Question about Atd Tools (ATD3130) 130A MIG WELDER 115V 3130
I have a ATD Tools 37001 (3130) 130 amp welder, when preparing to start welding I noticed that the wire feed assembly (top roller) was broken, the entire hook piece that the tension-er sits on was gone and now it will not feed. were can I get a new top roller assembly? it came from factory or warehouse like this.
My atd 37001 welder was welding along fine when it just stopped arcing I assume a part burnt out but which one and how do I find the part?
Check a fuse or circuit breaker. The breaker may reset it self when it cools down. The rectifier may be bad or the transformer opened.
Oct 20, 2013 | Atd Tools (ATD3130) 130A MIG WELDER 115V ...
Would like to if the telwin bimax 182 turbo have stitch timer an where do i find it on the machine?machine is to years old.
Hi there, the Bimax 182 has the stitch weld switch between the wire feed speed control and stitch weld timer, just flick it on and you are in business,
cheers.
Dec 18, 2010 | Atd Tools Welding Tools
I have a weldmark 140. When you turn the voltage knob it controls the wire speed. The wire speed knob does nothing
Flip up the cover on the side to expose the welding wire rool.
push the feed button on your welding gun, and watch the feed rollers.
If they are turning, then you need to increase the force on your rollers untill the wire starts feeding.
If the rollers do not turn, then you most likely have a bad switch, or connection in your welding gun or your speed control
Good Luck
Oct 24, 2010 | Welding Tools
Welder will only weld for about three inches on high
If it won't push wire through gun you might need to tighten wire rollers, or check the liner for bad spots.
May 13, 2010 | Century 80GS Flux - Cored Wire Feed Welder
I have a Hobart handler 120/90amp wire feed welder.When i try to weld,all i get is a small spark.I turn it off,turn it on and it does it again.The wire feed works good,it just sparks,but will not keep...
I have welded countless hours with Linde & Lincoln & even a few Hobarts & the only time that I ever had the same problem was when the ground connection either to the object I was welding, or the welding cable ground wasn't good & clean & tight. Same on stick welders also. I did develop the habit of grinding not only where I was preparing to weld, but where I was placing my ground clamp & that always provided a better "frying bacon" sound as I went along the business of pushing a bead. In a welder, the only other thing than that is involved is the step-up transformer and your wire. Hope this helps.
Feb 01, 2010 | Hobart Welding Tools
Wire feed stopped after tack welding on set-up jig
i had the same problem. its probably a bad solder on the wire feed pot. not hard to fix ,but you need a solering iron .BE CAREFULL 1 unplug welder.
2 remove pot and the nut underneath.
3 remove case from welder and remove controll box.
4 run the soldering iron over the joins , then put it all back together, should work fine.
Jul 22, 2009 | Hobart Handler 140 Mig Welder
Wire feed assembly for a Astro power mig welder 110
go here and buy the parts i have one too, fix it and sale it!!!!! (JUNK WIRE FEED )
http://store.daytonamig.com/wifeteas.html
Jul 11, 2009 | Miller matic 140 Mig Welding Package W/As...
Toolex 140 mig welder, wont feed wire.
You may have the scew settint your wire tension set to tight. Try loosening the tension and if that doesnt work check the eletrical wire that supplies the power to the roller and make sure it hasnt become disconected.
Jun 26, 2009 | Welding Tools
Handler 140 wire jerky when welding
make sure rollers are clean and slots not wore out check alignment
do not over tighten wire feed so it smashes the wire
flux wire is hard to get a good setting
make sure if you can set it for gas welding it is not on this setting
Apr 06, 2009 | Hobart Welders 500505 Handler 140 MIG &...
Relay clicks, gas blows, rollers dont turn
If you use it regularly, the liner should be replaced about every 6 months. Make sure you get a wiper for the wire. It goes inside the machine, on the wire, just before the feed rollers. It keeps the dust from clogging the liner.
Feb 08, 2009 | Miller Welding Tools
Atd Tools (ATD3130) 130A MIG WELDER  115V  3130 Logo
499 people viewed this question
Top Atd Tools Welding Tools Experts
Bill Boyd
Are you an Atd Tools Welding Tool Expert? Answer questions, earn points and help others
