegar is steamed out of the reservoir.  The vinegar will also remove any mineral deposits built up in the iron.
Next rinse the reservoir by filling it with water and emptying it completely a few times.  Follow this by filling it completely with water again and setting the iron to steam setting.  Use another clean rag or towel and steam it until all of the water has been steamed out of the reservoir.
In the future make sure to completely empty your iron after every use to prevent mineral build up and mold growth
Aug 04, 2008 | Rowenta Perfect Iron
I cannot get the iron to put forth steam when I am ironing. It isn't even a year old.
take down the iron and clean it the spring is dead probaly you can stretcth it to gain a little tension.good luck.
Nov 10, 2006 | Rowenta DX9800 Iron
Irons Logo
Top Kenmore Irons Experts
Steve
ray gallant
Tom Chichester
Are you a Kenmore Iron Expert? Answer questions, earn points and help others
