Question about Sport & Outdoor - Others
Sportek Magnetic Resistance Elliptical Machine
5 Suggested Answers
SOURCE: the resistance on my Precor elliptical 5.17 will
There is a small motor under the shroud that operates the resistance motor. It is about the size of a roll of half dollars. Have someone use a meter and check that you are getting power to this. When you turn on the machine the motor should move the resistance forward then back. You can hear this everytime you turn it on.
Posted on Mar 11, 2010
taran_2005
  • 10515 Answers
SOURCE: We have a REFLEX Step
I had a similar problem recently with my elliptical - it was permanently stuck in the "hard" position. In my case, it has a wheel that turns when you step, and the tension is adjusted by a pair of magnets inside this wheel assembly. These magnets are positioned near the wheel - closer for more tension or further for less tension.
The console control electronics that send a signal down to this wheel assembly. There is a little motor that pulls on a short cable to position the magnet(s).
The problem was that the cable attached to one of the magnets snapped, leaving that magnet close to the wheel, i.e. high tension. We had to have a technician order and replace the entire wheel assembly as its individual pieces are not made to be serviceable.
It sounds like your case might be similar. Maybe you only have one magnet or two. In any case, I'd look at whether the magnet(s) are moving relative to the wheel when you adjust the tension settings (you should be able to see or hear the magnets move - you might need a buddy to help).
While you may not be able to repair it yourself (you can get yourself pinched badly around these gears and mechanical elements), you will at least know what's going on so you get the right work done if you choose to hire someone.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 01, 2010
ercupa190
  • 12223 Answers
SOURCE: why does the resistance on my elliptical randomly go to OFF while working out
Do this for your console Elliptical:Removethe bolts or screws securing the console to the upright assembly. Lift theconsole and confirm that the cable connections are secure. Remove the coverfrom the console's battery bay and install a fresh set of batteries. Replacethe battery cover.2
Detachthe ends of the pedals from the crank axles. Remove the left and right discshields and side shields. Inspect the interior of the base unit and locate theflywheel.3
Inspectthe flywheel as it turns. Locate the magnet installed on the flywheel. Turn theflywheel until the magnet passes in front of the nearby reed switch. Loosen thescrew securing the switch in place. Rotate the switch to reduce the gap betweenit and the magnet. Tighten the screw.4
Replace the left and right disc shields and sideshields. Reattach the ends of the pedals to the crank axles
Good luck, sincerely. G-d bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Posted on Dec 06, 2011
ercupa190
  • 12223 Answers
SOURCE: resistance not changing on reebok elliptical
ADJUST THE MAGNET, AND REPLACE IF NECESSARY YOU CAN TEST THE MAGNET AGAINT THE MAGNET DOOR FROM YOUR REFRIGERATOR, VS REPULSION +ATRACTION IF DO NOT PASS THE TEST REPLACE. READ YOUR INSTR. MANUAL OR DOWNLOAD FROM WWW. ICONSERVICE.COM
GOD BLESS YOU
Posted on Oct 02, 2012
My cx1055 elliptical resistance is not working how it should. Once I get to resistance lever 4 or higher it starts out with the resistance but then it slips as you step into it. Any suggestions?
Nordic Track Nordictrack Cx1055 Elliptical Incline Motor For ...
www.fixya.com/search/p3944353-nordic...cx1055_elliptic/resistance
Nordic Track Nordictrack Cx1055 Elliptical Incline Motor For Model Number 285090, ...the bolts that secure the magnet4=if there are slips, the resistance will . ... my schwinn 460 elliptical resistance cannot be changed When I increase the ... Every time I increase the resistance it will go to that level of resistance but within a ...
Need someone to install a new resistance motor on a Nordic ...
www.shopyourway.com > Manage My Life > Questions
Aug 10, 2013 - I bought a CX 1055 Nordick Track elliptical at a garage sale. I noticed that the resistance doesn't really change between levels. ... 100 dollars, but how much would it cost to have someone come out and do the replacement for me? ... I wonder if maybe something shifted when I brought it to my apartment?Missing: slips
[PDF]View Manual in PDF Format - NordicTrack
https://service.nordictrack.com/.../pdfDownload.do?...2...
NordicTrack4. Place the elliptical exerciser on a level sur- face, with a mat beneath it to protect the... The CX 1055 elliptical exerciser is an ... 1055 elliptical exerciser features adjustableresistance ..... press the Odometer button again; the words "My.
Jan 05, 2016 | Exercise & Fitness
My digital screen on my 420 elliptical schwinn blinks on and off
replace batteries and proceed with this steps and fix it. God bless you
Check power problems if the console on the elliptical machine does not light up. Make sure that the plug for the machine is secure in the outlet. If it is plugged in, ensure that the outlet is receiving power. Check the breaker to make sure it has not tripped off.
Be sure that you are using the correct adapter that came with the elliptical machine. Because different adapters are able to handle differing amounts of energy, the wrong adapter will not transfer electricity like it should. If the adapter is pinched or damaged, this could also alter its effectiveness.
  • 2 Make sure the correct adapter is being used if the resistance settings seem to be too hard or too easy. If the correct adapter is being used, reset the machine. To reset the machine, either switch the "On/Off" button or unplug the machine from the wall. Doing this will allow the device to reset itself to the default resistance. Turn on or plug the device back into the wall and retry all of the levels of resistance.
  • Read more: http://www.ehow.com/how_6149016_troubleshoot-elliptical-machine.html#ixzz2gVxyHBXj
    Oct 01, 2013 | Exercise & Fitness
    Schwinn 420 elliptical
    follow this steps and replace batteries and clean the contacts batteries. God bless you
    • Check power problems if the console on the elliptical machine does not light up. Make sure that the plug for the machine is secure in the outlet. If it is plugged in, ensure that the outlet is receiving power. Check the breaker to make sure it has not tripped off.
    • 2
    Life Fitness X3 does not turn on. So I can't set resistance nor intervals with console. Plug was checked and is fine.
    follow this steps and fix it.
    God bless you
    • 2
    Sep 30, 2013 | Life Fitness X3 Elliptical Cross-Trainer...
    Elliptical resistance
    Be aware that the resistance is often the part that requires repair. Resistance is managed magnetically, so often if the machine is working, but the resistance isn't setting correctly or at all, check the bolts that secure the magnets. If they are loose, the resistance will slip. If the bolts are fine, check the magnets themselves by using a refrigerator magnet and see if it is attracted or repelled by the your fridge magnet. If not, the magnets have de-magnetized and need to be replaced.
    God bless you
    May 22, 2013 | Xterra Fitness Xterra FS220e Elliptical...
    My schwinn 460 elliptical resistance cannot be changed
    see the following details. God bless you
    Dec 04, 2012 | Schwinn 460 Variable Stride Elliptical...
    Bladez elliptical
    see the steps and fix it. God bless you
    Adjust the magnet with bolt attached there are loose, tight very well and ready the resistance is the main parts that need repair,
    However if the resistance is faulty, you must test again the magnet from the refrigerator by attracting or repeled, if do not pass this test replace it buying small cheaping from home depot or similar.
    GoD BLess you
  • 1 Check your owner's manual for diagrams and definitions. You'll need this information when you put the elliptical back together. You'll also want definitions in case you need to call the customer support line for assistance.
  • 2 Be aware that the resistance is often the part that requires repair. Resistance is managed magnetically, so often if the machine is working, but the resistance isn't setting correctly or at all, check the bolts that secure the magnets. If they are loose, the resistance will slip. If the bolts are fine, check the magnets themselves by using a refrigerator magnet and see if it is attracted or repelled by the your fridge magnet. If not, the magnets have de-magnetized and need to be replaced.
  • Sponsored Links
  • 3 Consider that if the foot pedals are attached with bolts, any slipping can be fixed with a quick use of the wrench. But if the foot pedals are damaged or breaking, order new foot pedals (see Resources below) rather than run the risk of a pedal breaking while you're on the machine.
  • 4 Check the hand bars. While not all people use them, as they can elevate your heart rate by up to 20 percent, they can become worn, too. While loose hand bars typically need a simple tightening of the bolt, be sure not to overtighten as the bolts can break.
  • 5 Know that if the axis is bent, it's likely you need a new machine. The axis is the central alignment of the elliptical. If the machine was used by a person who is over the maximum weight limit, it can be bent or damaged. It's not an easy fix and a better idea is to upgrade to a sturdier machine.
  • Read more: How to Fix an Elliptical Machine ' eHow.com http://www.ehow.com/how_4681374_fix-elliptical-machine.html#ixzz2DLrv9YSH
  • Sponsored Links
    Nov 25, 2012 | Bladez X350P Elliptical
    Proform 405 CE Elliptical display and Silent Magnetic Resistance control stopped working
    1) adjust magnet with the bolt looses with a wrench, tight very well.
    2) proof the magnet for attraction or repulsion with the magnet from your refrigerator, if NOT pass the test replace it.
    God bless you
    Jul 24, 2012 | Exercise & Fitness
    How do I fix my crosstrainer, magnetic resistance has stopped working
    This happened to me and I took the wheel mechanism cover off to discover the tension motor cable had come out of it's pulley guide- so there wasn't enough tension left in the cable to pull it away from the wheel- quite an easy fix for me- hope it is the snake for you!
    Feb 15, 2012 | Exercise & Fitness
    The resistance on my Precor elliptical 5.17 will not increase. All other functions on the machine work. Any ideas?
    open shroud and find the circuit board unplug and plug back in all connection this may sometime clean any oxidation off the connector. this is what I've in their 546's should work on the 5.17
    Feb 28, 2010 | Precor EFX 546i Elliptical Version 4
    Sport & Outdoor - Others Logo
    Top Sport & Outdoor - Others Experts
    Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
