Question about Canon Image Runner 1630 Copier Copier
E000 system error - looks like we have to replace the drum unit, however quotations to do this range from US$700+ to US$1000. Do you have any suggestions for a company on-line that would have a drum unit for this printer/copier - that isn't going to cost me an arm/leg?? This is a very small office.
  • 1,219 Answers
firstly these isnt drum unit fault, E000 means fixing temperature trouble. The drum unit fault is when you have streaks on copy.
For drum try on e-bay or find local KATUN representative for cheaper Drum.
You can try to clear error, do next:
press MENU and #, select CLEAR, ERR and OK, if not helps these means that you need to change the fixing assy.
Posted on Sep 09, 2010
  • lucy_field Sep 10, 2010
    ...unless you know something I cannot see, I've checked and there is no MENU button on the 1630!
  • Canon tech CROATIA
    Canon tech CROATIA Sep 10, 2010
    Try (*) add.function and # sorry
How do I solve a system error E000 on canon iR1600 photocopier?
First you need to clear that error from service mode. If problem persist replace the fixing unit
Jun 15, 2015 | Canon Office Equipment & Supplies
Help me how to remove system error cod e000 for canon pc-d 340
PC-D320/PC-D340/FAX-L400 Chapter 4: Maintenance and Service
E000 Fixing unit failure
Cause: (1) Shorted/broken wired main thermistor (2) Shorted/broken wired sub thermistor (3) Broken wired heater/blown thermal fuse
Solutions: (1) Turn the power off and remove the fixing unit from the machine. Measure the resistance between the fixing unit connector J206-2 (FSRTH) and J206-1 (GND). If the resistance is not within the range between 350 KW and 520 KW (room temperature of 20°C), replace the fixing film unit. (2) Turn the power off and remove the fixing unit from the machine. Measure the resistance between the fixing unit connector J206-3 (FSRTH2) and J206-4 (+3.3V). If the resistance is not within the range between 370 KW and 520 KW (room temperature of 20°C), replace the fixing film unit. (3) With the fixing film unit removed, if there is no continuity between the fixing unit connectors J102-1 (ACH) and J102-2 (ACN), replace the fixing film unit. (4) Replace the ECNT board. (5) Replace the SCNT board
See Service Manual page 105 (4-25):
Canon PC D320 Service Manual Page 105
Jun 04, 2015 | Canon PC-D340 All-In-One Laser Printer
System error e000 canon image class mf4122
Error e000 - error with fixing unit. Try to disassemble printer, remove fixing unit. Check heater element's and thermal sensor's impedance. Check connectors.
May 20, 2011 | Canon imageCLASS MF4150 All-In-One Laser...
I have a problem of system error of copier ir 2000. how can i solve it?
can You be specific by mean of which system error? Like E100? E000?, E001....
Few examples of most common errors:
E100 - Laser trouble - change the drum unit ( complete drum unit )
E000/001 - fixing trouble - try to reset the error under service mode - procedure: press MENU and #, with > key go to CLEAR and OK, find ERR and OK, turn off and back on - if it helps you solved the problem, if not you need to change the thermistors or the fixing lamp, because you have low/high temperature problem.
E019 - waste toner full - remove the drum unit and open the corks on top of the unit and empty/vacume waste toner out.
Hope that helps!
Jan 10, 2011 | Office Equipment & Supplies
SYSTEM ERROR E000
Error Coed E000
- Check the connectors of the fixing film unit.
- Need to replace fixing film unit.
- Need to replace Hi Voltage Power Supply Board
- Need to replace DCNT Board.
May 29, 2010 | Office Equipment & Supplies
E000-20-0081 Code
Pull the drum out. we get a small flash light and look inside. About half way inside, at about the 10 or 11 o'clock position is a small sensor that shines on the drum. Take a cloth and wipe the surface and reassemble and all should be well. Note the colour of the toner wiped off the sensor, (it is most likely black) if the problem returns then the developer unit of that colour needs to be replaced. The black can be replaced by itself but the colours should be replaced as a set.
Jul 28, 2009 | Canon imageRUNNER C3170I Color Copier
System error E000
E000 is a high temp. error. My first advice would be to atempt to clear it in service mode:
  1. Press ADDITIONAL FUNCTIONS, #
  2. Go to #7 Printer and press OK
  3. Go to #4 Printer Reset and press OK
  4. Yes = ( * )
  5. Power cycle unit.
If this does not help, on most units you have to start looking at your Fixing Assy. or Thermistors. Make sure that you do not have a piece of paper wrapped around Upper Fixing Roller or and other foreign substance in that area. However, on this one, I would recomend replacing Fix Assy. as a whole if you can, FG6-8326-000 (for s/n starting with MQT/MQV/MRV/MRW) or FG6-8325-000 (for all other s/n). Don't see p/n for Thermistors. Also, heard of alot of other board and p/s issues with this model that can cause E001-E004 errors. See if you can clear it first. Good luck. Let me know how you make out.
May 24, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Canon IR 1600 error message
Note: To reset E000, E001, E002, E003, go to service mode 4. select SET, go to "#7 PRINT-ER," in service mode. Then press Execute "#4 PRINTER RESET." Power the unit off/on.
May 17, 2008 | Canon imageRUNNER 1600 Laser Printer
Canon Image Runner 1630 Copier Copier Logo
71 people viewed this question
old marine
old marine
