Question about Refrigerators
GE refrigerator Model No. GSS25QGMDBB. I am trying to get the "trim recess disp bk", ie. the trim around the ice dispenser on the freezer door to fix the ice shute door, it doesn't close without pushing on it. How do I get the trim off?
  • 11,896 Answers
You will have to pry it off gently. A heat gun may help melt the double-stick adhesive that is holding it on.
Posted on Sep 08, 2010
How to fix water leak on GE Profile Refrigerator
I would look at the dispenser door for the ice (ice chute) I have seen this door not completely close and cause leaking the you are describing. This door is has a black seal, use a flashlight, from the inside of the freezer door, look for light on the outside of the door. I think you leak is there and replace the solenoid for the door to fix this issue. Good Luck, if you want more help please input a model number. Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Aug 17, 2014 | Refrigerators
My GE Profile model psc23sgnabs leaks water from under the water & ice dispenser recess trim moulding. Is there any way to get the freezer door apart to replace water hose inside the door? There are...
No, the door is foamed together.
Remove small drip catch at bottom of dispenser area. Use silicone to seal recess along front edge and the two front corners. That should prevent water from getting under the door trim.
Mar 02, 2011 | GE Profile 23.3 Cu. Ft. Counter-Depth...
Puddle in front of TFX24CRS
If there is ice on the floor of the freezer, you have a blocked defrost drain. If no ice there, you are getting water from the water / ice dispenser, possibly down the back side of the door panel.
Seal the seams around the water catching recess at your dispenser with a bit of clear silicone. (corners and along the front edge seam with the front door panel.
Jun 15, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a GE Refrigerator GSS22JFMD WW with a ice
The water supply in the recessed part of your door is frozen. very common with this model. You will need to turn unit off and with freezer door open use hairdryer on the area where water dispenses and on the recessed area as well. This is time consuming but only other remedy is to leave off and door open for 24 hours. hope this helps.
Feb 12, 2010 | GE Refrigerators
No water from dispenser in door .... ice machine works but no water.
If this is a GE the water supply in the freezer door is frozen. Quick easy way to check is disconnect at the bottom of the freezer door and close door and activate the water switch and see if water getting to that point. If it is turn off ref and use a hair dryer on the upper section around thr recessed area and defrost the ice line. Will take a while so be patient.
Feb 01, 2010 | GE GSH25JFR Side by Side Refrigerator
GE model PSC23SGRC SS refrigerator freezer door disassembly
Access from front of freezer door. Trim is just pushed into friction holders. Selector area snaps in. Phillip screws under that removes ice shoot.
Sep 16, 2009 | GE Profile 23.3 Cu. Ft. Counter-Depth...
Water dispenser on GE side by side not working. what should the refrigerator and freezer settings be? Can that be the problem?
Dispenser controls on any refrigerator actuate one of two things. Ice disp, or water disp. If the IM is not working also, then H20 valve is bad. If just the H20 disp feature isn't working in the door, try this: remove food and unplug unit for 24 hours. Then, plug back in and resume normal operation. If all checks ok, you have a frozen water tank, or frozen water line. Fix: on certain model ref's, there is a water tank service flash where an antifreeze insulation kit should be installed, contact Sears or your retailer for this information. On others, this is simply a freeze up caused by lack of H20 usage or temps in ref/freezer set too low. If this does not fix the water supply, and you still have ice production after 2-5 hours after restarting the ref, remove the dispenser cover and test the water supply actuator switch for continuity. of open after drepression, replace switch. If switch checks ok, then replace water valve as on side of the solonoid valve assy is not functioning. In rare cases, you may have to check or replace the wiring harness. This can be tested only after elimenating the disp switch test, and calling for H20 from the disp, voltage at the disp wires to the H20 valve, but no voltage recieved at the h20 valve, or by an ohm reading of the wires.
Jun 10, 2009 | GE GSS20IEP Side by Side Refrigerator
Frost gathering in freezer, icemaker dispenser freezes over
well check to see if door seal is split if it is get new one!! need to see photo of the frozon over dispenser- found before that when ice not bein used alot the odd time you will have to take out the ice in the bucket crack it up and put back in try this???
Feb 03, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Icemaker makes ice; door dispenser cranks, but no ice dispensed
sounds like either the dispenser motor is bad or the dispenser yoke is stripped. remove the bucket from the freezer. you will see a u shaped yoke in the rear of the disp area. this should be fairly hard to turn by hand if it turns easily then the motor gears are bad if the yoke slips on the motor shaft then you have a stripped yoke. hope that helps. peyton...
Jan 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
