Sony kdl-40s2530 error code flashing 9 times - Televison & Video
waynejamescm
  • 67 Answers
SOURCE: tv bravia kdl 40v3000 problem turning on
Unfortunately, this is a failure of the balancer board for the backlight. The unfortunate part is that the balancer is not available by itself anymore, and the whole panel must be replaced, as Sony only has the balancers attached to new panels. You can contact Sony directly to ask for assistance, and it usually helps.
Hope this helps you...
Posted on Jan 05, 2009
  • 4234 Answers
SOURCE: Sony Bravia KDL-40W4500 turns off
This can indicate a problem with the high voltage circuits. Since this is a new set, it should still be under warranty. DO NOT open up the unit as that will void the warranty. Return the set or request warranty service. Note the 8 blinks when you request service as that should allow them to bring the correct replacement parts.
Keep us posted.
Dan
ltfrc
  • 227 Answers
SOURCE: I have a sony LCD tv Model Number KDL-46V2500.
Try this link vor blink code info.
http://www.agoraquest.com/viewtopic.php?forum=70&topic=31721
Posted on Jun 11, 2009
SOURCE: KDL-40XBR3 turns itself off; STANDBY light flashes 9 times
sony 52 inch tv in stand by mode comes on and off on its own
Posted on Sep 14, 2009
SOURCE: Sony TV flashes 13 times and stops
I, too have a KDL52 also less than 2 years since purchase and have the same problem this morning 2009 Oct 2
Posted on Oct 02, 2009
I have Sony Bravia model KDL-55NX720 & it won't turn on.It has 5 blinking red lights.According to a diagram that I found for this TV, I have replaced the TCon Board and the LED Panel. Any suggestions?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Jun 14, 2016 | Sony BRAVIA KDL-55NX720 55" 3D LED-LCD TV...
What's six red blinks at sony tv?
Hi, [Error code 6. LED flashes 6 times]. Malfunction of inverter or overcurrent protection....regards Sean
Jan 15, 2016 | Sony BRAVIA KDL-32BX330 32" 720p HDTV with...
Sony Bravia KDL-46W3000 - Shuts off after 30 sec followed up with 6 red blinks.Last 3 days back cover off has been working fine. What board should I be replacing?
Sony Bravia TV kdl- red blinking led light error codes ...
? 10:28
https://www.youtube.com/watch?v=0KGysXbxnaU
Mar 28, 2015 - Uploaded by Tampatec
Sony Bravia LCD TV KDL models red blinking led light error codes & possible ... with perfect picture, no warning signs and it just shuts off. is it that quick? ... with the following problem: I connect the power grid lights Standby red light. ... the title before deleting, it is very fast after that flashes Standby 6 times.Missing: 46w3000 ‎30
Nov 18, 2015 | Sony BRAVIA KDL-46W3000 Television
Latest software update kdl55nx720
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Oct 11, 2014 | Sony BRAVIA KDL-55NX720 55" 3D LED-LCD TV...
The standby indicator is flashing 4 times on my sony bravia KDL55nx720 tv and will not start. Is there something that needs to be reset?
These blinks [flashes] are fault indication (Error Codes).From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it.This will make repair easy.These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times.Count it carefully.If you wish to get some details, check the site linked here.It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.Viewing it in "Mosaic" or "Sidebar" will make surf easy.
Blinking codes details to many popular brand TVs are given.Surf the site with patience.
Aug 09, 2014 | Sony BRAVIA KDL-55NX720 55" 3D LED-LCD TV...
Led blinks 9 time
You will need to check out the system fan for proper operation as that is what the self diagnostic of 9 LED flashing sequence means on a Sony LCD TV.
Good Luck!
Rich Lilja
Mar 31, 2014 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Hi! I have a Sony KDL-40s2530 that stopped working properly. When turned on the picture goes on for about a second then it turns off and the red light at the lower right starts blinking four times with...
Most likely this:
4X Blink error code = Balancer Error
The 4X blinking error code is used on models which have a dimming LED backlight.
If a failure happens the TV will shut down and display this diagnostic code.
Contact Consumer Electronics support for repair options.
http://esupport.sony.com/US/p/support-info.pl?info_id=932
Oct 20, 2017 | Sony Televison & Video
Hi got sony bravia 40s2530 40 inch tv,woz workin fine but wen turned bac on came on 4 a few seconds then red flashing light 4 flash then 3 sec brk & 4 flash again & so on!any ideas?
You can fix this yourself , having basic knowledge on electronics will make it easy but not withstanding you can get it a try.
Your power supply board is dead, u know basic electronics’ and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Take care and this help in solving the problem
Sep 13, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Jun 01, 2009 | Sony BRAVIA KDL-40XBR3 40 in. LCD HDTV
Bravia error code flashing 3 times
this problem is caused by an ABNORMAL PANEL VOLTAGE. led flashes are a self diagnostic tool for sonys. their chart points to bad inverter board
Feb 20, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Televison & Video Logo
549 people viewed this question
Top Televison & Video Experts
Electro Med Services...
