Question about Dyson Vacuums
Power head not working cutting out. where can I get it repaired in Delta B.C. 3year old canister
  • 52 Answers
If you bought your Dyson new it is still under warranty. Here is a link to Dyson warranty information http://www.dyson.com/support/
Posted on Sep 09, 2010
Why is my power head not working
You either have a broken power cable going to the head or your canister isn't supplying power to the head, or the motor for the head it bad.
Dec 13, 2015 | Shark Professional Canister Vac - EP754 -...
There is no power to my Filter Queen power nozzle. I have cleaned the connection and there is still nothing.
There is an electrical connection at the canister end and again at the beater end. If the beater is not working it is mostly that this is where you problem is. You need to test first to see if there is power at the canister end and then at the beater end. If there is no power at the canister it could be the outlet or something internal. If there is no power at the beater end then that outlet, or the cord could be the problem. If you have power and that end then the problem is likely within the wiring in the beater or in the motor itself
Jan 20, 2015 | Filter Queen Majestic Canister Vacuum
The power head of my DC 21 keeps cutting off as soon as I start moving the hose around. The only way to get it going again is to step on the main switch on the canister, then the whole cycle of off and on...
not much. my only suggestion is to dig through the internet and try and find that pcb it may take awhile but it would be worth a shot. if you dont think you can make the repair take it to repair shop with new pcb and let them do it.
Jan 17, 2013 | Dyson Genuine DC-21 "Stowaway" Spare HEPA...
Head won't work on dc 11
1) test the outlet wall with another devide such LAMP, if work is o.k
2) the problem will vacuum power : a) test the switch b) motor itself repair or replace.
God bless you
Sep 27, 2012 | Dyson DC11 All Floors Bagless Canister...
I have a kenmore vacuum, Series 116-23613300. four years old. It is emitting a high pitch squeel. I have checked and the hose is not clogged, I have put in a new bag and I have washed the foam filter. ...
If the squeal is coming from the canister portion of the machine, then you most likely have a fairly serious motor/fan problem. There are no moving parts on that machine other than the fan/motor assembly in the canister.
A local service center could confirm that. You can try to get a free quote if they offer such a service. Many may charge a fee even for diagnostic work.
If the noise is coming from the power-head, then there are multiple possibilities ranging from bad brushroller bearings to failing power-head motor.
Apr 04, 2011 | Kenmore 25512/ 25513 Progressive Canister...
I was vacuuming under my dresser using the large power head and I bumped the power head against the dresser and it stopped working.
If it doesn't work after depressing the reset button, a wire in the power nozzle may have been knocked loose. If that's the case, it will need to be taken to an authorized Aerus Electrolux store for repair.
Jan 27, 2011 | Electrolux Guardian Bagged Canister Vacuum
Kenmore Powermate power head not working
I've got the same problem. Try checking out the electrical connection where the hose attaches to the canister. The hot male terminal is corroded and the female socket is burned out. Its an unfortunate design flaw that every time you open the vacuum to replace the bag the electrical connection disconnects and reconnects. Not sure if I can find replacement parts for a 10 year old vacuum or if a home-made re-wiring job is in order. Will find out tomorrow.
May 30, 2010 | Kenmore 23612 Progressive PowerMate Bagged...
My power head on my Kenmore canister sweeper dont work right.How do I get it apart and fix the problem?
Try pushing the reset button on the top of the power head first. There is a protection system on Kenmore canisters that protect the belt from breaking, and if something was vacuumed up into the head, it will cause this reset switch to activate to protect the belt. On the top of the power head look for the a small red button, or a grey button that says overload protection switch, and push down on it.
If the power nozzle lights are coming on, and the machine is making noise, then this means that the belt may be off inside the head, however if you're not getting any power, and the head light is not coming on, then this is probably a bad hose on the unit.
I have written a detailed repair on how to replace the belt on the Kenmore canisters on Fixya, just follow the link below. The only difference on the one I helped repair and yours may be the that the screws are actually located on the bottom of the power nozzle rather then underneath of the headlight cover. The other steps will be the same, just unscrew the screws on the bottom of the power head.
Here's the link:
http://www.fixya.com/support/t4499227-need_replace_belt_in_kenmore_vacuum
Please let me know if this didn't fix it, and I'll help you walk through this further and help you diagnosis the power head further.
Thanks,
Chris J.
GoVacuum.com
Apr 13, 2010 | Kenmore 23612 Progressive PowerMate Bagged...
Power Head for Electrlux Oxygen Ultra
I work for Aerus Electrolux. My office # 570-326-1731 Call me and I will help you order the part. Liz
Feb 26, 2008 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Losing power to stick/floor vacuum
if you have an extension wand, the replacement will cost about $100.00. there is a way to repair both the pwr-cord on the brush assemble and the wand, but it depends on how much damage there is. also you need to check the contacts where the wand connects with the handle,and the prongs on the handle.
let me know if you still need help
Jan 11, 2008 | Kenmore 25614 / 25615 Progressive Bagged...
Vacuums Logo
322 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
