Question about Zenith D52WLCD 52" Rear Projection HDTV-Ready Television
Replace lamp screen comes on everytime I turn on tv. have just replace lamp but the screen still comes on how do I shut it off
  • Zenith Master
  • 8,457 Answers
Ur tv some how is setting on sleeping timer is on.Goto ur tv Menu.Resetting everythings all functions in the Menu.This will stop the auto on.
Posted on Sep 08, 2010
Hi, I have a Mitsubishi wd-57733 dlp tv that shuts down
Ballast is possible if repeated lamp failure but I have a solution I posted several times for this type of problem that works and is simple to try:
http://www.fixya.com/support/t12296849-turns_off_shortly_after_turn?mt_f=viewFull162
Apr 30, 2012 | Mitsubishi WD-57733 57" HDTV
We have a mitsubishi 735 series tv. When we power it on the mitsubishi sign comes on then the tv shuts off. We replaced the lamp bulb but that wasn't the problem. Any suggestions
Most of these sets that come on with the blue screen and logo and shut off shortly after may have two resets---I can tell you the soft reset.
Turn set on with the Mitsubishi remote and when screen comes up blue with logo:
Menu, 1,2,3 enter
This applies to most of these sets.
Mar 14, 2012 | Mitsubishi WD-60735 Projection Television
Flatron w1934s display problems; symptoms are black screen after 2 sec's of power up. i have tried wiggling the monitor cable/nothing, did notice if i unplugged the monitor cable you can see the screen...
hi good day
before you come up that the main board was the problem lets verify first to narrow down where the problem came from. now as you said you have been tried to put a backlight just to know if their is a problem with the backlight but still you have black screen so which mean the inverter ballast is possibly good as will as the backlight. ok here is on how will you trace the main cause you need to turn on the tv unit then check if their is a INV_ON voltage around 3.3V coming from processor going to inverter ballast, now if do not have voltage turn off the unit then disconnect the connector going to the ballast board and turn on the unit check again the INV_ON if still no voltage come out you have bad processor from the main board. now if the case is the INV_ON voltage is present their is a shorted component at the ballast board that is why the screen is going black after you turn on. if their is an error detected the main board will cut off. hope this will help you thanks for consulting through fixya god bless.
Sep 05, 2011 | LG Televison & Video
Tv turns off after about 30 seconds and 3 red lights show
Your lamp is burned out. When powering up the lamp doesn't turn on so the TV shuts down. Replace the lamp and it should fix the problem. This happens with mine about 1 per year and everytime it's the lamp.
Oct 30, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
I have a Panasonic PT-50DL54 50" rear projection tv. My tv screen won't come on but the fans will. The power led light flashes green like normal but than starts to flash fast for about a minute than the...
Time to get a new TV. I have similar problem. In my case, the set turns off, LED blinking green for about a minute or 2, then the set will turn on by itself. Something the LED started to blink yellow after blinking green and then shuts off. I can turn it back on. This happens 3 or 4 times in an hour. After that, the TV stays on for as many hours as I want until I shut it off.
And then the problem repeats everytime I turn it on from a cold start.
I have my eyes on the 50 inch Plasma from Panasonic. Bestbuy has one for 999.99.
Jun 14, 2010 | Panasonic PT-50DL54 50" Rear Projection...
Tv tries to turn on but then turns off with a red
Lamp light on again?must replaced the lamp again,the lamp hours it up.
Mar 30, 2010 | Mitsubishi WD-62525 62" Rear Projection...
My tv keep shuttin off ,everytime i turn the power on
Hi..
i have a few questions for you??
Have you ever change your TV LAMP? because i think you need a new one! try this website and see if you have a simillar problem and you will know how to do it your self.
http://www.fixyourdlp.com/forum/viewtopic.php?f=4&t=613
Mar 04, 2010 | Samsung DLP HL-P5663W 56" TV
When turned on, my Mitsubishi TV shuts off after a few seconds.
the lamp is simple; yet you can run into problems with this tv. be very careful replacing lamp. the plug in the tv can be damaged. (due to the design)
lamp part #
915P028010
Mar 13, 2009 | Mitsubishi WD-62526 Projection TV
Tv plays for a few minutes then shuts down. the red light blinks.
You need reset the lamp timer after
replace the new lamp.In the remote control pres menu------setup------lamp timer----message do you replace a lamp appear----press yes----and ok.
Feb 14, 2009 | Sony KDF42E2000 42" HDTV
I turn on the tv but I get no picture (black screen). A sound starts when I turn on the tv. The sound ( like a humming noise) fan perhaps which goes up and down for about a minute then the tv shuts off and...
Sounds like a problem with the color wheel. Unfortunately the color wheel is located inside the light engine. According to everything I have read, the only thing you can do is replace the light engine. You are better off replacing the TV. The light engines can run form $750 to $1400. Which is ridiculous!
Jan 02, 2009 | Optoma RD50 50" Rear Projection HDTV-Ready...
Zenith D52WLCD 52" Rear Projection HDTV-Ready Television Logo
67 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
