Question about Nextar X3-03 Car GPS Receiver
When turning unit on, it says file does not exist , What noee? hit reset button
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 184 Answers
You may have a defective or missing SD card, which has the maps on most of these models. Check the slot and make sure the card is present. If so, and it hasn't been hacked or modified, then you may need to contact Nextar for a new card. Here's a link to their site:
http://www.nextar.com/frontend/gps_navigation_systems.asp
Good luck. Thanks, Bill
Posted on Sep 09, 2010
Can't format my sony walkman mp4
At first reset it by pressing the RESET button with a small pin or similar object. When the RESET button is pressed, although the unit will retain the music data and clock settings, all other stored data and settings may be deleted. If the unit starts up after the reset, access the Settings menu and initialize the unit using the Format (initialize) function.
If it is not successful you may make firmware updates for your model. Updates can be found on the Sony Support Web Site: http://esupport.sony.com
The firmware upgrade file is exist and downloadable:
http://esupport.sony.com/US/perl/swu-spec-eula.pl?mdl=NWZE344&upd_id=5491&os_id=7&ULA=YES
gylacz
Mar 28, 2011 | Sony Walkman NWZ-E344 Digital Media Player
Where is the reset button on the avn 5435 Eclipse head unit?
After looking at the manual, there doesn't appear to be a reset button. If the unit is not turning on, try hitting the power button. A last resort option is to disconnect power from the unit by removing the unit from the dash and disconnecting the wiring harness that goes into the back of the unit.
Mar 01, 2011 | Car Audio & Video
Problem with our Garmin you can turn it on and it will not do anything but display Garmin name and will not turn off. Have changed batteries, any ideas???
It sounds like your Garmin has a corrupt file or file system. This is common when using bird's eye imagery with unsuspected shut-downs.
Try doing a soft reset of the Garmin:Warning: This procedure will delete information (waypoints, routes, tracks, etc) from your GPS and settings may be set back to factory defaults.
1. Power the unit OFF
2. Hold down the two Soft Keys for 2 seconds
3. While continuing to hold the 2 Soft Keys down, press and hold down the Power button for an additional 5 seconds
4. Release all buttons, and select YES to the prompt asking "if you want to clear all user data?"
This form of reset does not seem to reset all of the settings to factory defaults, just a few of the basics like Time Zone and Language, the remainder of the settings are still taken from your existing profile files.
Once you have completed a reset remember to place the Colorado outside in a stationary position for 20 minutes in plain view of the sky so that it can rebuild the almanac before using it again.
Note: Holding down both soft keys and the select button in a similar fashion seems to do a similar reset to the Colorado. This may be a master reset.
If the problem still persists, try this as a last ditch effort.
Warning: This procedure may delete information (waypoints, routes, tracks, etc) from your GPS and settings may be set back to factory defaults.
If you can't get your CO to start properly and it will not go into USB storage mode when connected to your computer you can try this as a last ditch recovery. It worked on a 400t that would freeze when loading maps and soft/hard resets didn't not work, I've also used it to recover a Colorado which refused to boot because of a bad gpx file.
First you'll also need to download file below. Once you've downloaded this file unzip it into a directory such as C:Garmin on your PC.
On your PC click the Start menu, select "Run..." and type "cmd" where it says open. A black window with a DOS command prompt should appear. At the command prompt enter the following command:
.text { font-family: monospace; }.text .imp { font-weight: bold; color: red; }.text span.xtra { display: block; } > cd c:Garmin
At the next command prompt type the following command without hitting enter:
.text { font-family: monospace; }.text .imp { font-weight: bold; color: red; }.text span.xtra { display: block; } > Updater.exe 066101000230.rgn
Now back to your GPS.
Press and hold the "up button" on the Rock'n Roller while you plug the CO into the USB cable. Wait 10-20 seconds while still holding the "up button". You should see a Garmin banner and nothing else. At this point you can hit enter on your PC to execute the updater command. Once the updater runs you will need to select you Colorado under USB and hit enter. This should perform the update (you may get a warning about loading an older version of software). You should receive a message that the update was successful and the Colorado will reboot.
Once the reboot is complete the "Loader" banner should appear near the top of the CO screen after about 30 seconds. Release the "up button" and on your PC you should be able to see the Colorado as a USB drive.
You can now attempt to fix the files on your Colorado which are preventing it from starting. If you've recently added or changed files these are good places to start. Deleting gpx files and/or replacing map img files with your backup copies may resolve the issue as well.
zip.png Colorado_Mass_Storage.zip
Feb 07, 2011 | Garmin Colorado 400t
When I turn my AC power on, the reset button pops out and the unit turns off. This happened yesterday, but then I hit the reset button and it was fine. Today, that is not working.
If it ran fine all day after you hit the unit, it sounds like its just the reset button that has the problem. What you can do, is turn off the power to the unit and pull this reset button out enough to get to the wiring. It should have the same wire going in one side and out the other as it is just a switch. Take a jumper wire and bypass the button. In other words just connect a piece of insulated wire and connect it from one terminal to the other, and this takes the button out of the system. This will be a temp. fix only, until you can get another at a appliance parts house. If its just wore out and there is nothing wrong with the unit, it will run. You say it was fine when you hit it that day? If it ran for the day, its just a faulty reset button, so just bypass it. Be sure to use black tape to tape any bare wires. Please don't forget to rate me as I know you will be kind to me. Please keep me posted on this also by my user name below. This will solve your problem until you get a new one.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
Sep 06, 2010 | Whirlpool Heating & Cooling
I hit a button , must have been a format button on my sansa mp3 player. my computer will not show it exists yet it charges the unit. please help.
May be its a wrong format type.
ok try to format it with fat file system.
Follow the steps below.
Go in Control Panel>Administrative Tools>Computer Management> A window computer management will appear. Then in the left column click disk management.
Format it with fat file system.
Tyr this and let me know...
Jan 28, 2010 | SanDisk Sansa Clip MP3 Player
Sony 46in projection tv
To reset this unit start with pwr off. Then on oringnal remote press the display button, the number 5 button and then volume up button and then hit the power button this will take you into the service mode menu, Press the number 8 key and then hit enter, this will set the unit back to factory specs. The set should turn off itself and then power on itself to channel 3, All user setting before this procedure are reset to factory mode..
Please leave comment THX
Nov 04, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Plz help...
A firmware update. Same happens to my friend's unit yp-u2(x) a 512 mb model.
In XP OS.
1. Download and install firmware updater.(manufacturer's support site)just key in model number and type.
2. Run updater, press and hold play button until its been detected fully by the updater.
3. Check the format box(My friend's unit firmware ver is 1.xxx to 2.xxx something when updated).
4. Hit the update button or something like that. do not detached the unit until its done. Unmount the unit using unmount method "Safely remove hardware".
5. Turn on the unit it should pass the 20 percent mark. When its good it has no file yet coz of format option. Just load your song.
I think it happens when too much file is upload in the unit. 60 percent of its capacity may be enough.
Hope it helps............
Jan 16, 2009 | Samsung YP-U2X Digital Media Player
Sony Walkman NWZ-S615F problem detecting and syncronizing
I had the same problem. One day my Mp3 started acting weird and said it was not recognizing the files and that i needed to re download them. Try plugging it up to your computer while its charging and hit the power off. Then reset your mp3 with the button at the bottom and it should recognize it.
Nov 17, 2008 | Sony NWZ-S615F Walkman Video MP3 Player
I have a never used air conditioner, I put it in window plugged it in, when you hit reset button the green light power indicator comes on, when you hit test it shuts off, the power will not turn on at...
I'm assuming that you're hitting the buttons on the GFI outlet. The test will test the grounding of the outlet. The reset fixes it. These have nothing to do with the A/C. Hit reset and leave it alone.
There is a control panel with fan and temperature switches in the a/c unit somewhere. Turn on the fan/ a/c switch and set the fan on high. Move the temperature switch to mid-range. The noise on the unit should be a bit louder as the compressor kicks in to do the cooling.
Jun 13, 2008 | Samsung Heating & Cooling
Frozen screen
Resetting Your c330
If your unit locks up, press the Power button to turn off the unit, then press again to turn the unit back on. If this does not help, reset your C330.
1. Place your thumb nail in the groove located under the Garmin logo on the face plate.
2. Gently pull off the face plate.
3. Press the Reset button.
4. Turn the unit back on; it will operate normally
Apr 04, 2008 | Garmin StreetPilot C330 GPS Receiver
Nextar X3-03 Car GPS Receiver Logo
75 people viewed this question
Top Nextar GPS Experts
Are you a Nextar GPS Expert? Answer questions, earn points and help others
