Question about Konica Minolta bizhub 350 All-In-One Laser Printer
My Bizhub 350 is saying malfunction dectected C3452
  • 1,110 Answers
This code means you have a fuser warm up failure. The fusing unit uses heat and pressure to "fuse" the toner onto the paper. It is located right where the paper exits the machine. Here is the info directly from the service manual:
The Fusing Roller Sub Thermistor does not
detect the required temperature within 30 sec.
after a warm-up cycle has begun; therefore, the
copier does not complete the warm-up cycle.
• The temperature of the Fusing Rollers does not
reach the required level even after the set period
of time has elapsed during a warm-up cycle.
Most likely you have a thermistor failure in the fuser. You are going to need to call your local service company and have them repair then reset the machine.
Good Luck and Thank You for using Fixya.
Posted on Sep 08, 2010
My konica Minolta bizhub 350 saying malfunction 3452
Posted on Jan 25, 2011
4 Suggested Answers
SOURCE: konica minolta bizhub 350
• The Fusing Roller Sub Thermistor does not
Check that the H1[ fuser lamp] comes on when the Main Power
Switch is set to ON, and correct or replace as necessary.
Check that the H2 comes on when the Main Power
Check the installation of the TH1 and the TH2, and
correct or clean as necessary.
Check the operation of the TH1.
Remove CN80 (4P), and then check that the resistance
across CN80-2 and -3 on the Thermistor is
infinity.
5
Check the operation of the TH2.
Remove CN81 (4P), and then check that the resistance
across CN81-2 and -3 on the Thermistor is
infinity.
6
Check the continuity of the H1.
Correct or replace as necessary.
7
Check the continuity of the H2.
8 Change PU1 - -
9 Change PWB-A
Posted on Nov 19, 2007
taminol
  • 62 Answers
SOURCE: when I turn on the machine (bizhub c300) error
This is a fuser related code.
To reset the code, please do the following
1. Turn OFF the Main Power Switch.
2. Turn Main Power Switch ON while pressing the Utility/Counter key.
3. Touch Trouble Reset.
4. Check to make sure that OK is displayed and the it has been reset.
5. After turning off the Main Power Switch, turn it on again more than 10 seconds after
and check if the machine starts correctly.
Good luck
Posted on Jan 29, 2010
duttabid
  • 69 Answers
SOURCE: malfunction with error code C3452
HI, If its a hardware malfunctioning then go to nearby service center of contact customer care but before that you can try to reset the device to factory settings or if it's a software isue then you can try reinstalling the drivers from google, its simple.
Posted on Jul 29, 2010
C 960 malfunction error
no go on that code for bizhub 350 missing a number normally it C-xxxx
Mar 15, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
Malfunction detected c 3301
No such code for a Bizhub 350. What model is it?
Sep 19, 2013 | Konica Minolta bizhub 350 All-In-One Laser...
Error c3452
error c3452 is fusing warm-up failure.
first do trouble reset.
second, check H1 or H2
third, check TH1 and TH2
four, change new fusing unit
five, change PU
six, change PWB-A
Sep 14, 2013 | Konica Minolta bizhub 350 All-In-One Laser...
Error c3452
Power off the machine wait ten seconds then holding the down the clear/stop button power on the machine. should clear the code if the code comes back replace the fusing unit the hot part!
Jul 23, 2013 | Minolta bizhub 200 All-In-One Printer
C3452
hi ali... the problem with your mfp is fixing uunit warm up failure... try to perform trouble reset... turn off the machine, then hold press the utility/ counter... konica minolta logo appears... press 3, type eight 0's then then tuoch "end" then touch "trouble reset"( note: dont touch other menu displayed on screen because you might get another problem.) then the machine will re-statr.....If there is an abort code, there its time for you to change the fixing unit.... ( if you know electronics try to check the heater lamp and thermostat using a multitester, check if there is a continuity inthe both ends...)
Apr 29, 2011 | Konica Minolta bizhub 350 All-In-One Laser...
Malfunction with error code C3452
Jul 29, 2010 | Konica Minolta bizhub C250 All-In-One...
Error C3452 right after power on.
I assume this is a Bizhub, Fusing unit fault. to clear you will need to look on the right side of the machine, if this machine is networked?, just below the scanner, on the right side is a small cover it will come off close to where your network cable goes. once it is open press the small black button (Looking at the machine from the right side it will be on your left using a paper clip or small screw driver just gently depress the button the machine will go thur its cycle you will get a Trouble reset on the screen with a "OK" touch then power off, wait ten seconds then power on
May 28, 2009 | Minolta Office Equipment & Supplies
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
1,586 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
