Question about Porter Cable 10,000 Watt 20 Hp Portable Generator #H1000IS W...
I have a porter cable 5500 watt 10hp gen its now running wide open how/what do i adjust to have it run normal??
  • 44 Answers
High idle screw or governer
Posted on Sep 09, 2010
Capabilities of the Robin 2400is generator
no
ac units are 2000 watts minimum, washing machines are 1500 watts minimum, microwave is what is on the plate and start at 650 watts but most are 2000 watts
the 2400 is the peak out put for start up of fridge , washer etc and the running wattage will be 2000 watts or less ( duty cycle )
to run more than one of the nominated items at once you will be needing a 5500 to-6500 watts unit
they handle a start up surge of 6500 watts ( larger one) and will comfortably handle 5500 watts run full load
it works like this , the plate on the gen set is the surge short time load capacity of the genset and not the duty load which is 500 to 750 watts less than that plate wattage
for example your 2400 is is surge rated at 2400 watts but duty load is less than the 2000 watts
many people make the mistake of buying a gen set that looks big enough but do not calculate the maximum load capable on being put on the gen set
fully loaded uses more fuel /hr
wears out faster
has power surges as the extra load cuts in and the motor struggles to get back to required rpms for voltage and cycles
will not cover extras like lights ,
a much large gen set will take it all in it's stride , no power surges, better economy, less stress
talk with an electrician , do your maths on everything you wish to run and that which you forgot about then add 1000 watts to the duty cycle and that will be close to the gen set you require
Oct 17, 2016 | Electrical Supplies
Porter cable 5500 watt generator - where are the diodes?
on back of stator in side gen, they look like silver round disks on the stator coil
Oct 09, 2013 | Electrical Supplies
Have Onan 3.6 KY propane gen that will not keep running. Runs only as long as start switch is pushed. Then stops immediately after release. Fault code is 15 (underfrequency) and suggests removing heavy...
I am not familiar with your peice of equipment but from your description of the fault being Under Frequency it appears that generator governor is out of adjustment or the governor spring has brcome weak or broken and not allowing the engine to run at the correct speed to produce an output frequency within the allowable tolerance. Governor linkage could also be binding and not moving smoothly to respond properly to engine load conditions. Thoroughly check governor and throttle linkage for free and smooth operation and full range of movement.
Another cause could be that the engine is not getting sufficient fuel causing the governor to have the throttle wide open to try to get engine to run at its correctly governed speed but unable to do so because the engine is not developing enough horse power.
Jan 10, 2011 | Watts Onan Portable Generator - 4000 ,...
My porter cabe 5500 only runs on choke
Because it running lean, too much air in the air/fuel mixture. I can only give a suggestion and it's a rule of thumb I follow regarding basic internal combustion tuning. With this condition I locate the fuel adjustment screw, usually located after the throttle plate (butterfly) which controls the amount of fuel into the mixture.
I would set it up to run richer then open the choke until it idles effortlessly, without any assistance. When it's too rich, the engine's revolution would be to high and probably cause it to smoke a little and I back off the adjuster. The best level is that it shouldn't stumble and cut off. Once this is optimal, hard starting and unassisted idling should be eliminated.
Jun 27, 2010 | Porter Cable 5,500 Watt Portable Generator...
No electricity from generator
If you have a voltmeter, you can check the voltage coming out of the outlet. If you have some kind of residual voltage, such as 25 Volts AC or 10 volts ac, then you probably have a voltage regulator problem and your regulator will need to be replaced. If you read 0 volts then you you have an open between the output (outlet) and the windings of the stator.
Jun 09, 2009 | Porter Cable Electrical Supplies
Porter Cable 10,000 Watt 20 Hp Portable Generator #H1000IS W... Logo
252 people viewed this question
Top Porter Cable Electrical Supplies Experts
John Trevino
Spud Howell
Are you a Porter Cable Electrical Supply Expert? Answer questions, earn points and help others
