Question about Lands Phones
Trying to replace a stand alone answering machine on our Lucent 18D (and 34D PARTNER advanced Release 1.0) phone system. We have had one for years with no issues. We have tried a couple of brands - both work just fine on the stand-alone fax line, but when we put it on the system line it doesn't seem to hear the rings.
  • 2 more comments
  • deb_kobelan Sep 09, 2010
    we have already done this and it is set on Immediate ring, but it still doesn't recognize it what should we try next?
    it is set on immediate ring and when we plug a phone into the port it functions properly, but for some reason it doesn't recognize the answering machine - any ideas?
  • deb_kobelan Sep 10, 2010
    tried multiple ports the only one it seems to work with is port 11 and it wont allow the phone to loop with it. do you have any other suggestions?
    Thank you for your help! If we wanted to replace the ACS and the R8 whom do we contact? Also (sorry for the stupid question) but what is the R8? I assume the ACS is the operating software - is it easy to install the upgrade?
    Again THANK YOU SO MUCH FOR ALL YOUR HELP!!!
  • Lands Phones Master
  • 2,460 Answers
A Partner ACS version ONE???? Wow. O.K. What happens when you dial the extension you plugged the ansering machine into? I assume it's a port on the switch, so it has an extension number of 11-17 (there has to be a system phone in ext 10).
If you get it to answer internally, then you must have lost programming on the port. If you don't have a manual, get it here. http://www.wedophones.com/Manuals/AT&T/Partner%20ACS%20R1-0%20Programming%20and%20Use.pdf
From memory, that is changed in Centralized programming and you get there from the display phone (34D) on extension 10 by pressing FEATURE 00 LIC LIC RIC and dial the extension the answering machine is on. Your line lights will be blinking or solid, depending on what the ring status is. If you press it, the line will switch to another of the 3 states. Keep pressing it until what you want (immediate ring) is in the display.
If you search the manual for Line Ringing, you will be able to read more about the feature and possibly what may have changed.
Carl
Posted on Sep 09, 2010
  • 2 more comments
  • Carl Navarro
    Carl Navarro Sep 09, 2010
    Oops, if you're unfamiliar with the jargon LIC is left intercom RIC is right intercom
  • Carl Navarro
    Yeah. Try plugging the answering machine into a different port. The ring generator for single line sets may be defective for the whole system, or just the port. Since a system phone works in the port, you'll either have to repair or replace the ACS, or change answering machine ports. Repair is not expensive, ie less than $200, but an ACS 3 or 4 is probably not much more.
  • Carl Navarro
    Carl Navarro Sep 10, 2010
    I already said it...."repair or replace the ACS". A 4.0 box is about $325, an R8 is about $600. The nicest part of the 8.0 is it will pass caller-ID to a single line set. It's fairly redundant to repair a 1.0 processor.
  • Carl Navarro
    Carl Navarro Sep 12, 2010
Caller id partner
To program a Caller ID Name Display button using remote administration on Partner ACS Release 3 or later systems:
  1. In the Partner ACS R3 System window, select Extensions. The Extensions window appears.
  2. Select the extension you want to program. The Individual Extension Parameters window appears for the selected extension.
  3. Select the Button Programming button. The Button Programming window appears for the selected extension.
  4. Optional - For new systems where no download is available: From the Phone Model box, select the arrow and choose Partner-34D, Partner-18D, Partner-18 Non-display, Partner/MLS-6 Non-display, MLC-6 Cordless, MLS-12 Non-display, MLS-12D, MLS-18D, or MLS-34D for this extension. The button layout for the type of phone you selected appears.
  5. Select the button you want to program. The Partner Set Button Programming Information dialog box appears.
  6. Select the Caller ID Name Display button.
  7. When you are finished, select the OK button.
  8. Repeat steps 5 to 7 to program other buttons for this extension.
May 22, 2014 | Avaya Eurostyle 18D Corded Phone
How do I change the time on my Lucent Partner 18d
Partner ACS, any release
Changing the time on a Partner system must be done from extension # 10 or 11. 1. At station(Ext.10 or 11) press feature, 0, 0
2. Press the left intercom 2 times
3. Enter # 103
4. Enter the correct time in 24 hr. format, for example:
* to set the time for 09:00 A.M., enter 0900
* to set the time for 04:45 P.M., enter 1645
5. Press feature, 0, 0
Mar 30, 2010 | Lucent PARTNER18 Corded Phone
Lucent Partner 18D cant fully reboot itself
That one doesn't sound too good.
You could perform a reset through programming which should clear the scratch pad.
Thats done by entering programming on either ext. 10 or 11
Press feature 00 then the left hand intercom twice.
Next enter # 728, the display should say reset save all then reboot the system.If the problem is still there, then the processor is malfunctioning and will need to be replaced.
Dec 04, 2009 | Avaya Corded Phone avaparp18d
Lucent Partner 18D - Caller ID not working
The caller id information is sent from your local telco provider after the first ring and might not be able to be extended to the individual sets, try backing off the ring to answer on your voice mail from 2 to 3 rings to see if the information is then passed on. The Voice Messaging System message is being sent from the system showing who transfered the call to you. You should also notice that the ring pattern when that message is displayed is a standard ring followed by a beep meaning a transfer is taking place.
Nov 20, 2009 | Lucent PARTNER18 Corded Phone
Lucent Partner 34D phone system with 18D extensions
That doesn't sound good at all. I would first try powering down the system and waiting about 15 seconds or so before powering back up. If the problem remains, the processor was some how damagedand would be best if it was looked at by your vendor.
Sep 25, 2009 | Avaya Lucent Partner 616 Phone
Ayaya Lucent Partner 18D Cordless call waiting.
The cordless will not work that way. If you hit flash, that will put calls on hold, etc....
The only thing you can do is have the flash button on the 18D itself.
Aug 28, 2009 | Avaya Lucent Partner 616 Phone
The voicemail system on our 18D phones leaves the messages all jumbled and full of static...how do we fix that?
Which voicemail do you have? If it is the Partner Mail VS, or the stand alone Partner Mail, then it sounds like the hard drive is going bad. I would buy a new voicemail before this one dies.
Aug 05, 2009 | Lucent PARTNER18 Corded Phone
Lucent partner 18d- reprogramming
go to support/avaya.com and get a manual for free. Try to find out what release is your partner system. Cheers
Jun 10, 2009 | Lucent PARTNER18 Corded Phone
Noise in system
Probably in the module. Switch to different port on module and see if it clears the problem
Jun 17, 2008 | AT&T Partner 18 Phone (315805B)
Lands Phones Logo
166 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
