Question about GE (PSS26MSRSS) Side by Side Refrigerator
The refrigerator and freezer are getting warmer 47 and 10 ,after a couple of hours are 37 and -2. What could be the problem?
  • GE Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Sep 08, 2010
Too cold
Refrigerators and freezers have a thermostat control inside the refrigerator compartment. It is normally some type of dial with numbers and a graphic indicating warmer or colder.
Place a thermometer inside the cold box. Wait one hour and record the temperature. Adjust the thermostat one or two numbers warmer, then wait 12 hours and record the temperature.
The interior temperature for a refrigerator must be below 40F for food safety. A good range is 35-38F.
Jul 26, 2012 | KitchenAid KBFS25EVMS Stainless Steel...
My whirlpool side by side is getting warmer. Freezer was up to 45 F yesterday, today 55 F, Refrigerator getting warmer too. Fan on freezer and refrigerator vents blowing, but isn't that cool. What's...
check and clean the condenser coil under the ref , remove the back to the ref if the compressor is real hot you need to put a fan behind the ref for a couple of hours until the compressor cools down then plug it back in.
Nov 21, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
I have a GE refrigerator model number PSC25SG SA SS which has Problem that in every couple days the freezer and the refrigerator display panels display out of their setting ranges. For example, the...
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
heatman101
Aug 24, 2010 | GE PSC25SGSSS Stainless Steel Side by Side...
HI, I have a Fisher and Paykel E402B fridge the fridge nor the freezer get anywhere near cold enough and the warning light at the back of the fridge has just started flashing Continuously and every couple...
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Aug 13, 2010 | Fisher and Paykel Active Smart E522B...
I have a Samsung refrigerator/freezer How do I adjust the freezer temperature?
1Place the appliance thermometer in a glass of water.
2Set the glass of water with the thermometer in the refrigerator on the middle shelf.
3Check the temperature on the appliance thermometer after 24 hours.
The temperature should register between 37 and 40 degrees Fahrenheit (2 and 4 degrees Celsius) in order to store food safely.
4Look for the temperature control dial inside the refrigerator if you have to adjust the temperature, and make it warmer or cooler.
If you can’t easily see the control dial, check the owner’s manual for a diagram that shows the location
When looking at the refrigerator temperature dial, you may see numbers rather than degrees. The majority of refrigerators use a set of numbers, with the lower numbers representing cooler temperatures and the higher numbers representing warmer temperatures.
5Move the temperature dial in the necessary direction to adjust the temperature up or down. Be sure to move the dial only one number in either direction because it probably will not take much to change the temperature in the refrigerator.
6Adjust the temperature balance control if your refrigerator has such a dial or sliding switch. This allows you to direct more or less cold air to the refrigerator section from the freezer section.
7Wait at least 24 hours, and then check the refrigerator temperature again.
8Observe the amount of frost in the freezer section of the refrigerator if you are unable to properly set the temperature.
90Defrost the freezer if the amount of frost is more than .25 inches (.64 cm) thick.
10Repeat the steps as necessary until the temperature is within the safe range.
11Use a permanent marker to draw a line on the dial after you locate the best setting on the refrigerator temperature dial. This will give you a reference point in case your dial moves and needs to be adjusted in the future.
Hope this helpout...
Aug 09, 2010 | Samsung Refrigerators
Hot point model hss25gfp. can get water at coupling but not out of door dispencer . ice maker works fine. When coupling is disconnected and water is depressed water flows fine from the coupling.
The water line is frozen in the door .Turn on the dispenser light for several hours , or , use a hair dryer aimed up into the dispenser , or , use compressed air in the tube going up into the bottom of the door ( computer cleaning bottle with a small tube ) , or , air compressor hose at the bottom of the door tube , or , order GE dispenser heater kit pt # WR49X10173 ( it comes with instructions ) . After you get it working , turn up ( warmer ) the freezer temp only slightly .
Aug 08, 2010 | Hotpoint HSS25GFP Side by Side...
Freezer is not cold enough
Here are normal temperatures - Freezer should not be warmer than 10F. Normally it should be 0F, however optimal temps are -10F and for hard icecream - I recommend -10F or colder since it gives a better recovery after a power failure.
Refrigerator temps no warmer than 4F - optimal should be 34F.
After ruling out door gasket seals and dirty condensers, the most common cause is a bad defrost system. If you remove your freezer panel you can look for over frosting on the evap coils - (after shutting down unit of course) try manually defrosting with a blow dryer until everything is melted - place back panel and run for a couple of hours. If cooling is back to nromal, your issue is defrost timer components / control board.
Make sure the evap fan is working properly as well. as your condenser fan (if applicable).
Sep 23, 2009 | Kenmore Refrigerators
Freezer then Fridge not cold enough
heatman101
Apr 06, 2009 | GE Profile PTS22LCSCC 33" 21.7 Cu. Ft....
Refrigerator is not cooling
Hello hazraan
Welcome.
You said your Kenmore model 60852990 freezer is working but refrigerator is not cooling.
Lets try a couple of ideas.
Is your freezer filled up where the packages are covering the air vents in the rear of the freezer?
Refrigerators and freezers must share the cold air and circulate between them. If the freezer is packed full with not enough space at the air vents in side it, the fridge will get warmer!
Next,Turn off the fridge and freezer controls, and then go to the breaker box and turn off the breaker to the fridge for 5 minutes!!!!!
Then restart it and the fridge and freezer controls.
This should reset the system and solve the problem. let me know if either were the case.
If either was the reason,it now will take some 8 to 12 hours to gets back to temperature.
Waiting your response.
Huuum, Please remember to leave a rating.
Oct 13, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
