Question about Jado 815/450/144 Brushed Nickel Tamarac Single Handle Pressure Balanced Sho
I turn the shower on and it sounds like a machine gun going off until I turn on the bathroom sink a little to balance out the pressure. It happens only with certain hot/cold setting ranges. All hot water and all cold settings don't cause the problem. Thanks
Did you ever find a solution? Mine does the same thing. I tried swapping out the hot/cold mixture valve, but to no avail. Any help would be appreciated! Dustin dustinrains@gmail.com
Posted on Jul 09, 2011
One of my HG shower systems has increasingly lower volume. The shower head and supply hose are fine. what should I check next?
If you are using water in another part of the house most times the pressure at the bathroom shower will go low. For instance if some one in the kitchen draws water in the kitchen sink this will make the shower water even turn cooler because of low pressure. Flushing the toilet will also do the same.
Most houses are plumbed with half inch water pipe and would work a lot better if it was three quarter inch to give more water pressure.
Jan 12, 2015 | Hansgrohe Home
Flip over bathroom plug in bath stuck & bath full :/
follow this steps and fix it. God bless you
  1. Remove the shower head from the pipe.
  2. Clean the arm threads and wrap them with plumbers' joint tape.
  3. Screw the head back on and hand-tighten it. Remove any excess compound or tape.
  4. Test and retighten as needed.
Repair a shower head that leaks at the swivel:
  1. Unscrew the shower-head body from the swivel-ball ring.
  2. Find the O-ring or a similar seal inside. Replace it and screw the shower head back into place.
  3. Turn off the water supply and open the faucet handle to relieve water pressure.
  4. Carefully loosen the coupling nuts at the shutoff valves and at the base of the faucet.
  5. Carefully remove the supply tubes.
  6. Remove the locknuts that hold the faucet to the sink and lift the faucet out.
  7. Clean the area where the old faucet sat.
  8. As needed, install the new spray hose and supply tubes, if any, through their holes in the sink.
  9. Set the rubber gasket that came with the faucet on the sink where it will be mounted. If no gasket is supplied, apply plumber's putty.
  10. Set the faucet into position and center it.
  11. From under the sink, attach the faucet locknuts to hold it to the sink.
  12. Reinstall the supply lines, then turn them on and test the faucet. Turn it on carefully because the line and faucet have air in them.
Nov 28, 2013 | Home
M delta 174939-ss-i shower has no pressure just a trickle of water comes out. I have full pressure at tub and sink in bathroom, just not in shower which a stand alone shower.
Hello Mark
is the water still coming out the bottom when you pull up the lever to make the shower come on ? if it is then the tub valve is bad . if little or no water come out of the bottom then the head is going to be clogged and you have have buildup inside the filter /screen which could be located in the end of the hose at the head or inside the head unit itself. .
Nov 05, 2013 | Delta 174939-SS-I Carlisle Monitor 17...
What to do if i can't stop the water flowing from the shower spout and there's little water pressure coming from the shower head and a hand held shower?
One rule I live by: more parts, more problems. Sounds to me that the plumbing/valves were not insalled properly. If you hired a profesional plumber, have them fix it. I am a licensed profesional plumber and I offer a 1 year warranty on all my work. If the contractor did the work and does not hold a plumbing license, that person is still responsible and may have to suffer legal consequenses.
Sep 10, 2013 | Latoscana TC3TPW690 Water Harmony...
I jhave in my showers the Moen and One handle tub and shower faucet, model # T3132. When I turn it on in the showers, there is no hot water... in both it gives me only cold water... even if I turn the...
As you look at your valve on the right you will see a large screw fitting.inside this fitting is a temp/ pressure balance spool. it has failed for some reason and needs to be replaced. On both sides of the valve are 2 smaller screws. these are the water shut off valves. turn off the water and remove the larger screw fitting. remove spool and replace. Hope this helps.
Dec 21, 2010 | Moen & One Handle Tub & Shower Faucet
We bought a home and our spare bathroom shower does not work. we replaced the moen valve and still cannot get water to come out of the shower. the toliet and sink in that bathroom work as they should. and...
did you install the valve sideways or upside down? or is there a blockage in the hot line? the valve may be pressure balanced so if there is no water then there may be a blockage on one side. did you solder the valve? if so did you remove the cartridge? when you replaced the cartridge did you grease it with non-petroleum grease?
Dec 03, 2010 | Moen & One Handle Tub & Shower Faucet
My shower drain gurgles when the washing machine drains
The drain from your washer is tied to your shower drain and it is receiving air from your shower drain. Maybe your washer drain is not vented. This should not be a major concern if you can live with the noise.
Jan 03, 2010 | Dryers
Severely reduced water pressure from lavatory faucet
Take the strainer off the spout and check to see if there is any dirt or rust buildup in the strainer. This happens when repairs have been done. It usually collects at the first place the water comes out of.
Nov 07, 2009 | Elements Of Design Chicago Polished Brass...
Jado 815/450/144 Brushed Nickel Tamarac Single Handle Pressure Balanced Sho Logo
247 people viewed this question
Top Jado Home Experts
Donni Steen
Tom Chichester
Are you a Jado Home Expert? Answer questions, earn points and help others
