Question about Goodman CKL60AR60 Air Conditioner
Blower not working.. - Goodman CKL60AR60 Air Conditioner
  • Goodman Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Posted on Sep 08, 2010
2003 trailblazer blower not working
Are you saying the blower motor would run intermittently and then just stopped working? My first thought is faulty blower motor, I've seen faulty blower motors that would run intermittently. Any motor that uses brushes, you can tap on the motor to see if it will start working, that is a sign of bad motor brushes, replace the blower motor. There could be other issues?
Did you check the blower fuse, not only check the fuse, check the fuse circuit for voltage, use a test light. Check for applicable hvac trouble codes. With hvac on, check for voltage and ground at blower motor wiring connector, if both are good and no blower action, suspect the blower motor.
May 13, 2017 | Cars & Trucks
98 buick heater stop working
Its faulty blower motor resistor. The low and medium speed on blower motor is controlled by resistor and its actual speed is high. So because resistor is not working, blower motors actual speed which is high is working.
It can be faulty blower motor or faulty blower motor resistor. Get the blower motor inspected. If it's faulty it has to be replaced.
For blower motor testing and replacing, check the link below: ----
Blower motor Testing/replacing for all vehicles?
http://repairhelpcenter.blogspot.in/2012/02/blower-motor-replacing-for-all-vehicles.html
These will help.
Thanks.
Dec 14, 2012 | 1998 Buick LeSabre
Heater is not working
HEATER BLOWER MOTOR
These will help.
Thanks.
Nov 28, 2012 | 1988 Honda Accord 4 Door
1996 SILHOUETTE BLOWER WILL NOT WORK
of the blower motor makes a howling or grinding noise the motor is going bad. blower control modules are common and will not give you all the blower speeds.
Dec 13, 2009 | 1996 Oldsmobile Silhouette
When I turn on Blower the ac lt comes on but the
could be the blower motor or the blower motor resistor. if its the resistor the blower will usually work on high only with the settings not working. if it doesnt work on any setting it may be the blower motor itself
Oct 25, 2009 | 2003 Buick Century
2000 Wrangler blower won't work
HOT WIRE BLOWER MOTOR IF IT WORKS PROBLEM IN THE BLOWER RELAY AND RESISTOR.IF BLOWER DONT WORK REPLACE IT.
Sep 02, 2009 | 2004 Jeep Wrangler
A/c blower; inop
Check for power at blower motor connector with a/c on and blower on low if you have power I would suspect blower motor.
Jul 05, 2009 | 2004 Ford F150
Blower motor wont work
Disconnect connector at blower under pass side of dash.Check for power & ground with the blower switch in the #4 speed (High).Most Likely a blower motor if all 4 speeds are out.If high works but no other speeds,you need a blower resistor.Blower easy to change 3 screws & one connector.hope this helps
May 19, 2009 | 1993 Saturn SL2
Blower Motor not working
hello the problem your having with the blower motor sound like the blower itself the brushes could be worn out causing the extra load on the blower resistor you may need to have a blower motor installed hopefully you won't need the resistor hope this helps you
workitover
Jul 24, 2008 | 1997 BMW 328
Goodman CKL60AR60 Air Conditioner Logo
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
