Question about HP Officejet Pro L7680 All-In-One Printer
Where can I find the step-by-step procedure for replacing the carriage belt?
3 Suggested Answers
  • 4 Answers
SOURCE: Carriage belt replacement for HP 430
http://www.fixyourownprinter.com/forums/inkjet/36780
Fifth post down.
I changed the carriage belt using these instructions.
Hope that helps
Posted on Feb 05, 2009
vinay229229
  • 1121 Answers
SOURCE: I need to know the steps to replace the carriage
Sorry to say that if you are not a tech guy, it is not suggestible to do this major work. even you want to do.. Remove carriages and print heads, remove back,lift adf unit remove side covers,ADF unit, foramtter, mechanism carriage rail,carrige assm..Ohh these many you have remove...
Posted on Sep 12, 2011
Clarify: #Error appearing immediately with sudden ****? or while carriage parking in serve station area?# remove & take out service station, place it out side(to avoid capping/wiping by cleaners)..check
# check carriage bushing warn out condition( too much play of carriage causes this error)
# trailing cable flexibility good? or its obstructing the carriage path?
# take out cutter assembly from rail.. check..
# Check carriage belt tension, adjust if required.
# Check carriage belt properly installed? re-install again
Best of luck....
Jul 24, 2012 | HP Designjet Z6100 InkJet Printer
I need to know the steps to replace the carriage belt for a hp all in one L7780 printer
Sep 11, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
How to replace 2001 hyundai elantra timing belt
Replacing timing belt, requires complete step by step procedure, its not very easy process, but if there is exact procedure, then it gets easy to do this job.For complete step by step procedure with details and diagrams of replacing timing belt of your 2001 hyundai elentra , click this link below :---- http://howtobyme.blogspot.com/2011/08/how-to-replace-timing-belt-on-2001.html -------- This will help.Thanks.Helpmech.
Aug 20, 2011 | Hyundai Elantra Cars & Trucks
How can I replace the belt for the ink carriage
Here is an HP Support Forum where a user has posted a detailed procedure for the belt replacement.
http://forums11.itrc.hp.com/service/forums/bizsupport/questionanswer.do?threadId=846691
The Service Manual is needed. It's available at:
http://www.hylink.com/PrinterManual.html
Designjet 430, 450, 455C - Service Manual
DesignJet 430, 450C, 455CA - Quick Reference Service Manual
As mentioned, it's a delicate and time consuming operation. I replaced my belt two years ago with little problem. (Be sure to clean the old degraded belt gunk off the drive pully too!)
It's not a job for "Beginners". More like "Intermediate" or "Advanced".
Good Luck!
This is the part I ordered. It was $15
WARNING: THIS IS FOR THE "E-SIZE" MACHINE.
If you have the smaller one, you must research the part number for that.
Carriage belt (E-size) - Long/wide belt attached to the carriage 15.00 0.00 15.00 1 15.00
Oct 21, 2009 | HP DesignJet 450c InkJet Printer
Use the carriage replacement procedure in the service manual. Download here: www.lpscomputer.com/ec/manuals.htm
Aug 10, 2009 | HP DesignJet 500ps (42 in.) InkJet Printer
How do I replace the carriage belt?
From the service manual:
1. Remove the Left Hand Cover
2. Remove the Right Rear Cover
3. Remove the Right Hand Cover
4. Remove the Tensioner Assembly
5. Pull out Printhead Cleaner Carriage
6. Slide Carriage Assembly to position shown.
7. Lift up the Carriage Cover and remove ALL the Printheads and close the Carriage Cover.
8. Slide the Carriage along the Printer to the position shown.
9. Push in the 2 retaining clips either side of the Printhead Tube Connector.
10. Pull the Printhead Tube Connector towards you.
11. Push the button to release the Printhead Tubes in the Carriage.
12. Release the retaining clip by pulling it away from the holding brackets.
13. Pull the Printhead Tube Connector up between the two Tube Guides.
14. Slide the Carriage to the left side of the Printer.
15. Unclip and remove the Carriage Cover to access the Trailing Cable in the Carriage.
16. Carefully disconnect the Trailing Cable from the connectors in the Carriage PCA. NOTE Remove Trailing Cable
Ferrites if they fall into the Carriage.
17. Remove the Trailing Cables from the Trailing Cable Holder.
TIP Press the Trailing Cables firmly in the center to release.
18. Slide the Trailing Cable Guide out of the Carriage.
19. Slide the Carriage (including the Belt) to the left and out of the Printer.
20. Remove the Belt from the Carriage by releasing it from the retaining clips underneath the Carriage.
As you can see it looks to be a long process. I have the reinstallation instructions as well. If you still want to carry through with this, let me know and I'll send you the service manual....it will be easier than posting the text and the pictures that go along with each step.
Thanks and please take a moment to rate this solution as fixya.
Mar 16, 2009 | HP Designjet 5500 (42 in.) InkJet Printer
Fifth post down.
Hope that helps
Jan 08, 2009 | HP DesignJet 430 InkJet Printer
HP designjet 800
I wrote in about this problem earlier and have found the solution to my problem. There is not notes in the manual nor are there any cautions in any instructions for this procedure and of course HP was as useless as they always are. In my care I found that when you remove the carriage to replace the belt that when you remove the shims for the slider rod on the left and right side of the carriage that it is very important not to mix up which one was the Left and witch was the right. Of course the shims can only be inserted one way but will fit either side. if you look at them one half is fatter then the other so if you reverse them then the carriage is loose so it slightly shifts when the carriage goes from right to left making it impossible for the line sensor to read the marks properly. To fix the problem there is no disassemble required just move the carriage to the center and remove the screws that hold them then slide them out and swop sides put the screws back.
Jun 09, 2008 | HP DesignJet 500ps (42 in.) InkJet Printer
CANON IMAGE PRO W6400
This error code is a Carriage motor error. Below is the outline for what to check and what to repair/replace. Good luck.
Cause
This is displayed when a jam or other physical problem puts an excessive load on the carriage motor so that the carriage could not operate.
This is displayed when the carriage motor could not reach the prescribed speed within the prescribed time.
Probable problem locations
Foreign object in carriage movement path, carriage rail, carriage belt, linear scale, linear encoder, carriage motor, engine controller, system controller
Remedy
1. Carriage movement path check
Remove any foreign objects (jammed sheet) in the carriage movement path.
2. Carriage rail
Use rail cleaner to clean the carriage rails if a visual check reveals that they are dirty.
3. Carriage belt
If a visual check reveals slack in the carriage belt, remount the belt.
4. Replace the linear scale.
5. Replace the linear encoder.
6. Replace the carriage motor.
7. Cable connection check
Replace the cable between the carriage motor and engine controller if the connection is not functioning normally.
8. Replace the engine controller.
9. Replace the system controller.
Feb 12, 2008 | Office Equipment & Supplies
HP Officejet Pro L7680 All-In-One Printer Logo
734 people viewed this question
Seeker5211
Seeker5211
