Question about GE (PSS26MSRSS) Side by Side Refrigerator
My ge refrigerator model # gss23Qsta ss has slowly over a week has increased temps. in freezer and fridge. Temps are now 24 (freezer) and 44 (fridge) and holding for past 2 days. Digital temps are set at the correct temps. 0 and 37. We have unplugged and then replugged cord, cleaned dust off back vents, etc. Nothings working. Fridge has also lost its loud 2nd gear sound just a low fan noise now.
  • GE Master
  • 8,220 Answers
Maybe the defrost heater or terminator has failed and iced up the evaporator.
PSS service manual.
More about defrost systems
Posted on Sep 08, 2010
We just bought a GE gbe21dgkarww we are having trouble wth the crisper, they are freezing my fruit and vegetables. Temp. Cool on freezer on coldest
Fridge temps are actually cooled by the freezer,try turning freezer temp down somewhat-and I highly recommend buying a fridge thermometer,generally speaking I try to keep my fridge at about 34-35 degrees,you can go SLIGHTLY higher,is fridge section directly over freezer??
May 09, 2017 | GE Refrigerators
Ge profile bottom freezer model # PGSS5NFXA SS. Got up this morning and freezer thawing both fridge and freezer same
Not sure if the compressor is running. If not, you'll need a repair man. Since fans are running, most likely the thermistor. Also, if you haven't unplug from the wall, wait 10 seconds then plug back in; this may reset the control board. The link below may help. GE Refrigerator Not Cold Enough
Feb 03, 2015 | GE Refrigerators
Ge bottom freezer not freezing
Check to see that the evaporator is not covered with layer of ice. The latter serves as an insulator and prevents freezer temps from going down to about zero degrees. If the defrost heater/timer is defective that will certainly be a cause. Since the freezer air is not cold enough to freeze, then the refrigerator temps are also high. Using a digital thermometer will confirm this.
Leaking door gaskets can also be responsible for higher internal temps
May 17, 2014 | GE GFSF6KKYWW 25.9 cu. ft. French-Door...
How to set temperature on GE Profile PSS26NGPA WW?
Press and hold temp up button then press quick freeze button at the same time, your temp settings will be displayed on display for fridge and freezer, fridge temp is + and freezer -, cycle by pressing quick freeze, set temps by up and down temp buttons, once done, push vacation button. your temps are now set, turn the unit off for 2 mins the turn on. reaction is now set and normal. regards Russ
Jul 03, 2012 | GE Refrigerators
I have a GE Adora M# DSF25KGTABG. Set temps on the freezer door to 0 and 37. runs great for a few days then drops down to -9. I have replaced all thermistors and the mother board. What would be the next...
I have the GE Adora DSS25KSTB ss and the temps will not hold to cool temp.
We set it at 0-25 and the refg to 35 and sometimes it will cool to that temp and then sometimes it is a lot warmer.
Dec 29, 2010 | GE Adora DSS25KSTSS Stainless Steel Side...
May freezer temp 20F, and refrigerator's temp 47
Im guessing you have a maytag refrigerator. If this is a side by side model, one of the more common problems that cause the fridge side temps to increase, followed by a freezer temp increase, is likely due to a faulty adaptive defrost control failing to switch the unit into the defrost cycle. There are other possible reasons, but with your limited info, cant be sure
Feb 14, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Water was frozen all inside the freezer and fridge temp was high
Self defrost mechanism may have an issue. If it stays on too long you will have excessive temps build up in refrig as well as freezer. There is also a defrost thermostat that is supposed to turn compressor back on when temps get too high - check that out also.
Apr 14, 2017 | GE Profile PSW26P Stainless Steel Side by...
GE Fridge: PSS26SGPA SS Model
CallMe-
Your "freezer" and "refridgerator" temps are not jumping back to 14 and 44 respectively. When you change temps, they both wait 3-5 seconds before they revert back to a temp reading, not a temp setting.
Does your "freezer" make any loud or thumping noises? If not, do you hear a quiet whisper when both compartment doors are closed?
Solutions could be :
1. Servicing the coolant (might have a small leak)
2. Checking the seal on your freezer compartment (black rubber that meets the metal frame)
3. Your internal cooling fan is not operating and needs replacing (but I think your temps would be significantly higher).
Best of luck.
Jul 28, 2008 | Refrigerators
Flucuating temps/constant running
yes its very important to have clean coils at the back it will run better
Jul 13, 2008 | GE PDS22SBRLSS Bottom Freezer Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
627 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
