Question about Frigidaire Microwave Ovens
My frigidaire microwave turn on but it will not cook.FMV156DB.Please help.
  • Frigidaire Master
  • 9,098 Answers
If when you try to cook, the turntable and cooling fan come on, but the inside light does not, then your primary interlock (bottom door switch) or its mount is bad.
See the service manual here:
http://www.microwavedisplay.com/fmv156_sm.pdf
And see these files:
http://207.234.249.73/mwd/safety.txt
http://207.234.249.73/mwd/disassembly.txt
http://207.234.249.73/mwd/doorsw.txt
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
Posted on Sep 08, 2010
Turning it on for 90 seconds
Hey friend, thank you for your inquiry!
I understand that you would like to set your Frigidaire microwave for 90 seconds. Based off the Use and Care Guide you would press "Cook Time" and then enter "90". That would start your microwave for 90 seconds. If that is not your question please provide me with additional information for your current issue. I hope this information is helpful. -Matt
Oct 08, 2014 | Frigidaire FMV145K Microwave Oven
Why has my frigidaire microwave (model PLEB30M9ECE) stopped beeping. It still cooks but no longer beeps
Good Afternoon Friend,
I understand that your Frigidaire microwave, model# PLEB30M9ECE, is cooking, but has stopped beeping. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Sometimes there can be a miscommunication between the different boards inside your appliance. Restore power and try any cooking cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 01, 2014 | Frigidaire Microwave Ovens
Microwave actual serial # FMC B11 5GM. We had this microwave set on push a one and cooks for one min. push a two and so on.. in a rental house with people who aren't electronic savy. I pushed a...
The owner's manual will help you, I'm sure.
If for some reason you don't still have yours, you can download Frigidaire owner's manuals and installation instructions here.
Sep 26, 2011 | Frigidaire FMCB115GC Microwave Oven
Frigidaire model cfmv156fmc allows programming, lights work but when hitting go wont turn on yet timer is counting down.
If the inside light comes on when you try to cook, but the turntable and internal cooling fan do NOT, then that's a bad bottom door switch or that switch's mount.
See this helpful text file.
If the inside light, turntable, and internal cooling fan DO all come on when you try to cook, but it does not cook, then you have a bad relay or connection on the control circuit board, which we can repair for $39.95. Details here.
We have the service manual and have uploaded it to our site here to help you.
Jan 11, 2011 | Frigidaire Microwave Microwave Oven
The lights work, the truntable does no turn and there is no power to the motor. FMV156DB
Hello there:
The carousel won't turn Although the carousel is usually driven by a small motor that's unrelated to the heating function of the microwave, the microwave cabinet needs to be opened to repair it.. Inspect the plastic drive coupling that the tray sits on, as well as the ring-and-roller assembly, to make sure that they're working properly. if not replace it and check all of the wiring to the motor with a meter to see if there is any continuity to it if not there is a problem with the motor itself or the wiring harness ok?
Sep 26, 2010 | Frigidaire FMV156D Microwave Oven
Hi. My Frigidaire Microwave does not turn nor does it give any sound that its working. You can see the word COOK but nothing is happening.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 08, 2010 | Frigidaire Microwave Ovens
The timer counts down but the microwave doesnt turn on.
I have a FNCB115GC Microwave problem. The microwave has a icon on the left hand side of the panel that looks like a opened book on a stand with lines on top. This is best that I can descibe it. The microwave turntable does not move or the microwave does to come on but the light comes on and the timer will count down. I have cleared the microwave and unplugged it with no results. Please help. Thanks in advance.
Jun 03, 2010 | Frigidaire FMCB115GC Microwave Oven
I think I have a bad door swtich on a frigidaire microwave
un plug the oven, un screw the screws and remove the cover, look behind the door where it closes and you will see a micro switch, and two wirers, note where the wires and screw is located and remove them. get a replacement switch NOTE!! make certain that it is the same type of switch ie. normaly open or nomaly closed. carry the switch you to get the replacement. replace the switch and the wires. if you want to verifry that the switch is defective you can have it tested when you go to the spares store to obtain the new one.
Jan 05, 2009 | Frigidaire FMV156D Microwave Oven
No power
you will need to replace the 20amp fuse above the control. also obviously fix the door switch. which can all be accesible through the control panel
Jan 04, 2009 | Frigidaire GLMB209D Microwave Oven
Microwave Ovens Logo
176 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
